IAT sensor...
Old Aug 22, 2007 | 11:03 PM
Vince99FRC's Avatar
Vince99FRC
Default IAT sensor...
Where are you ECS Meth Kit guys installing the IAT sensor? I am having a hard time getting my IAT's under control. I turn up the meth and my air/fuel gets richer, but my IAT's continue to climb..
Old Aug 22, 2007 | 11:24 PM
longdrive70's Avatar
longdrive70
Twin Turbo Coupe
I am have relocated the IAT so that I am spraying alky after the MAF and before the IAT. I usually see a 20 - 25* swing in my IAT once the Alky kicks in. I also adjusted my IAT/timing table to pull lot's of timing if my IAT goes above 100* F in case my Alky fails
Old Aug 22, 2007 | 11:34 PM
Vince99FRC's Avatar
Vince99FRC
I also spray Meth after the MAF and b4 the IAT. My IAT sensor is in my air bridge....
Old Aug 23, 2007 | 11:37 AM
Vince99FRC's Avatar
Vince99FRC
ECS are you out there? Where do you usually install your meth nozzles compared to the IAT sensor? Per you guys I am suppose to see my IAT's go lower than ambient. That is not the case with my dual nozzle setup.
Old Aug 23, 2007 | 12:21 PM
longdrive70
Twin Turbo Coupe
Somethings is definately not right if you are spraying before the IAT and your temps are not dropping. What is your gain set on? I usually do not see any significant IAT drop untill I reach 5 on the gain control. Also, how much space do you have between the nozzles and the IAT. I suppose if they were too close the IAT may not be in the alky path.
The guys at ECS are probably at Carlisle by now....
Old Aug 23, 2007 | 12:56 PM
NICK YOSKIN's Avatar
NICK YOSKIN
St. Jude Donor '08
Old Aug 23, 2007 | 01:37 PM
Vince99FRC's Avatar
Vince99FRC
I did not install the kit. I will ask the tuner.
To IAT sensor...
