Coolant?
Old Jan 18, 2006 | 06:22 PM
z06boz's Avatar
z06boz
Default Coolant?
Is there any better coolant to run on a F/I car, besides the pink stock stuff. And also how do you drain the coolant?
Old Jan 18, 2006 | 06:33 PM
jers98vet's Avatar
jers98vet
I use the dexcool mixed 50% with water and an Evans pump. When I want to drain my coolant I just pull the lower rad.hose and rinse off the driveway.
Old Jan 18, 2006 | 08:23 PM
z06boz's Avatar
z06boz
gotcha, what is dexcool exactly?
Old Jan 18, 2006 | 10:09 PM
DanTTVette's Avatar
DanTTVette
A quote for ya
Your question sparked my interest...
Dexcool® is marketed to last for 5 years or 150,000 miles of service, compared to traditional green antifreeze/coolants which are marketed as dependable thermal control and corrosion and rust protection for twenty-four (24) months or 30,000 miles. Traditional antifreeze/coolants contain inorganic salts of borate, phosphate, silicate and other chemicals to prevent rust and corrosion, whereas, Dexcool’s® corrosion inhibitor components, are based on organic acid technology (OAT). Dexcool® is orange and traditional antifreeze is green.
Old Jan 18, 2006 | 10:10 PM
BLOWNZO6's Avatar
BLOWNZO6
Premium Supporting Vendor
Glad I don't live in your neighborhood...
Old Jan 18, 2006 | 10:25 PM
NICK YOSKIN's Avatar
NICK YOSKIN
St. Jude Donor '08
there some stuff out there that i wanna run in liue of antifreeze. if i pop a gasket or get antifreeeze in the oil i wont need to worry about my bearings. need to ask julio don, he's the one told me.
Old Jan 19, 2006 | 09:21 AM
sqeznbi's Avatar
sqeznbi
My 2001 z has a drain plug i guess you could call it on the passenger side lower corner. Its a white cap with a big slot in it , i use a short flatblade screwdriver.
Old Jan 19, 2006 | 04:23 PM
LRD VDR's Avatar
LRD VDR
Coolant is over rated! In the summer time irun water, Redline Water Wetter and a pint of water pump lube. And here in Texas in the winter time, I use Nissan green coolant from the Nissan dealer. if I worry about it being really really cold!
Shahram
Old Jan 19, 2006 | 04:45 PM
z06boz's Avatar
z06boz
so u can run strait water, with some water wetter and what is that other stuff
Old Jan 19, 2006 | 05:16 PM
LRD VDR's Avatar
LRD VDR
Just a water pump lube made by Prestone. You can buy it anywhere.
Shahram
Old Jan 19, 2006 | 08:28 PM
jers98vet's Avatar
jers98vet
Gotta love living in the boonies with a gravel driveway!
Old Jan 20, 2006 | 12:14 AM
z06boz's Avatar
z06boz
one more question is there any cooling advantage to using something other than factory?
Old Jan 20, 2006 | 08:38 AM
LRD VDR's Avatar
LRD VDR
Ethelyne Glycol(sp) is actually has pretty crappy heat dissapation properties, but it does raise the boiling point. And I don't know if you guys do much work on cars/trucks that run the "Long Life" coolant but that sh$t really sucks. Even more so with more miles. Water does have a much better dissapation rate but the boiling point is lower so you need to make certain of your cooling system is in great condition. Something I'm sure C5 owners do anyway. All this of course does not mean poop if you live in a very cold climate!! Then you really need to run antifreeeeze!!
Shahrm
Old Jan 20, 2006 | 09:12 AM
99 C-5 F1C VETTE's Avatar
99 C-5 F1C VETTE
the best out there that I have seen is the evans waterless coolant
EVANS COOLING SYSTEMS, INC. Evans Cooling Systems, Inc. introduces NPG-R, its newest addition to their innovative line of waterless Engine Coolants. NPG-R is specifically formulated to handle the extreme conditions of racing and high performance automotive, marine and motorcycle applications. Engines previously unable to be effectively cooled with water or conventional water-based antifreezes now have the option of the improved heat transfer formula of NPG-R.
NPG-R exhibits superior coolant flow, as it is less viscous than the popular NPG+. Its improvement in thermal-conductivity increases the ability of NPG-R to transfer extreme heat away from the engine coolant jacket. This provides superior engine metal temperature control. High coolant temperature related detonation is also eliminated with NPG-R as it stays in a more liquid state instead of converting to vapor and creating hot spots within the engine coolant jacket. Remaining in a more liquid state allows NPG-R to remove additional heat from the cylinder heads when compared to other coolants. The heat is then transferred away from the engine providing continuous control of cylinder head metal temperatures.
The reduced viscosity of NPG-R makes it more compatible with small tube copper-brass radiators while providing the superior cooling of Evans Waterless Coolants. (NPG+ and NPG are only recommended for large tube aluminum radiators.) All metals, including Magnesium, are safe to use with NPG-R. Although NPG-R is safe for all metals and contains no water, an annual coolant change is suggested for racing vehicles. For maximum corrosion protection, high performance street driven vehicles running NPG-R should change coolant every other year.
NPG-R does not freeze or boil-over. In cold temperatures (down to -1OF°) NPG-R will not freeze and expand like conventional water-based antifreezes potentially cracking the engine block. In contrast NPG-R contracts into thick slurry - never becoming a solid. With a boiling point of 400°F at 7psi, NPG-R will never boil-over because it immediately condenses back to a liquid within the cylinder head coolant jacket, maintaining a liquid contact on all metal surfaces at all times.
As with NPG+ and NPG, NPG-R is a stand-alone coolant. Therefore, NPG-R requires all the existing antifreeze and water to be removed from the radiator, engine block and heater core. (Evans Prep Fluid is available for smaller capacity systems where the engine block cannot be fully drained) Once system is empty fill 100% with NPG-R. A free Test Strip is included with all purchases as a guide to a successful conversion. Technical assistance is available to assist in determining which Evans Waterless Coolant is right for your application.
Evans and Darton Sleeves
Darton Sleeves Requires NPG+ or NPGR for use with its sleeve conversions
The Darton kit effectively converts the block to a wet sleeve configuration as used on diesel engines. One cannot expect the original cooling system to effectively cool an engine producing two or more times the power of the original engine, along with a modified cylinder arrangement. We require “Evans NPG+™ coolant” be used as well as Evans LS-1 reworked water pump utilizing a relocated thermostat. High output applications may also require a larger radiator and coolant fan. Evans coolant is recommended because of the potential for hot spots and cavitation around wet style sleeves. We realize that most engines built will produce well in access of the stock rated horsepower making cooling system enhancements a must.
The above taken from Darton Sleeves Technical papers. For more information on Darton, please visit http://www.darton-international.com
Old Jan 20, 2006 | 11:59 AM
Warp Factor's Avatar
Warp Factor
How does propylene glycol stack up on thermal conductivity and boiling point? Anyone know?
Old Jan 20, 2006 | 12:26 PM
z06boz's Avatar
z06boz
im glad i made this thread very helpful, thanks guys
and the waterless coolant where do you get it?
Old Jan 20, 2006 | 03:53 PM
RED99's Avatar
RED99
Shahram
How do you stop corrosion? And won't that lower your boiling point running straight water?
To Coolant?
Old Jan 20, 2006 | 04:50 PM
LRD VDR's Avatar
LRD VDR
With the water pump lube from Prestone and the Watter Wetter from Redline. Yes, it does lower the boiling point but its still over the 260 degree factory gauge limit.
Shahram
Old Jan 20, 2006 | 06:38 PM
Warp Factor
Shahram
The risk isn't that your average coolant temperature (which is what the gauge measures) will go over 260, but that it will exceed that temp in localized hot spots such as around exhaust valves, flash to steam, and then you lose your metal-to-coolant contact. Higher risk of detonation. Considering this, is water sufficient, or is something with a higher boiling point an advantage?
Old Jan 20, 2006 | 08:48 PM
pski694's Avatar
pski694
Can I send my neighbors dog to your house when he needs a drink?
