Alky kit install help
Old Nov 9, 2006 | 06:01 PM
clemsondave's Avatar
clemsondave
Default Alky kit install help
I'm installing the ECS Alky kit and could use a little help. Please look at the picture below and tell me if the 'x' is the proper place to mount the nozzle. Any other words of wisdom? I've got the washer tank and pump mounted.
Old Nov 9, 2006 | 06:29 PM
Scubanme's Avatar
Scubanme
Yep, you got it. before the throttle blade because you don't want to install after the blade, as it could lead to siphoning. Before the MAF would get wrong Maf readings.
Maybe somebody else can chime in too to confirm this.
Old Nov 9, 2006 | 06:32 PM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
Old Nov 9, 2006 | 06:36 PM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
Yep, after the MAF and before the throttle (unless you provision other means to prevent siphoning). Check the height of your nozzle relative to the height of the tank (washer fluid reservoir?) as without a check valve, you can get some drainage/siphoning even though the nozzle isn't exposed to constant vacuum. It can puddle, which can be problematic.
Old Nov 9, 2006 | 06:41 PM
clemsondave
Supposedly, the kit contains a check valve. Either I dont know what it looks like, or it is not in here. The parts inventory lists it. Anyone know what it looks like?
Old Nov 9, 2006 | 07:29 PM
DanTTVette's Avatar
DanTTVette
Here is an average piccy of the check valve (ECS kit).
You should see some small arrows on the side.
Old Nov 9, 2006 | 07:40 PM
clemsondave
Thanks!
Wiring/controllers go in tomorrow. Probably post more questions.
I am racing on Sat. Anyone see any issues with just getting it installed and running with it? In other words, without tuning? Not looking for more power, just to richen up the mixture a bit.
Old Nov 9, 2006 | 07:46 PM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
No problems doing that, just don't richen up too much. You'll know when you've gone too far by a decrease in power.
Old Nov 9, 2006 | 08:21 PM
HeadHunter1's Avatar
HeadHunter1
Here is my ECS installed setup. The brass fitting on the intake tube is the Alky.
Old Nov 9, 2006 | 09:12 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Here is one installed on my A&A kit and you can see the check valvue, I purchased the check valvue prior to ECS shipping them and I have had no issues with any Alky getting into the intake
Old Nov 10, 2006 | 09:22 PM
clemsondave
Ok, just about done. I kept the tank empty, turned the ignition and pushed the test button. The LED lit up. Yea!
However, the low washer warning did not come on. I made sure the wire was connected. Anything else I should check?
also, any suggestions on the settings considering my setup in my signature?
Old Nov 11, 2006 | 01:26 AM
jbsblownc5's Avatar
jbsblownc5
2017 C5 of the Year Finalist
St. Jude Donor '08
You might have the WW sensor upside down in the tank, and check to see the sensor is plugged in well...
Good luck!
JB
Old Nov 11, 2006 | 02:34 PM
NICK YOSKIN's Avatar
NICK YOSKIN
St. Jude Donor '08
Good luck!
JB
"floatin the wrong way there boy"
Old Nov 11, 2006 | 08:31 PM
clemsondave
Nope, I had it right. Guess I was following the instructions to well. The sensor does not work without the car running. The ECS intructions just say to turn the ignition to run. Once I cranked it up and drove down the street, the warning light came on.
btw, that was a pretty easy install!
Old Nov 15, 2006 | 11:17 AM
Laguna Blu's Avatar
Laguna Blu
What kind of fluid exactly is used? Do you just keep the windshield washer tank full? Thanks.
Old Nov 15, 2006 | 12:07 PM
Mike04's Avatar
Mike04
ECS suggested to turn the gain 1/2 way on my dual nozzle set up (I think that is 4). My sig has what I'm running.
Old Nov 15, 2006 | 12:09 PM
Mike04's Avatar
Mike04
The windshield reservoir is filled with methonal or a methonal/ water mix. I leave mine full of straight Meth
To Alky kit install help
Old Nov 15, 2006 | 12:34 PM
Laguna Blu's Avatar
Laguna Blu
Where do you buy methanol?
Old Nov 15, 2006 | 01:31 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
We have found it cheapest if you buy it at the track, short of picking up a 55gal direct. In a pinch Home Depot sells denatured alcohol or Wal mart sells Heet, but it whinds up costing more.
Old Nov 15, 2006 | 04:02 PM
BigLew's Avatar
BigLew
Default DD's
Nick,where did the avator come from?
