APS FMIC install notes
Old Feb 10, 2007 | 08:57 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
Default APS FMIC install notes
just some minor things to point out
the brace on the inner fender that attaches to the aft headlight mount needs to be rem'd iaw APS instructions, be advised there are retaining clips on each stud(ie: oem brake rotor clips), you will need to remove the h/l assy to gain access to the clilps; also GM sometimes shims the aft mount with washers(there is one of three in the third pic)
97-00 owners: you won't have a vacuum line to the AIR pump, do not coil and tie off the pump wiring unless you plan on omiting the fog lights(LHS f/l wiring is part of the pump harness)
Old Feb 10, 2007 | 09:21 AM
jfhand69's Avatar
jfhand69
7th Gear
Default Item 230,231
I havent started install but while sorting parts into smaller labeled bag item 230 and 231 could not be found in instructions. Think these are for dipstick tube bracket. They did tap rt manifold for this. May have to shorten bracket because now its spaced out from head? Having cast parts coated this weekend. thanks for info above watching forum for any problems with installs.
Old Feb 10, 2007 | 10:05 AM
SteveDoten's Avatar
SteveDoten
you sure those tapped holes aren't for the heat shield?, 4 bolts/washers and s/s tie straps
most likely you'll need the '01 and newer style tube that bolts to the heads along w/ the newer d/s
Old Feb 10, 2007 | 12:21 PM
SteveDoten's Avatar
SteveDoten
1. looks like no room for oe foglights, BOV tubing is right there
2. F34/55 adj. suspension boxes won't fit with the discharge tube bolted in(allow a few hours for some fab work on the pipes)
3. early 97-00 maf req's a silicone tube coupling to fit correctly into the aps intake tubing or replace w/ later/bigger maf(01-04)
Old Feb 10, 2007 | 06:30 PM
Fastbird's Avatar
Fastbird
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
Do WHATEVER necessary to keep the fog lights please. I have no intentions or desire to lose those. Those MUST stay in my eyes.
Old Feb 10, 2007 | 06:49 PM
SteveDoten's Avatar
SteveDoten
don't worry, we'll figure something out
Old Feb 10, 2007 | 07:43 PM
Fastbird's Avatar
Fastbird
Pro Mechanic
I have faith in ye!! Looks like things are progressing nicely!
Old Feb 10, 2007 | 08:39 PM
Z_Rocks's Avatar
Z_Rocks
Nice work Steve!
Old Feb 11, 2007 | 01:09 AM
Sportsdude's Avatar
Sportsdude
Will the PIAA X1100 lights be a problem as well? Thanks for the info.
Old Feb 11, 2007 | 05:49 AM
Z06Samuel's Avatar
Z06Samuel
Steve,
Thanks for the info, will be installing my kit soon. Any info is always helpful.
Old Feb 11, 2007 | 10:44 PM
Slowhawk's Avatar
0Slowhawk
Former Vendor
Looks like fun
You can toss the air pump into the trash. Also,get the computer to me.
Old Feb 13, 2007 | 07:35 AM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Old Feb 13, 2007 | 08:18 AM
Fastbird's Avatar
Fastbird
Pro Mechanic
Originally Posted by Slowhawk
Looks like fun
Actually save that air pump. Someone will want it.
Steve says teh Tex 0Z700 is going in today with new hydraulics (04 Z) and I'm ordering Bilstein Sports today also (and sims for a temp fix until I can get the F45 removed from the BCM).
Old Feb 13, 2007 | 06:44 PM
0EG@EnglandGreen
Supporting Tuner
Any updates?
Old Feb 13, 2007 | 08:05 PM
Fastbird's Avatar
Fastbird
Pro Mechanic
Yeah, I ordered Bilstein HD's today and they'll be at the shop on Friday, and ordered new O2's and they'll be there tomorrow. I think Steve has everything else, but we were talking today and it's slow moving in somewhat uncharted territory.
Old Feb 14, 2007 | 02:03 PM
LS6.net's Avatar
LS6.net
Thanks for the updates on fit and such.
How is everything else going with the kit? Fit as expected?
Old Feb 21, 2007 | 12:12 AM
NassauBlue98's Avatar
NassauBlue98
Updates on the APS install(s)???
Were you guys able to keep the foglights?
To APS FMIC install notes
Old Feb 21, 2007 | 08:54 AM
Fastbird's Avatar
Fastbird
Pro Mechanic
Not sure about the fog lights right now, Steve hasn't updated me on those. There's going to be some custom work to get the clearance necessary from the BOV piping.....that's all I know there.
He told me last night that the left side turbo is in and mounted.
Old Feb 21, 2007 | 09:55 AM
IM QUIKR's Avatar
IM QUIKR
Can't the plates on the side of the skid rails be removed and the pipes run through the the skid instead of in front of it? Then the fogs would not be affected. Right?
Old Feb 21, 2007 | 03:00 PM
SteveDoten's Avatar
SteveDoten
once you 'alter' the sheetmetal near the turbos, they fit; only way in is manifold/turbo/exhaust all together
re: foglights, i think if we moved them forward they might work, no room to go inboard(frame rail)
in the directions, the f/l's are omitted and Z06 screens are suggested
