First Boost Run
Old Aug 4, 2006 | 10:22 AM
V8_Club's Avatar
V8_Club
Default First Boost Run
Finally after many months of waiting I have experienced boost via an ECS Paxton. Sweet. The only thing that kinda spoilt the fun was the car going into reduced power mode with Service Active Handling come on. First time I forgot the traction control on. Next time though I have no idea why it came on since the trac control was off ? . Second time I went up to 230 ish kph ( very fast I might add ) . The reduced power mode stayed on and didn't go off despite me turning the ignition off then on ( this got rid of it the first time ) . Also note that rpms would stick up at 2kish ( Is it the TB is stuck /open ? ) . So finally I remembered to clear codes . PCM Code 0068 I think ? or 0096/8 not sure.. But after I cleared it car ran normally. Didn't floor it again though after that. Codes didn't re
-appear as well. I did give it some boost sub 5 psi but it was ok. The second time boost was in the 6 to 7 region.
Any ideas ?
Old Aug 4, 2006 | 10:31 AM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Originally Posted by V8_Club
Finally after many months of waiting I have experienced boost via an ECS Paxton. Sweet. The only thing that kinda spoilt the fun was the car going into reduced power mode with Service Active Handling come on. First time I forgot the traction control off. Next time though I have no idea why it came on since the trac control was off ? . Second time I went up to 230 ish kph ( very fast I might add ) . The reduced power mode stayed on and didn't go off despite me turning the ignition off then on ( this got rid of it the first time ) . Also note that rpms would stick up at 2kish ( Is it the TB is stuck /open ? ) . So finally I remembered to clear codes . PCM Code 0068 I think ? or 0096/8 not sure.. But after I cleared it car ran normally. Didn't floor it again though after that. Codes didn't re
Any ideas ?
Congratulations!
The problem is in your in tune, send us your file and we can take of it for you. Or we can just tell you what to do over the phone.
Old Aug 4, 2006 | 10:36 AM
V8_Club's Avatar
V8_Club
Cool. Are you in the office now ? I can call now :P
Old Aug 4, 2006 | 10:47 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
Congrlations on the boost and those guys should be in the office it is almost 11:00 am
Old Aug 4, 2006 | 10:52 AM
V8_Club's Avatar
V8_Club
Thanks I just called them . Turns out there is an issue with the tune . Thing is I am running in SD mode. Maf FQ set to NIL. Codes 102 / 103 Set to No MIL. They will tell me what tables I need to change in Hp Tuners.
Old Aug 4, 2006 | 11:03 AM
marco383's Avatar
marco383
My blown 427 (773 RWHP) just did exactly the same thing: big power, big wheelspin, then the "service traction system, reduced power" message.
I'm passing thsi string along to my tuner.
Old Aug 4, 2006 | 12:09 PM
Corvette4ever's Avatar
Corvette4ever
Is that how you break in your new tranny
Anyway, definitely it sounds like a tuning issue
Old Aug 4, 2006 | 12:11 PM
V8_Club's Avatar
V8_Club
lol Hey buddy,
Don't worry I took Chuck's advice and went easy for 300 miles. After that I did exactly what he told me to do : HAVE FUN lol
Old Aug 4, 2006 | 06:35 PM
V8_Club's Avatar
V8_Club
I think this is the table that needs to be changed :
Suggestions ?
Old Aug 6, 2006 | 06:25 AM
V8_Club's Avatar
V8_Club
Old Aug 6, 2006 | 03:47 PM
Corvette4ever
"code 0068 is set if pcm detects too large a difference between maf airflow and sd calculated airflow. Appears to be specific to 2004 model. Also an improperly installed tb sensor can set code"
Old Sep 3, 2006 | 11:48 AM
V8_Club's Avatar
V8_Club
I'm still waiting for a professional response to this one ....
Old Sep 3, 2006 | 12:05 PM
Ken G's Avatar
Ken G
I had the same problem when I first switched to an SD tune. I'm not familiar with the HPTuners suite but it looks like you've found the right table. In EFILive the table is called ECT Predicted Airflow {C6101} and it plots airflow in mg/cyl on a grid of Throttle Opening% vs. RPM. I was told to scale the whole table by 200-300% which eliminated the P1514/reduced power problem for me.
Old Sep 3, 2006 | 11:23 PM
V8_Club's Avatar
V8_Club
Thanks Buddy. Just wanted some confirmation on this
To First Boost Run
