APS FMIC install notes
Old Feb 21, 2007 | 03:39 PM
Fastbird's Avatar
Fastbird
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
Originally Posted by Steve@CTCorvette
once you 'alter' the sheetmetal near the turbos, they fit; only way in is manifold/turbo/exhaust all together
re: foglights, i think if we moved them forward they might work, no room to go inboard(frame rail)
in the directions, the f/l's are omitted and Z06 screens are suggested
Instead of modding how/where the fog lights mount, why not mod the piping around them for clearance. IIRC, you said the BOV sections were what was interfering. If that's the case, that should be a pretty easy workaround I would think to relocate those a little bit.
Old Feb 21, 2007 | 04:39 PM
NoOne's Avatar
NoOne
This just hit me as I've been reading...a most likely exspensive, yet workable fix might be a ring of LED's to go around the opening.
Bright and angled right you could mimic the fog light look and still allow air in.
Old Feb 21, 2007 | 04:55 PM
IM QUIKR's Avatar
IM QUIKR
Old Feb 21, 2007 | 05:50 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
If you move them in front of the rad/cond you block the bottom half of airflow and basically cut half of or eliminate the plastic rad. shroud, I set the tubing up that way to see how it looked
another downfall of positioning the filters in there would be water ingestion
alright, back to work for me
Old Feb 21, 2007 | 06:09 PM
Fastbird's Avatar
Fastbird
Pro Mechanic
Oh, so it's the air filters that's cauing the clearance issues???
Water ingestion??? This is a non-rain car now.
Just keep my fogs, that's all I ask. As long as they're in, look like they do when the car was stock, and function, I'll be happy.
Old Feb 21, 2007 | 09:48 PM
Slowhawk's Avatar
0Slowhawk
Former Vendor
Just dump the stupid fog light's already
Old Feb 22, 2007 | 07:07 AM
vetteboy2k's Avatar
vetteboy2k
First off the facory fog lights do absolutely nothing. Instead of paying labor to find a work around for keeping them, just put in some Piaa 1100x fogs and be done with it. You will have more light and they "DO" fit.
Old Feb 22, 2007 | 05:32 PM
SteveDoten's Avatar
SteveDoten
both turbos are in, fmic's and pipes installed, need to finish the oil return lines, Comp 918's and Textralia/LS6 slave/master complied with
the LHS coolant drain plug didn't want to move very easily
it's time for a new thread with more pics
if anyone has any questions feel free to post
Old Feb 22, 2007 | 05:45 PM
SpeedyD's Avatar
SpeedyD
How many hours would you say you have into it this far? Is there estimate of 36 or 38 close, or are we in for a real shock treatment!?!?!?
Old Feb 22, 2007 | 09:30 PM
Fastbird's Avatar
Fastbird
Pro Mechanic
Where's this new thread with pics?? I'm going through withdrawal.
Old Feb 22, 2007 | 09:57 PM
SteveDoten's Avatar
SteveDoten
started snowing/raining, had to scramble to get back home
Dan, 38 hours would be a good estimate next time
Old Feb 22, 2007 | 10:20 PM
Fastbird's Avatar
Fastbird
Pro Mechanic
I can completely understand that one. I'm excited for sure, hearing that both turbo's are already in!!!!
Old Feb 23, 2007 | 09:51 AM
  #33
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
1. looks like no room for oe foglights, BOV tubing is right there
That makes sense, I believe they used a c5 z06 from A&A to do a final mock up. (no fogs in a z)
