Post Your Dyno Sheet Here
Old May 29, 2007 | 08:01 AM
2010Vette's Avatar
2010Vette
From a recent thread. I will delete this if jbsblownc5 prefers.
http://forums.corvetteforum.com/show....php?t=1712112
Old May 29, 2007 | 12:00 PM
obxfunn's Avatar
obxfunn
St. Jude Donor '07-'08-'09-'10
FedEx Bowl 4 St. Jude '09
This is my 2003 Z06. Headers, 90mmTB, and Meth. Kenne Bell running 8#
New dyno coming very soon with the new forged motor, heads, and cam.
Old May 29, 2007 | 12:47 PM
NemesisC5's Avatar
NemesisC5
Originally Posted by AMERICAN_HP
LS2 403
AFR 225's
Kenne Bell 2.8H S/C @ 16psi.
Have you installed your new LME motor yet? If so is it tuned and running?
Old May 29, 2007 | 12:57 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Here is another of a 346 setup
Old May 29, 2007 | 01:04 PM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
The motor is in. I just haven't had time to install the acessories. It should be running by the end of the week. (hopefully)
Old May 29, 2007 | 02:27 PM
RocketSled's Avatar
RocketSled
Okay, so help me out here. Mine's an A4 with the stock rear-end and you'll note we were testing at over 100 friggen degrees in the dyno cell. What should I expect from an intercooled Maggie in a 98 Coupe?
Seems like it was only 40-50 hp more than stockers were running.
Old May 29, 2007 | 04:14 PM
MissZ06's Avatar
MissZ06
kinda laggy huh?
Old May 29, 2007 | 04:57 PM
2010Vette's Avatar
2010Vette
From a recent thread. I will delete if Freebs prefers.
http://forums.corvetteforum.com/show....php?t=1597629
Old May 29, 2007 | 09:18 PM
RJW's Avatar
RJW
From: Tinker till it blows... then back it off a notch, maybe!!
St. Jude Donor '08
Here is the first run of my new maggie setup...details of car in sig
547 rwhp/514 torque with clutch slipping and iat's over 180 F
I hope to hit between 575 nd 600 rwhp with this setup
http://www.co2cars.net/z06dyno1.jpg
Old May 30, 2007 | 08:04 AM
DSCHULTZ's Avatar
DSCHULTZ
402 stroker 200 wet shot
Old May 30, 2007 | 08:08 AM
chuntington101's Avatar
chuntington101
Originally Posted by MissZ06
kinda laggy huh?
i dont know, look pretty good to me!
Old May 30, 2007 | 08:26 AM
Jesse_Boyer's Avatar
Jesse_Boyer
gotta be his supra
Old May 30, 2007 | 10:42 AM
  #33
MissZ06's Avatar
MissZ06
Originally Posted by Jesse_Boyer
gotta be his supra
Yeah, i was just funnin with ya'll its tha supra. Man i am wantin a KB BAD now after seeing those TQ curves.
Old May 30, 2007 | 03:57 PM
  #34
Drewstein's Avatar
Drewstein
Here's two graphs over each other for you. It's my stock bottom end LS1 VS my 402 dyno comparison with the boost at 9psi for both.
I have since upped the boost to 12#s but no numbers yet.
Old May 30, 2007 | 10:29 PM
  #35
2010Vette's Avatar
2010Vette
From a recent LAPD thread on an APS setup. As usual, I will delete if they prefer.
http://forums.corvetteforum.com/show....php?t=1713477
Old Jun 2, 2007 | 03:40 AM
  #36
Freebs's Avatar
Freebs
no i dont mind :P thanks for posting it.. and thats whp... not crank
Old Jun 2, 2007 | 07:47 PM
  #37
c52k1vert's Avatar
c52k1vert
916/795 rwhp C5R 412 YSI
To Post Your Dyno Sheet Here
Old Jun 11, 2007 | 08:55 AM
  #38
2010Vette's Avatar
2010Vette
Default My LPE 427TT
Pump gas, 11.5 psi, through stock cats...
Old Jun 16, 2007 | 10:34 AM
  #39
vegasredz062's Avatar
vegasredz062
St. Jude Donor '08
402 APS TWIN TURBO 12 PSI
Old Jun 17, 2007 | 11:17 AM
  #40
AVB's Avatar
AVB
Finally got around to getting (too busy enjoying the car) the first complete dyno run.
Iron 408 8.7:1 compression with PTS/PTK twins (T66's)
Running 10.5 -11 lbs boost on 91 octane pump/no alky
Air/fuel was set to 11.6 and timing nice and conservative at 17.5*
Temp in the dynoroom 104 degrees
EFILive tuned courtesy of Robert@Advanceddyno..
At the same boost there is 25-50rwp more in this one for sure
Next session will have LS1 intake and heads replaced by an LS6/TrickFlow 225 or 235's combo.
[/QUOTE]
