torque tube question- help me debug
Old Jan 21, 2008 | 10:11 AM
ICULUKN-C5's Avatar
ICULUKN-C5
Default torque tube question- help me debug
I am hearing a whine from just north of my shifter.
Its louder in 6th gear than 1st, at the same RPM.
There is no shake or vibrations in the shifter
For lack of a better description, it sounds like a ground loop on a bad stereo installation (mine is still stock)
I have a RPM level 5 transmission, and its working flawlessly.
I was thinking its probably a bearing in the torque tube.....
What do you think?
My next questions is......
Since there isnt any one that can press bearings into a torque tube around me... Is it cheaper to just buy a new one?
Old Jan 21, 2008 | 10:23 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
What do you think?
Send it out to RPM to be repaired. They sell the parts.
Old Jan 21, 2008 | 11:21 AM
ICULUKN-C5's Avatar
ICULUKN-C5
So.. you think it would be cheaper to ship a torque tube to RPM than to by a new one from the dealer?
Old Jan 21, 2008 | 12:50 PM
BLOWNZO6's Avatar
BLOWNZO6
Premium Supporting Vendor
Get in touch with RPM.
It is not that expensive to ship one to them.
Another tube will cost you over $500 used.
The last one that they redid for me, was much less than that, shipping included.
__________________
EAST COAST SUPERCHARGING SALES AND TECH SUPPORT
WWW.EASTCOASTSUPERCHARGING.COM
Old Jan 21, 2008 | 01:35 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Dealer want $1,650.
Old Jan 21, 2008 | 03:50 PM
NICK YOSKIN's Avatar
NICK YOSKIN
St. Jude Donor '08
Old Jan 21, 2008 | 06:38 PM
ICULUKN-C5's Avatar
ICULUKN-C5
That is cheap... RPM told me the bearings were $395.00 alone.
I cant image it would be under cheap to send a torque tube from AZ.
its it a ton of labor to press new bearings?
What is preventing a shop from doing it locally?
Glenn
Old Jan 21, 2008 | 08:43 PM
Slowhawk's Avatar
0Slowhawk
Former Vendor
Here is pics of 2 torque tubes. The first one the coupling started to fall apart till it went to dust.This wrecked the torque tube by cutting holes in it. The second is the bolts ripped out of the tube completely,somehow the customer still drove it over 100 miles to me this way.From the same car 1 year later.
I'm having ECS built me a new shaft with u-joint's instead of those crappy couplers.
Old Jan 21, 2008 | 09:28 PM
BLOWNZO6's Avatar
BLOWNZO6
Not calling you a liar, but I think you are mistaken here.
Old Jan 21, 2008 | 09:35 PM
ICULUKN-C5's Avatar
ICULUKN-C5
Maybe I heard TJ wrong... but he told me a rebuild kit was 395.00...
Maybe RPM can jump in here to clarify..
What is needed to convert to a u-joint set up.
Old Jan 21, 2008 | 09:36 PM
BLOWNZO6's Avatar
BLOWNZO6
That might be right, I am not sure what is included.
If you need the couplers too, they are not cheap.
Old Jan 21, 2008 | 09:45 PM
easyvette's Avatar
easyvette
http://forums.corvetteforum.com/show....php?t=1893580
BINGO
Old Jan 22, 2008 | 07:11 AM
BLOWNZO6's Avatar
BLOWNZO6
Originally Posted by easyvette
There you go... that makes sense.
Couplers and all.
Old Jan 24, 2008 | 06:27 AM
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
My upgrade to those have been fine on the strip & road course
To torque tube question- help me debug
