Is 61.4 psi fuel pressure at idle normal?
Old 07-07-2008, 10:07 PM
01vetter
01vetter's Avatar
Default Is 61.4 psi fuel pressure at idle normal?
I just installed a SPA duel boost/pressure gauge and it reads 61.4 psi fuel pressure at idle with stock injectors and fuel pump (I think, I am the second owner). I thought that 58 psi was normal. Fuel filter was changed about 9k miles ago. Is 61.4 psi in the normal range?
Old 07-08-2008, 03:08 AM
JustinStrife
JustinStrife's Avatar
I have 60lb injectors with a Lingenfelter fuel pump, and see 61ish at idle. I've never seen the needle get below 60 infact.
Old 07-09-2008, 07:43 PM
LRD VDR
LRD VDR's Avatar
Also..I'm sure there is a marginal error from gauge to gauge.
Shahram
Old 07-09-2008, 09:13 PM
JustinStrife
Shahram
I'd believe it. Just for informational purposes, I run a Cobalt FPG.
Old 07-29-2008, 04:40 PM
XtremeVette
NCM Bash 2008-2018
Support Corvetteforum!
XtremeVette's Avatar
Location: Granby, MA Talladega Super Speedway Vettes 4 Vets Ambassador
Middle TN Events Coordinator
Cruise-In 1, 3, 9. 10 & 11 Veteran
Default so for stock
Ok so for stock is 60 the normal no matter what you doing? I have noticed that when I get on mine and go WOT, I lose maybe a pound of pressure. The needle slightly dips down. Soon as Iam off it, it returns to around 60. Sound normal? I too run a Cobalt Gauge but with stock injectors and fuel pump. Never changed out the filter nor do I know if the previous owner did. Car has 73,000 on it. Seems to run fine.
To Is 61.4 psi fuel pressure at idle normal?
Quick Reply: Is 61.4 psi fuel pressure at idle normal?
