Speedy D's APS Project
Old Feb 27, 2007 | 10:28 PM
  #61
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
Dan, remove the 3 bolts and the foam support on the front face bar, your build sheet is in there(saves you $40 )
I fired up the APS car today, no drama, just topped off the coolant, get that metal glowing and start hammering
shoot me a pm if you have any questions
Old Feb 27, 2007 | 11:10 PM
  #62
SpeedyD's Avatar
SpeedyD
Well yeah, I think the big question is, how'd she go!?!?!?!? I think a couple more hours and I should have mine fired up!! Slow and steady will hopefully win this race!!
Thanks for the tip, had no idea the build sheet is in there, I will have to take a look!!
Old Feb 27, 2007 | 11:32 PM
  #63
oahuyahoo's Avatar
oahuyahoo
UPS, USPS and Fedex have got you dialed in.
Old Feb 28, 2007 | 05:33 AM
  #64
SpeedyD's Avatar
SpeedyD
Old Mar 5, 2007 | 08:54 PM
  #65
NICK YOSKIN's Avatar
NICK YOSKIN
St. Jude Donor '08
dan it aint that bad!
[IMG][/IMG]
Old Mar 6, 2007 | 03:45 AM
  #66
nassauzo6's Avatar
nassauzo6
Default Exhaust
how much do you want for the dynatech exhaust???
Old Mar 6, 2007 | 04:58 AM
  #67
SpeedyD's Avatar
SpeedyD
[QUOTE=NICK YOSKIN;1559242223]dan it aint that bad!
I'm only a few bolts away from that, on jackstands!!! no lift, basically by myself, with a whole lot less tools!! Bt you're right, it hasn't been that bad just yet, I think it's the calm before the storm!! If I had a lift, I would have doen exactly what was above, much easier. Pull the engine, change out the driveline, change out the susspension, brakes, and then put it all back in in one shot!! I think that would definately be the easiest way!! no? It'll get done, I'm just worried about the timeline!!
Old Mar 6, 2007 | 05:00 AM
  #68
SpeedyD's Avatar
SpeedyD
Sorry, I sold them last weekend. I got 950 plus shipping and insurance!! Good luck, keep looking, they are great headers!! If you're looking for a mild cam, blackwing intake, smooth coupler, a MN6, 3:42 rear, Bilsteins, let me know, those will be going up for sale shortly!! Thanks, Dan
Old Mar 6, 2007 | 09:29 AM
  #69
SteveDoten's Avatar
SteveDoten
no, you need to 'fit' the manifold/turbo assy's in there first
your wheels are going to hit the aft side of the discharge tubes(speculation only)
Old Apr 14, 2007 | 08:51 PM
  #70
SpeedyD's Avatar
SpeedyD
Hey guys, I know it's been a while since I posted but there has been great progress made. I sent my manifolds out to Swaintech to have them coated, I decided to go with a forged engine and that was done by Chris at CF Performance, I also picked up a RPM Level V transmission with the G-Force 5th and 6th gear conversion mated to a built rear diff, 3:42's in that. Today I was able to get the engine back into place, tomorrow I am puting the rest of the driveline in place. here's a couple pics:
Old Apr 14, 2007 | 09:41 PM
  #71
7LitreC5's Avatar
7LitreC5
I like the Pfadt goodies!
Good luck with the project.
Old Apr 15, 2007 | 11:47 AM
  #72
SteveDoten's Avatar
SteveDoten
only install the front 2 studs on the manifolds, you won't be installed the turbo/manifold/pipe assy like the instructions state
Old Apr 15, 2007 | 11:51 AM
  #73
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
Oooooooohh! Look at that hardware! Following this thread closely
Old Apr 15, 2007 | 01:57 PM
  #74
NICK YOSKIN
St. Jude Donor '08
SWEET! CF BUILDS AWESOME MOTORS!
danny call me
Old Apr 15, 2007 | 01:58 PM
  #75
02bpdz06's Avatar
02bpdz06
How much for the Bilsteins? Your really close to me, so I can pick up.
Old May 6, 2007 | 05:55 PM
  #76
SpeedyD's Avatar
SpeedyD
Well Saturday night I was able to turn the key, there are still several things I need to do, but I wanted to fire it up and make sure all is good before I go further. Fired right up, sounded good, no Check Engine light, clutch worked great, brakes were right there. There were a couple issues, 1, it's sitting too low, I need to bring it up at least 3/4", maybe a full 1" but I'm waiting for all componets to be back on the car for proper so it is at full weight. There's a little issue with the exhaust but I think I have that one figured out. I couldn't wait to clean it, so I washed it and took a few pics, now it's going back in the garage for the rest of the work. Soon, it will hit a dyno and I will post numbers!! Here's a couple pics!
And three things, I know I'm missing a lug nut, I didn't bother to put the locks on, the boost line at the intake coupling has been moved, it was running really close to the pulley and I know I haven't put the air directors at the front charge pipes.
Old May 6, 2007 | 05:59 PM
  #77
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Looks great Dan! Awesome work!
Cant wait to see the dyno numbers!
BTW, who is tuning the car?
To Speedy D's APS Project
Old May 6, 2007 | 09:10 PM
  #78
SteveDoten's Avatar
SteveDoten
do a few trial fits with the front bumper cover, the tubes might hit the blinker housings
Old May 6, 2007 | 09:51 PM
  #79
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Old May 6, 2007 | 11:23 PM
  #80
2fat2fly's Avatar
2fat2fly
Your car looks like pure sex with that system installed.
