Altenator Relocation
Old Mar 10, 2009 | 09:23 PM
wilson34's Avatar
wilson34
Default Altenator Relocation
Is it possible to use the Fbody bracket to relocate the altenator to the lower driver side of the block? Would it require switching to the power steering setup of the Fbody cars?
Old Mar 10, 2009 | 09:27 PM
breecher_7's Avatar
breecher_7
Unsure what would all have to be switched around but I do know that if you have a IRON block the F-Body mounts will not bolt up to the drivers side correctly. Only two of the 4 holes are there on the irons, one of them can be drilled and tapped leaving you with 3 of the 4....
Old Mar 10, 2009 | 09:42 PM
wilson34's Avatar
wilson34
I was looking at Gorrillavettes build, the one with the twin turbos and lsx, and he has the altenator mocked up in the Fbod location Ill probably ask him what he is doing for it.
Old Mar 10, 2009 | 09:51 PM
NICK YOSKIN's Avatar
NICK YOSKIN
St. Jude Donor '08
the "box" on the steering rack will not allow fitment.
Old Mar 10, 2009 | 10:21 PM
wilson34's Avatar
wilson34
I figured there was something more to it or else I woulda seen it done that way by others.
To Altenator Relocation
