i cant seem to keep a constan fuel presure on my car evry time i start getin on it i end up with 2bar of fuel presure at about 5000RPM redline at 6800RPM
i have done evry thing BOOST A PUMP( start at 7PSI) 255LB HOTWIRE 60LB injectors i heve thim all on my car O yah new filter also
i am only running 12.8PSI of boost and the fuel system is not keeping up
can someone help me and show or show me what i am doing wrong
or advise me on what fuel system should i buy that will hold up my cars demand
thanks
Ok, I know exactly what you are going through! ! ! I was there last year...........I will PM you my number and we can talk about it! !
I have ECS Fuel System and I have no issues! ! My car is a 383 Stroker with A&A Kit, I am making 13 Lbs. of Boost and my fuel pressure is 60+ Lbs. My internal pump runs all the time but the external pump is only used when the car goes under boost! ! I have not seen under 60Lbs. since last year! !
I'm sort of in the same boat. I am seeing 135% duty cycle on 45 lb. inj. with 50 psi of fuel pressure with Andy's kit on the stock bottom end. I have a boost-a-pump as well and I'm thinking of going to a 383 soon and turning the boost up! I'm a little worried. What are your thoughts guys?
thanks
Lonis duble pumper with awsone wirring harness..plug and play it will feed anything up to 10000 RWHP..and the great thing is its only around $550.00..anlike most others like ECS,,where they want ridigulous money and they are nothing but problems...
lonis performance.com
-it's simple and neat and my injector duty cycle was only 65% last time out!
any good ideas???????????????????????????????????/
I have the ECS fuel system with a hobbs 1psi pressure switch (purchased from Coolmist . com)...At idle I'm at 55psi and once I hit boost I hit 60psi all the way through 10psi. Without the Hobbs switch the external pump runs on ignition switch and in 100* weather the fuel pump was dying due to captivation.
did u use the buckit for the dual pump stup or u did likr the f-body gys and did not bother your self with it
ECS fuel system here. The kit just works. It's a little pricey but there are plenty of users out there with the kit not having issues at varying levels of power (including plenty of 700+ and 800+ cars).
Not saying it's the only solution, but if you just want to get something that you know will work -- the ECS kit will get you there. If you want to spend some time tinkering you could probably save a few bucks.
WOW UP TO 10000 RWHP!!!!
Please let us know how many ECS fuel systems you have personally installed.
I don't see the link you posted as a supporting vendor either...
thanks but I dought this would work for my 2002 vette becouse also i would like to retain the standard fuel filter ( REGULATOR )
Thanks any way
any more ?????
The problem w/ regulating fuel at the filter is it doesn't regulate the pressure where you need it very well... at the rails. I would start by getting a return and regulator.
