lets talk turbos
Old Jun 7, 2007 | 10:36 PM
NICK YOSKIN's Avatar
NICK YOSKIN
St. Jude Donor '08
Default lets talk turbos
lets talk about trims ar turbine wheels ect.....
here is a picture of two turbos that are of the same model except the turbine wheel in the one is a p trim and the other is turbonetic's new F1wheel. the exhaust housing are the same minus AR. look how much more the turbine wheel is recessed.
Old Jun 7, 2007 | 10:47 PM
longdrive70's Avatar
longdrive70
Twin Turbo Coupe
looks like the turbine wheel on the right definately has more surface area....vs actaully recessed.
Old Jun 7, 2007 | 11:23 PM
4DRUSH's Avatar
4DRUSH
Also looks like you already bought it
NICK YOSKIN
St. Jude Donor '08
the turbine wheel on the right is very aggresive. its much wider then the one on the left. an aggresive turbine wheel i would imagine would be flatter then on that has alot of pitch.
Old Jun 7, 2007 | 11:25 PM
NICK YOSKIN
St. Jude Donor '08
which turbo looks like it will produce more hp and why?
Old Jun 7, 2007 | 11:42 PM
longdrive70
Twin Turbo Coupe
still learning a lot over here but here's a stab...
It hard to determine....many variables...mass of & wheight of wheel? Are the pitches of the wheels similar, are they progressive or fixed? Is the progression comparable? Amount of blade overlap?
The one on the right definately seems more agressive..but without some of the above info it would be hard to say
From my jetski racing days I was amazed how much a few degrees with the right pitch progression made on thrust and overal pump efficiency. More overlap definately helped low end thrust but at the cost of top-end pump efficiency....I would assume the same characteristics here
Old Jun 8, 2007 | 12:22 AM
1%r's Avatar
1%r
St. Jude 15 Year Donor
St. Jude Donor '03 through '17
Simple
A. The one on the right will produce more.
B. It cost more money.
If I told you the real answer I'd have to have Lisa cook dinner again.
I know but you have to call me to find out if you already don't know.
Old Jun 8, 2007 | 01:02 AM
AVB's Avatar
AVB
The right one cause the left one is too small.
Old Jun 8, 2007 | 01:15 AM
LB's Avatar
LB
Looking at a picture doesn't tell much. You need to measure the wheel diameter and hight to get any sort of idea what you have sitting in front of you. That is only half the equasion as you need to know the pitch or degree of the wheel in comparison to the other etc etc etc. I would call up turbonetics and speak to their head tech
Are both turbine housings the same A/R ?
Old Jun 8, 2007 | 08:32 AM
Tomulrich's Avatar
Tomulrich
I think the one on the left looks like it would make more HP. I think you got sucked into the "F" wheel crap.
I would install the old units. I dont mine testing out the new units for you........plus the one on the right is way to big for your wimpy stock cubed motor!!!!!!!!!!!!!!!!!!
Tom
Old Jun 8, 2007 | 10:46 AM
LB's Avatar
LB
Tom
The charger on the right looks like the wheel is taller. Perhaps you might get some more specifics on these two turbine wheels before taking a shot in the dark. 346 is plenty of cubes to push these turbos, you just need a tuner who knows what hes doing.
Old Jun 8, 2007 | 02:15 PM
NICK YOSKIN
St. Jude Donor '08
Tom
not according to turbonetics the one on the left tom has beed around for 20yrs or so. the wheel on theright is turbonetics version of a garrett gt40 turbine wheel.
Old Jun 8, 2007 | 02:17 PM
NICK YOSKIN
St. Jude Donor '08
your absolutly right....
Old Jun 8, 2007 | 02:35 PM
NICK YOSKIN
St. Jude Donor '08
i really dont know what iam talking about:o :o :o
i started this tread cause i wanna learn...
ok...F1 isnt any specific turbine wheel its turbonetics new version of a turbine wheel. the wheel on the left is old school turbine wheel the on the left is the new style F1. the AR on the right is also .86 were as the the other is .68
Old Jun 8, 2007 | 07:03 PM
NICK YOSKIN
St. Jude Donor '08
the turbine wheel in the turbo on the right is capable of a
1000hp. the turbine in the other is aprox. 700hp.
this according to people @ turbonetics.
Old Jun 8, 2007 | 07:11 PM
LB's Avatar
LB
When you have alot of cubes, you can push the larger wheel and the greater flow potential will open up the top end enough for you to maxamize that compressor.
Old Jun 8, 2007 | 07:59 PM
NICK YOSKIN
St. Jude Donor '08
yeah i gotta alot of cubes.....347
To lets talk turbos
Old Jun 10, 2007 | 02:39 AM
AVB's Avatar
AVB
Old Jun 10, 2007 | 11:47 AM
Vindication's Avatar
Vindication
Is this a single turbo project?
Old Jun 10, 2007 | 07:05 PM
NICK YOSKIN
St. Jude Donor '08
no twins....
this should be one of the nastest irs street drivin C5 here.
