fuel system help
Old Jul 29, 2007 | 04:09 AM
jbsblownc5's Avatar
jbsblownc5
2017 C5 of the Year Finalist
St. Jude Donor '08
Originally Posted by AVB
The problem w/ regulating fuel at the filter is it doesn't regulate the pressure where you need it very well... at the rails. I would start by getting a return and regulator.
Arnel
Old Jul 29, 2007 | 06:26 AM
sultan 2 ZR1 KSA's Avatar
sultan 2 ZR1 KSA
Originally Posted by jbsblownc5
OK guys this is what i came up with after allot of thinking and dessication with some LS1 gurus here in my city
this is what i will do , please give me your feedback
1-cancel the standard fuel filter ( regulator )
2-install a hi capacity fuel filter
3-install one airomotive FPR non boost reference ( set at 60 PSI )
4-Fabricate a new return line from regulator to fuel pump sending unit at the tank
5-dual 255LB pumps one boost reference the other for standard driving
i think this should be all that i need to do to get the fueling i need
what do you think ???????????????????????????????????????? ?????
or
did i mess something els please help me out
Old Jul 29, 2007 | 10:08 AM
sultan 2 ZR1 KSA
^^^^^^any take on post above ^^^^^^^^^^^^^^^^^^^
Old Jul 29, 2007 | 10:27 AM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
Sounds like you're on the right track, but getting a fuel system right is not just about the parts -- it's about your execution/how you put it all together.
Please don't take this the wrong way... but while it's true that just about everyone in this forum is extremely helpful, I certainly wouldn't expect that people will give you all their fuel system secrets on day one, unless the secret is to go buy a fuel system package that worked for them.
Old Jul 29, 2007 | 11:19 AM
AVB's Avatar
AVB
Not too many have been able to "revise" the fuel system and get it right the first time. That's why many here are suggesting picking up a tried and true ECS setup.
Make sure you thoroughly understand the mechanism that transfers fuel between the two tanks or you'll be stranded on the side of the road.
Arnel
Old Jul 29, 2007 | 07:36 PM
sultan 2 ZR1 KSA
Arnel
i must say that is a very good point i tryed to avoid
evry thing is baseclky the same internally exept for the pumps
i think this is the rite way
please corect me if i am wrong
Old Jul 30, 2007 | 12:22 AM
AVB's Avatar
AVB
From the tank, the pressurized line (feeds rails) has a tee about 2 feet from point it exits the tank. If your second pump is before that and doesn't disturb it then you'll be in decent shape. Does this mean you won't have a problem? Unfortunately, some do and some don't..
You really should consider the ECS advantage... if there's a problem they'll work with you to get it right. If a pump is bad, you get a replacement.
Arnel
Old Jul 30, 2007 | 12:46 PM
sultan 2 ZR1 KSA
Arnel
hi Arnel
Please have a look at this link I have a small scematics of the setup tall me what you think
http://www.facebook.com/album.php?ai...3&id=601000729
Old Jul 30, 2007 | 12:56 PM
AVB's Avatar
AVB
hi Arnel
What is the dark gray area? That's where the venturi is which is critical in the transfer mechanism..
I'm a bit confused on the pump setup your considering... You really don't want to be re-engineering anything. Use the two options already mentioned.
Arnel
Old Jul 30, 2007 | 05:52 PM
sultan 2 ZR1 KSA
Arnel
the grye cercular thing is the opening in the tank with the hard lines
Old Jul 30, 2007 | 05:58 PM
sultan 2 ZR1 KSA
we only used the IN-OUT lines all is left untuched , it should be ready by tomorow
wish me luck
Old Jul 30, 2007 | 10:07 PM
leo12's Avatar
leo12
Originally Posted by BLOWNZO6
WOW UP TO 10000 RWHP!!!!
Please let us know how many ECS fuel systems you have personally installed.
I don't see the link you posted as a supporting vendor either...
i try not to install anything that has an external pump and sounds /vibrates like a bad muffler ...sorry..
as for his web go to LS1 forum his work is everywhere there and wont break your bank...
Old Jul 30, 2007 | 10:32 PM
  #33
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
Mine's perfectly quiet. Maybe I got one that was built by Loni?
BTW, the external pump thing is awesome, if I ever need more fuel or need to replace a pump I don't need to open up the fuel tank! It's just plug and play and done in less than an hour!
edit: I am not bashing Lonnie, just the general attitude of your post. BTW the double pumper kit on his site says $1535. I am not sure how $1535 doesn't break the bank but $1800 does, but to each his own.
Old Jul 31, 2007 | 03:59 AM
  #34
sultan 2 ZR1 KSA
updates
Old Jul 31, 2007 | 04:37 AM
  #35
sultan 2 ZR1 KSA
started it up it runs
Old Jul 31, 2007 | 04:49 AM
  #36
RJW's Avatar
RJW
From: Tinker till it blows... then back it off a notch, maybe!!
St. Jude Donor '08
Congrats...
Hope it stays running and solves your fuel problems.
So what did it cost you in total?
Old Jul 31, 2007 | 06:37 PM
  #37
sultan 2 ZR1 KSA
thank you guys for your support
i decided to boost reference instead just to be on the safe side
i took my baby out for a drive just naw did about 5 to 6 runs on the hi way started with stage 0 boost 12.4PSI man o man its the first i could punch it and not worry about fuel delivery , next i went into stage A 15.3PSI there was joy happens 4th gear became 3rd thin i went to the B setting 19.0PSI there was FEAR there was allot of bad words being said that i cant mention here 4th gear became 2nd and finally just for kicks i put it in 5th and let her rep cruising at 4000RPM and i punched it it spun the tires and OH god that was adrenaline with a capital A
I would advise any one that looking for big power to invest in a fuel system it is really worth it peace of mined and good moods
finally a gentleman asked me haw much did it cost me to do my setup
will here we go
1-280LB Sard Pump 300$
1-255LB walbrow pump 120$
1-Mallory FPR i think 102$
Pipping and fittings tie raps 150$
a total of 672$ max due to us having to import most of the stuff from out of the ****ry with 5% and some stuff 15%
Last edited by sultan 2 ZR1 KSA; Jul 31, 2007 at 07:35 PM. Reason: wrong calculation thanks RJW
To fuel system help
Old Jul 31, 2007 | 07:06 PM
  #38
RJW's Avatar
RJW
St. Jude Donor '08
Hooooonk....wrong answer....how about $672?...maybe?
It's a good thing you didn't go to the 'C' setting...you might not have found your way back....
which reminds me, I think I need to tweak my 'D' setting just a tad..
Joking of course...good job .. stay on top of it for a while and make sure everything stays good...
So much for lonnie....
btw; What are you going to do with all the money that you saved?
Old Jul 31, 2007 | 07:33 PM
  #39
sultan 2 ZR1 KSA
Default :cool:
i will start saving more for begir turbos
YOU GUYS ROCK
Old Jul 31, 2007 | 07:58 PM
  #40
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Originally Posted by BlownZR
The ECS has an external pump tapped into the drivers side gas tank. My car is an 2004 so I couldn't do an internal upgrade pump...
Which is where our set up works so well, the 04's are tough to beef up the fuel system and we have worked it out and have plenty of dyno and 9 second time slips with it to prove it.
thanks but I dought this would work for my 2002 vette becouse also i would like to retain the standard fuel filter ( REGULATOR )
Thanks any way
any more ?????
And you want to make how much power?....
or
Um... yup.
Arnel
Thanks Arnel
wish me luck
OK.... good luck....you'll need it.
You have never installed our system, but you know all about it and what it sounds like. Wow, what more can I say. We have sold this system to more people and shops because it is proven to work, and work as quietly as a 1000hp fuel system can, period. Especially if you boost reference it, then it is the same as a stock car.
Sorry Tony, I must admit to you that I went to a non supporting vendor for your fuel pump, you have the only quiet one.
Oh, ok then, we'll wait for your nine second time slips to show up soon.
Sorry to be so brash, but you have flaws in yours system and I would tell what they are.... but you can do the trail and error like we did and then figure out why things cost they way they do.
