APS Guys
A little off topic but the way the BOV's are routed back into the system (bypass), can i disconnect it so it blows off into the atmosphere to get some sound out of them? From what I understand, its not a problem since its before the MAF but I want to confirm it before I risk blowing something.
As for the pancake pipes......my car is lowered as far as it will go on the stock bolts, no bushings were cut or anything. I've got a couple of small scrapes on my pancake pipes, but I've been VERY cautious when I'm out and about with the car. Still one thing I really want to get rid of though.
There is just not a lot of room on these cars.
Case in point, look at the kits to come out after the C5 kit was released. Note the distinct lack of a majority of the inlet being non-hard tubes and a VERY notable lack of pancake pipes on the inlet side of things.
C6 ZO6:
GTO and G8 (so similar I used the same pic):
F-Body Standard and Extreme Kits:
Seems they learned their lesson with the C6 and C5 kits, then abandoned them with the newer stuff not bothering to support the previous buyers. I have emailed and PM'd Peter @ APS on MULTIPLE occasions concerning the purchase of a set of 70mm Inlet Tubes for my car, and my last response from him was, and I quote directly from a PM:
Sorry that I could not assist you,
Cheers,
Peter
That being said, I have a friend who's a fabricator. I'm in contact with him now, and I want to query the APS guys here on the forum. Would you guys be interested in a non-recirculating (air vented BOV setup) inlet setup for teh APS systems if I could do it with hard inlet tubes, a properly sized filter, and do it for around $300ish a set give or take (just a number to toss out really, I'd be surprised if it was that much). As soon as I get my car back I'm going to pop some panels off and start getting this worked on.
C6 ZO6:
Seems that they've made their money and are content with that.
All the other cars you mentioned have much more room to run piping than the vette.
The C6 Z06 kit is supposed to be a higher-effort kit, so APS reversed the charge and inlet pipes to account for the greater airflow of the 427.
That is actually your best solution, to create piping to mimic the C6 Z06 inlet pipes, and the use of the pancakes for the charge pipes.
It could be done fairly easy that way, with some moderate fab work.
I am going to tr to take it slow once I get my kit in my hands and just see what I/we can come up with
APS is well aware of the issues, but they're NOT stepping up to the plate. Admittedly, I'm a bit peeved at them, especially the brush off I got from Peter after being the first guy to actually receive their TT kit for the C5's here in the states, jumping on board like I did.
As soon as I get my car back home I'm going to pull the front panels off and have a look. I've been studying pictures all day of how the car looks with the fenders off and think there might be some room in there, but I'm very concerned about space on the passenger side with the PCM where it is.
I thought about getting in touch with APS to see if they would sell just the cast inlet pipes from the C6Z kit, but I imagine they will be expensive.
I don't doubt they are avoiding a complete retrofit for all the C5/C6 kits because of expense.
I'm sure they don't want to eat that cost, and then you have the fact that Cartek was able to get big power out of the C5 kit, so there is some data to suggest APS has supplied the kit in as-advertised form with the numbers to back it up.
I'm certainly no apologist for APS, just touching on some reasons why they may not feel compelled to forcefully pursue the issue.
You are basically left to your own ingenuity on this one.
I'm sure you'll figure something out.
I am however going to get in there and see if you can't relocate the PCM slightly from it's factory location to give a little more room for an air filter setup.
