Post Your Dyno Sheet Here
Old May 27, 2007 | 06:34 PM
2010Vette's Avatar
2010Vette
Default Post Your Dyno Sheet Here
I wanted to compare dyno sheets, and they aren't available in one place. Let's put something together that makes it easy for people to do comparisons on various setups.
What does a good dyno look like to you? High peak HP/TQ? Does it have a certain shape? Are you looking for a linear rise to the peak? Does it hold power well to redline? Post your dyno sheet here for comparison purposes, and post your setup and boost-level for the dyno.
(Mine is coming in a few days.)
Old May 27, 2007 | 09:29 PM
NemesisC5's Avatar
NemesisC5
Old May 28, 2007 | 02:05 AM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
LS2 403
AFR 225's
Kenne Bell 2.8H S/C @ 16psi.
Old May 28, 2007 | 02:19 AM
Beer99C5@FastbirdPerf.com's Avatar
St. Jude Donor '08
Some Stock LS1 Nitrous Graphs from Last year.
99 C-5 A-4 Vert Stock.
Borla Stingers and Blackwing Intake. Nitrous Outlet Wet Plate Kit
Stock Tune
50 Shot Wet
100 Shot Wet
150 Shot Wet
Two Stage Dry @ 50 and Wet @ 125
Here is what it looks like when your running out of injector (a mere 75 shot w/ 26 # injectors)
See the AFR go above 12
Last edited by Beer99C5@FastbirdPerf.com; May 28, 2007 at 04:07 AM. Reason: Added dyno running out of injector on 75 Dry Shot
Old May 28, 2007 | 03:17 AM
Third Gear's Avatar
Third Gear
I'll show you what one shouldn't look like. Maggie Non-Intercooled. 5psi. Full Exhaust. I couldn't exactly figure out why it's like that, but it's basically getting all new parts and upgrades.... so if it looks anything like that when I'm done I'll be temped to hydrolock it on the dyno.
The blue graph is mine. The red one belongs to muncie21, basically the same setup, but without headers.
BTW, I love zero smoothing. It shows you what's really going on.
Old May 28, 2007 | 06:50 AM
backchannel's Avatar
backchannel
Originally Posted by AMERICAN_HP
ha - how many gears can you spin the tires!!
Old May 28, 2007 | 07:40 AM
longdrive70's Avatar
longdrive70
Twin Turbo Coupe
Forged 346 TTiX 16lbs
Old May 28, 2007 | 08:11 AM
2010Vette's Avatar
2010Vette
Good start, great charts!
For those who haven't already, add your boost levels and setup.
Old May 28, 2007 | 08:47 AM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
Default Dyno Sheets
mike C-5
Old May 28, 2007 | 01:48 PM
Laguna Blu's Avatar
Laguna Blu
Okay.
Old May 28, 2007 | 02:02 PM
Pio's Avatar
Pio
Stock bottom LS7 C6Z, S-trim and LT's 607 / 552
03 Z with 413 L92 and a T-trim, tuned for 91 octane, no meth. 735 / 685
Old May 28, 2007 | 04:24 PM
BobJ's Avatar
BobJ
Old May 28, 2007 | 04:35 PM
NemesisC5's Avatar
NemesisC5
Originally Posted by BobJ
Man, looks like the KB's make so much torque that you can hardly take off from a light without spinning your tires Do they feel like TT's when driving ?...Your driving impressions please
Old May 28, 2007 | 06:00 PM
vrybad's Avatar
vrybad
APS TT
(the C6 kit I adapted to my car)
-stock 2002 C5 Z06
-about 9.5 psi
-93 octane
Old May 28, 2007 | 06:03 PM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
It feels like a 600+ci stroker.
I personaly think my car is more driveable now than when I had my 346 w/F1R. I dont like a ramping power curve. I prefer it be there when I put my foot down.
Old May 28, 2007 | 06:51 PM
2010Vette's Avatar
2010Vette
A power curve for a blower is an elevator trip straight to the top, with a slow descent. "Instant on" comes to mind.
The stock power curve is a 45-degree mountain climb that levels off. Consistent, predictable, increasing (but not that high).
Turbo power curves are of several kinds. Some mirror the stock curve (the ultimate in predictability and managability.) Some look like a half-circle (probably the next best.) And some look like a 30-degree ascent to base camp, then a 70-degree climb to the top once they spool. (Exciting, but a little unpredictable. In the vids, this is where the car loses traction, and likely a little control.)
All sound good except for the hockey-stick, lag-induced 30/70 power curve. Just not my personal preference, but to each his own.
Old May 28, 2007 | 07:36 PM
BobJ's Avatar
BobJ
I get the same feeling AMHP does, only x 50%....
The torque is instantaneous which is what I was shooting for. I rarely drive the car over 80 mph, but 0-80 sure is a blast!!
From a stop if you take the traction control off and mash it, you'll leave $100 worth of rubber in the intersection. It's easy to control though, you learn pretty quick how much you can give it before it starts spinning. Mine will definitely spin second (A4), not sure about third, I'm usually out of the gas by then....
To Post Your Dyno Sheet Here
Old May 28, 2007 | 09:37 PM
Slowhawk's Avatar
0Slowhawk
Former Vendor
first is a 346ci /F1 93octain car
second is a 408ci /T88 turbo 8,12,14lb graph on 100% 93 octain.
Old May 28, 2007 | 10:00 PM
Pio's Avatar
Pio
LS2 403
AFR 225's
I still have the Vette magazine where your car appeared on the cover. Simply AWESOME power. Congrats!
Out of curiosity, Vegas gets hot as hell in the Summer, what oil do you use?
Old May 29, 2007 | 01:33 AM
RED99's Avatar
RED99
LS2 403
AFR 225's
No downshifting that baby to pass.
