Turbo
Old Nov 29, 2005 | 02:48 PM
Z06VET's Avatar
Z06VET
Originally Posted by Shinobi'sZ
Good luck Dave...don't let people's negativity bring you down. Its fun pioneering new kits...I know...I got to do it with ATI, TTI, and PTK....that doesn't include H&C, suspension and other miscellaneous stuff I have put on the 2 C5s I have owned. While sometimes frustrating it can be one of the best learning experiences you will ever have owning one of these cars....especially if you have turned wrenches on cars before.
You will find a lot of people in this section who comment and offer their experience, to have merely only wrote a check for their TT or SC kit, but have never even worked on their cars and probably only been to the track a few times. They also hang really well on the legs of others and have a tendency to regurgitate.
Now this makes sense .... buy a 50 k plus car ( up here they're 75k ) and put some unproven kit into it just so you can cause yourself frustration , hassle, growing pains , plus some possible additional costs . There is some degree of it with "proven " kits , nevermind the unproven . Can you say yikes ? As for just writing a cheque for their TT like thats a bad thing , feel lucky that you can, because the reality is MOST people cannot afford 100k + car and if this is the case , things must be going pretty good for you. Enjoy it. And good luck with your choice.
Dan
Old Nov 29, 2005 | 03:19 PM
DDSLT5's Avatar
DDSLT5
Originally Posted by Bill Reid
Big Dog,
One thing you need to ask yourself is: Do you feel lucky? Well.........DO YA PUNK???????
Good luck
Bill
Totally uncalled for, Bill. If you don't have anything nice to say.............
Old Nov 29, 2005 | 04:02 PM
Sportsdude's Avatar
Sportsdude
Big Dog,
One thing you need to ask yourself is what are your expectations for performance? Do you plan on future power upgrades or once you are done will you always be happy with the kit? I find most guys get used to the power and want more down the road... something to take into consideration. Do you want to see what you paid for up top or do you prefer the stealth look when the hood is opened? Kit "superiority" can move from kit to kit based on what exactly you want... what YOU define as "superior". Most if not all of the kits normally discussed in this section are great kits... with excellant customer service after the sale. Maybe Cerra's initial single turbo kit was a turd but guys that like to tinker made it a great kit... but as far as I know tha kit is no longer available anyway.
So heat and lag must be important factors for you. Have you ever driven a turbo car? What are your expectations for lag? Must you have instant boost... or do you prefer it build over a given RPM range? Sure, you will have guys that prefer one or the other... but in the end it depends on your expectations... not theirs.
Heat can be creatively dealt with on over the top or bottom mount kits... but heat MUST be managed no matter what kit you choose. Thats a given...
Andy@A&A will have super nice over the top kit coming out soon as well... and I wouldn't expect it to be released without being run through the ringer.
STS' twin kit looks to be a formidable opponant... with much less of the heat componant being a factor.
Will you install the kit? On what? Who will tune? You? If not, have you talked to the tuner about kits they have tuned?
... and if you are going to turn the screws on the kit... better be prepared to do a little research on fuel delivery capabilities as well. Some guys are running stock short blocks... some are forging the bottom ends. How much of your money can I spend?
Good luck
Bill
Thanks for the tips Bill. Since I don't have the $$ at present, I will wait for A&A TT system and I'm not in a big rush. I personally like the over the top systems.
Old Nov 29, 2005 | 04:29 PM
FastCashDave's Avatar
FastCashDave
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Dan
Thanks Dan
I am very excited about this new Turbo
I have done alot of research on turbos and these guys have it going.
They know what they are doing, So no one is going to change my mind
I am going to keep everyonr posted on my progress, I will be doing most of the work myself, Well me and my mechanic
I will also be posting Pictures of our progress.
Have A Great Day
Dave Dillon
Old Nov 29, 2005 | 06:07 PM
Shinobi'sZ's Avatar
Shinobi'sZ
Dan
That was kind of my situation. At the time I didn't think I could afford to both buy my car and send it to LPE for a TT setup. But in hind sight if I was to include my labor it would have been easy in achieving $30-40K in mods.
As it is I have only spent about $20-25K (in mods) between 2 cars and 3 different power adder kits and some H&C setups. Not too bad because I was able to sell everything for about .75-85 cents on the dollar.
You cost things out...pick a kit..any kit...lets just focus on a price for a Turbo kit and split the difference of the DIYer prices to arrive at $8k for a Turbo kit.
Turbo kit $8K
Forged motor $6K Depends on HP goal
(long block LSx) Subtract $3k for H&C
Stock Crank, H&C and stock bottom
Clutch $1K
Fuel System $1K
Fuel Injectors, Pump
Return system
Miscellaneous $500
Tune $500
Subtotal (no installation) $17k ($14K stock bottom)
Now you have to figure what the install is going to run. A diy'er can stay under $20K or $15K depending on whether you replace pistons or not.
If I was only going with 9-10#s, I wouldn't bother replacing pistons until a time arrived when I was forced to. You can effectively lower your CR down to 9.2:1 (approx) with a larger CC heads.
I hear people on here stating that they are running their stock bottom end with a "safe" tune..I find that comment hilarious....whether you are stock bottom or not you should be running around with a "safe" tune.
Having a stock bottom end vs. having forged pistons doesn't necessarily mean more power at the same # boost, it just adds an added level of reliability, in that it provides some cushion should detonation occur. Plain and simple.
An example, LPE for a long time has been giving full warranties on their TT 550 setup...and it is stock bottom, they merely used larger CC volume to lower the CR.
I used a stock bottom end with my Procharger setup at 12-13#s, stock Heads, and a mild cam. Ran great...for awhile. It was right at the time (beginning) of the introduction of aftermarket FPs..which I didn't own. I was using the stock FP and an inline pump....it leaned out. It only takes 1 or 2 times detonating with stock Hyperuetetic pistons....kaboom!
So after that I went with forged pistons and rods, but kept the stock crank.
Bottom line is you can make 590-630 rwhp with a stock bottom quite easily, and a few guys have made more (Quicksilver) on a stock bottom...if everything is working correctly and there is a certain degree of reliability of everthing working as it should all the time. That being said, any error at those hp levels (detonation) and you can kiss the stock pistons goodbye..they just can't take any abuse..too brittle..never were intended for NOS or FI.
By the way..the only frustration I had was with ATI and some promises made by a Vendor selling the TTi kit. The ATI frustration was very brief with me about 4 years ago and the same issues lasted and came up until just recently. I had the ATI kit for 6 mos...it evolved into the first A&A kit..which followed after many discussions I had with Kenny from GWP.
The most frustrating experience I have ever had with adding a power adder to my C5, in fact I was first approached and asked if my car could be the donor car..and I said yes. The kit did not deliver what was promised to me and what was supposed to take 6 weeks took 9 mos. After I got the car back I took matters into my own hands and was not able to achieve much better results...I picked up 10 more rwhp at a lower CR..so not a total failure.
But it was largely due to some promises that were made about the product..that really were not backed up in the real world...but I was willing to give most reliable tuners the benefit of the doubt...I did..and as a result...a much better kit is available and people seem to be quite pleased about it...so a happy ending.
On the opposite end of the spectrum is the kit I have now. Which took 6 mos to develop from beginning to end.
Old Nov 29, 2005 | 09:56 PM
Earl H's Avatar
Earl H
Originally Posted by FastCashDave
This is the turbo setup that I'm going with to make a 1000 + rwhp
I am taking them some money tomorrow so they can get started on my 408 motor .
Iwill have there Turbo setup for the Corvette World to see in March at the Corvette Forum Cruise in.
Brad at Force Fed High Preformance Know's his ****.
Here is the thread check it out
http://forums.corvetteforum.com/show...9&page=1&pp=30
Have a great night
Dave Dillon
dld61@blueriver.net
Someone hasn't been paying attention ....Big Cubes + T76GTS + 3" DP = huge back pressure issues at higher boost pressures. Try it if you want, but I have seen the results of the above combination. For this reason I am switching to a twin turbo setup (packaging). My single makes great power on stock cubes, but going to a 4XX motor with my single setup would not be a good idea. You will need at least a T88 t4, preferably a T6 to make good power efficiently.
Old Nov 29, 2005 | 10:12 PM
Z06GMAN's Avatar
Z06GMAN
St. Jude Donor '06
You know I am sure that you will hear different thing from different people. But On single turbo's Earl not only knows what he is talking about............he has done it.
Old Nov 29, 2005 | 11:11 PM
NICK YOSKIN's Avatar
NICK YOSKIN
St. Jude Donor '08
hehehehehehe....... 50k
check this out!
got a friend who is serouisly thinking about using his car a donor for new turbo kit. cannot say who the company is at this moment but should be VERY intresting, to say the least.
oh yeah the car LAMBORGHINI MURCIELAGO.
Dan
