LS9 pics
Old Nov 27, 2007 | 12:03 AM
Z06PSI's Avatar
Z06PSI
St. Jude Donor '17-'18-'19
Default LS9 pics
Don't know how many visit 2 sections down but here.
http://forums.corvetteforum.com/forumdisplay.php?f=49
Old Nov 27, 2007 | 01:38 AM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
I just dont get it...I thought everyone said twin screws weren't efficient..
I also heard a birdie tell me that there was a twin screw company that had offered a little "Help" in this arena, and that when this comes out there will be a fairly LARGE internal upgrade avail..
Old Nov 27, 2007 | 01:55 AM
Z06PSI's Avatar
Z06PSI
Old Nov 27, 2007 | 07:23 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Originally Posted by redrumss aka Z06PSI
Not bad already coming with a SuperCharger!
As for the intercoolers! We'll see if heat soak is a problem with it!
Now we all need the specs and if it will bolt into a C5
Thanks,Matt
Old Nov 27, 2007 | 07:50 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
I assume that the engine internals have been forged ?
If so this would make a nice bolt in replacement, when the old power plant gives out.
Old Nov 27, 2007 | 07:59 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
Looks really nice and looking forward to some performance and wether there is heat soak or not
Old Nov 27, 2007 | 08:18 AM
LRD VDR's Avatar
LRD VDR
Very nice....Love the compactness.
Shahram
Old Nov 27, 2007 | 09:31 AM
RoadRebel's Avatar
RoadRebel
Haha, thats a good one!
Why would they bother doing that when its make like 100hp less than any other bolt on in this forum on a stock motor.
Phil
Old Nov 27, 2007 | 10:00 AM
RED99's Avatar
RED99
I see they made a visual improvement over the first design. This looks a little better.
Old Nov 27, 2007 | 10:18 AM
Baldturbofreak's Avatar
Baldturbofreak
Phil
It's all about duty cycle. The general has to build it for 100% duty cycle @ rated power.
None of our stockers would survive the 200/400 hour durability test at that power. There isnt enough meat in the piston crown, and there are no means of removing the additional heat input (piston oil squirters and hollow dome salt cast piston like my turbo LNF motor).
I would expect a steel crank, great rods, and a hollow dome saltcast piston with the same kind of piston oil squirter system thats in the ecotec.
Cast pipstons are alright in some respects. Ive never had one break and F anything other than itself. Ive had forgies come a knockin thru the sleeve
what im really suprosed to see is that they have conventional (looks like garrett "1000hp" WIC cores) cores inthere instead of the Laminova extrusions that they have used in the blown northstar/ecotec.
Perhaps they couldnt fit enough tubes in there to get 65lbs/min thru there with a satisfactory pressure drop?
Old Nov 27, 2007 | 11:51 AM
Vette Stripes's Avatar
0Vette Stripes
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08
Phil
I think they may need that because GM now got 5 or 7 years power train warranty (I forgot)?
Old Nov 27, 2007 | 11:56 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Phil
Oh well it was just a passsing thought. Not sure what the power rating is on that motor but it would be nice if GM would build motors comparable to the others out there.
Old Nov 27, 2007 | 12:54 PM
Z06PSI's Avatar
Z06PSI
Supposed to be 650fwhp. All rumors though.
Old Nov 27, 2007 | 03:44 PM
m90daytona's Avatar
m90daytona
wow, if it makes that much fwhp, imagine how much rwhp it will have!
Old Nov 27, 2007 | 03:51 PM
_Will_'s Avatar
_Will_
From: Somewhere between mild insanity and complete psychosis
They'd be morons not to build a top notch forged bottom end for the zr1.
Countless buyers will simply pulley down much like the Cobra crowd. Motor pops because it isn't forged, swap back the original pulley and leave GM with the rebuild cost under warranty. They'll save themselves $$$ by spending a couple hundred bucks extra per car for quality pistons and rods.
I don't think tacking it on to the final retail $ will hurt sales, this is going to be a limited production expensive car to begin with. Anyone who wants to spend six figures on one won't blink at a few hundred extra. This is a designer car made for the "look at me" crowd who don't care about spending extra $$$. Anyone who cares about price would be able to build a base c6 to more power with their own blower and a forged short block, put aside $$$ for multiple rebuilds, and still have cash leftover compared to a zr1.
Old Nov 27, 2007 | 04:32 PM
Boob's Avatar
Boob
This twin screw should be a part in the GMPP catalog shouldn't it? Anyone have any idea on the cost? I see lots of potential for the supercharger setup for the lsx community.
Edit: Props to the GM engineers. Looks like a nice setup esp when you consider it's a production package.
Old Nov 27, 2007 | 08:12 PM
tlaselva's Avatar
tlaselva
Do you honestly think they'd leave that avenue open for people to screw them with? Give your head a shake.
It's a simple matter to add a computer data recorder to keep track of rpm and psi readings.
BMW has them on their M cars for years. There are several documented cases of M3 owners being denied warranty work on motors because they were able to prove neglect with the data recorder.
GM's not exactly cutting edge technology, but it's just a matter of time before they do too.
To LS9 pics
Old Nov 27, 2007 | 09:26 PM
Baldturbofreak
like the "event recorder" that tracks how many times it's been flashed.
Old Nov 27, 2007 | 09:55 PM
Skunkworks's Avatar
Skunkworks
Thanks,Matt
Well I see the C6 supercharger market just changed. Looks like a 12-rib belt from the factory... With that I wonder how much steering rack was shifted and how without effecting steering.
The belt arrangement looks great. This the best PD supercharger I have seen from the big 3.
Now as far as performance time will tell. The A2W intercoolers do look smallish but who knows what alloy it is?
Mike
Old Nov 27, 2007 | 10:04 PM
NICK YOSKIN's Avatar
NICK YOSKIN
St. Jude Donor '08
yeah the new 335 bmw monitors boost targets, if they are not within predetermined ranges then the gates open and the car goes into reduced engine power.
w/that being said i am sure that GM thought of something....
wow bmw guys blowing motors up????
