gotta problem...
Old Oct 31, 2007 | 09:45 AM
LB's Avatar
LB
WooWee 66mm !
1000 should be a breeze @ 20psi.
Old Oct 31, 2007 | 10:06 AM
Apipe's Avatar
Apipe
I would say an honest 300RW for the boost and 500RW for the engine puts u at 800RW.....Threw an A4 that is some serious power
Joel
Old Oct 31, 2007 | 02:33 PM
Skunkworks's Avatar
Skunkworks
Good luck... thinking 800-850 but not sure on pushing it to 20 psi. I'd dump some race gas in if your seriously considering 20 psi.
Mike
Old Oct 31, 2007 | 02:39 PM
JZ 97 SS 1500's Avatar
JZ 97 SS 1500
Nick with the turbos we got for you, their is no reason it should not make over 1000rwhp with the auto. All will come down to the tune and whether the heads will stay put.
Whenever your done with those turbos, we have the new ones ready with ETT
Old Oct 31, 2007 | 02:56 PM
SpeedyD's Avatar
SpeedyD
I can't beleive some of the people posting 800 or 800 and change. It made that on the 346 at 18 psi., Nick if it doesn't hit the 1000RW I'd be super surprised!!! I'm sticking with my 1072 and wouldn't be shocked to see more! That thing is going to be an absoute monster!
Old Oct 31, 2007 | 03:32 PM
NICK YOSKIN's Avatar
NICK YOSKIN
St. Jude Donor '08
send them...
Old Oct 31, 2007 | 03:33 PM
NICK YOSKIN
St. Jude Donor '08
Mike
being an insurance man i think that race gas would be a very cheap insurance policy!
Old Oct 31, 2007 | 11:04 PM
NassauBlue98's Avatar
NassauBlue98
Originally Posted by NICK YOSKIN
[IMG][/IMG]
Post a log showing gm/cyl.... I want one with over 2 gm/cyl for my desktop!
Bring a lot of weight with you to the dyno... I bet you're going to have a hard time strapping it down tight enough to keep it from spinning...
Old Oct 31, 2007 | 11:24 PM
1%r's Avatar
1%r
St. Jude 15 Year Donor
St. Jude Donor '03 through '17
Where's my phone call back?
Playing with the trick or treaters too much?
Old Oct 31, 2007 | 11:40 PM
Vince99FRC's Avatar
Vince99FRC
I personally dont see the need to go past 800rwhp unless you have a raceweight of over 3600lbs. 800rwhp has propelled Supras to low 9's and high 8's in auto cars...
Old Oct 31, 2007 | 11:56 PM
vegasredz062's Avatar
vegasredz062
St. Jude Donor '08
well after you posted the viper running 9.8x at 158.00 on 20 inch rims.. maybe there is room for 1000 rwhp on a c5 ..i think NIck will HAVE TO get a boost controller like the ones heffner uses .. i think its speed related.. at 60 you can only make 9 psi or something like that..
here is a link : click on the boost controller in action
http://www.heffnersperformance.com/videos.htm
Old Nov 1, 2007 | 12:38 AM
Vince99FRC's Avatar
Vince99FRC
We have options, but as of now there is no AEM for the C5.
Old Nov 1, 2007 | 01:34 AM
  #33
RED99's Avatar
RED99
1067.5 RWHP @ 20psi.
Old Nov 1, 2007 | 01:58 AM
  #34
master blaster's Avatar
master blaster
Originally Posted by Chris Stewart
Yeah I tested the limits the other day it was about 40 degrees, and romped it from 65mph as soon as I hit boost = sideways. I think anything under 70 degrees on Nittos it's useless, and around 40 degrees forget it!
I found nitto drag radials for the street to be good until 55 outside
Old Nov 1, 2007 | 11:34 AM
  #35
vegasredz062
St. Jude Donor '08
When temps drop to 55 i could not hook my car when i was NA putting down 417 rwhp... 430trq.. (in first and second).. so 800+ in not happening in the winter... now whne its 110 outside here in vegas.. i can hook in first with 650..
Old Nov 1, 2007 | 11:44 AM
  #36
Shinobi'sZ's Avatar
Shinobi'sZ
When I talked to AEM 3 years ago they do have an option...but it involves using the mechanical TB which I wasn't willing to do, so in that respect they truly don't have a C5 option but they have one that would work on a C5. They have a couple of applications where they are using AEM piggy backs on some trucks.
Nick,
All that I have to say buddy is that you better make more HP then me! I will give you a break too if your tq is close to your hp given that you have a tq converter...but if you post up something like 850/1000 hp/tq.....it will be dissappoiting.
Seriously though (hp #s aside) it will be nice to check out your tune on the dyno...and be able to make whatever adjustments you need to optimize the setup.
Have fun playing around.
Please remember the graph below is lower then the one from A&As party.
Old Nov 1, 2007 | 01:16 PM
  #37
onfire's Avatar
onfire
hey lb....
yeah 427 approx 9.0:1 trick flow heas from TEA inconel valves, cam motions 234 231 59X turbos are turbonetics E cover w/66 compressor, .81 AR with F1 turbine. this thing pulls WAY harder then last set up..not even close!
[IMG][/IMG]
I hope you're using a box and 96lb injectors (and a great pump(s))....you have enough turbo(s) and cubes to "blow" past 1000rwhp if you have enough fuel.
To gotta problem...
Old Nov 1, 2007 | 01:24 PM
  #38
NICK YOSKIN
St. Jude Donor '08
Nick,
hey what did alterstart say?
twin intank 255 and one external 255 activated by hobb. yeas 96'ers with driver box.
Old Nov 1, 2007 | 01:45 PM
  #39
AVB's Avatar
AVB
did you notice the race unit voltages?
Old Nov 1, 2007 | 02:13 PM
  #40
NICK YOSKIN
St. Jude Donor '08
whats up with u'rs?
i noticed a nice bump w/smaller pullie...it gets up to 13.5 13.8 quicker for sure...granted at night with all blasting @ a stop its 12.6 but once i move the slightest its up in the 13's
