Boost question
Old Feb 22, 2007 | 09:51 AM
Tomulrich's Avatar
Tomulrich
Default Boost question
I cannot make over 8lbs of boost on my 427TT. I am running the EBoost2...in the instructions there are two ways to plumb the Solinoids to open the waste gates...I switched to method 2 which is "how to make max boost". I am running the 7lb WG spring. Should I change this ?
Not sure if exhaust manifold back pressure is opening the wastegate?
If I want to make 20lbs (approx 20 lb spring).....what will happen when I only want 7lbs on the street?
Some knowledge of Eboost 2 is needed to understand what I am asking and how the system is supposed to work.
Hose ...Forced induction ...you there????..Anyone else
Thanks Tom
Old Feb 22, 2007 | 09:56 AM
70Stang's Avatar
70Stang
How are the lines hooked up to the wastegate? What kind of gate is it?
Old Feb 22, 2007 | 10:04 AM
RoadRebel's Avatar
RoadRebel
General rule of thumb is you should be able to make atleast 2x the base spring pressure with a boost controler. Most setups will make more.
Check your Blowoff valves and the plumbing to them, they may be blowing open. Also check for the usual hose couplers off.
Phil
Old Feb 22, 2007 | 10:36 AM
Tomulrich's Avatar
Tomulrich
will check
The wastegate is a turbosmart ultragate 38mm...
Old Feb 22, 2007 | 01:54 PM
Shinobi'sZ's Avatar
Shinobi'sZ
Originally Posted by Tomulrich
will check
As Phil stated you should be able to at least make double what the springs are set at. Using my manual boost controller with 8.75lb springs I made 18 #s.
Have you tried running your setup with no Boost Controller just to make sure everything is working correctly first?????
Old Feb 22, 2007 | 03:51 PM
NICK YOSKIN's Avatar
NICK YOSKIN
St. Jude Donor '08
tom sounds to me that there might be some sort of plumbing isssue.
double check everything as far as v. lines.
the lines comin off the niods should be going to the top of the gates.
Old Feb 22, 2007 | 04:14 PM
AlwaysInBoost's Avatar
AlwaysInBoost
can you give us a detailed description of how you have the signal lines hooked up to the WG & BC? there are several different ways to do this depending on your hardware and your goals each one has a benifit and drawback.
Not to go against what others have said above but you generally shouldn't try to run more then double the spring pressure using a boost controller. if you have a 5# spring and are trying to run 10# of boost using either an EBC or MBC what happens is that 5# spring will start to crack open prematurley somewhere between 5-10psi from exhaust pressure. this will cause you to lose power during spoolup. EBC's combat this effect somewhat by actually holding the signal line going to the WG closed using a solenoid. once your desired boost pressure is reached the solenoid will open sending a boost reference to the WG which allows the WG to open.
so basically the closer your static pressure is, which is just the spring pressure in the WG, to the actual boost you intend to run the better your boost response will be.
Hope that all makes sense...
Old Feb 22, 2007 | 05:46 PM
NICK YOSKIN
St. Jude Donor '08
[QUOTE=AlwaysInBoost;1559079613]can you give us a detailed description of how you have the signal lines hooked up to the WG & BC? there are several different ways to do this depending on your hardware and your goals each one has a benifit and drawback.
correct....that is what roadrebel said.... up to double
Old Feb 22, 2007 | 06:27 PM
AlwaysInBoost
actually he said 'at least double', I'm saying don't go above double the static pressure.
my experience has shown that trying to run too much boost on a small spring will lead to inconsistant boost pressures.
Old Feb 22, 2007 | 06:39 PM
NICK YOSKIN
St. Jude Donor '08
oh....i am sure thats what he meant though. yeah i was running 6lbs spring and really started cranking the ebc so i flipped out the springs for some 9'ers.....i see 18 WNP
Old Feb 22, 2007 | 06:51 PM
AlwaysInBoost
I'll bet you a donut if you put an 18psi (ish) spring in there, as long as thats the min boost you plan to run, your car will pickup TQ in the mid range from the WG not cracking open.
I have a couple Tial springs sitting around if you want to give it a shot.
Old Feb 22, 2007 | 08:12 PM
NICK YOSKIN
St. Jude Donor '08
but doenst the ebc hold "them" shut? isnt that one of the benifts of ebc ....gain?
Old Feb 22, 2007 | 08:37 PM
AlwaysInBoost
yep, an EBC will hold the WG closed longer then an MBC.
Old Feb 23, 2007 | 08:34 AM
Tomulrich's Avatar
Tomulrich
The EBoost2 "two port" method...used to achieve the Max possible boost pressure that the system will develop.
Connections are:
1. Boost pressure source (turbo outlet) to solenoid port 2
2. Bottom port of WG connected to port 3 of solenoid
3. Top port of WG connected to port 1 of solenoid
Rechecked all connections....no leaks, all okay.
Could it be that there is too much manifold backpressure....forcing the wastegate open......I have a 427 running the PTK kit designed for stock CI motor...
Let me know what you think
Tom
Old Feb 23, 2007 | 09:24 AM
RoadRebel's Avatar
RoadRebel
Connections are:
Tom
Its pretty unlikly thats it blowing the gates open. That typically only happens with internal gates.
This is what I suggest you do, VERY CAREFULLY!!!!
Unhook all vac lines from the gates, and go test your boost level again. It should spike in boost and It will do it pretty quick, this will help pinpoint which side of the system the problem is.
1. If it does spike then its in the Eboost or the eboost setup but this will tell us for sure.
2. If it still does not go over 8psi then we have to look elsewhere.
Phil
PS I have $5 on #1
Old Feb 23, 2007 | 09:38 AM
RoadRebel's Avatar
RoadRebel
Tom,
If you still have my cell hit me up on it.
Phil
To Boost question
