Belt preference
Old Apr 15, 2009 | 04:25 PM
optimum01's Avatar
optimum01
Default Belt preference
After running a gates green strip 8rib for quite a few years,I am about to try the Goodyear Gatorback on a few recommendations.Is that the CF belt of choice with procharger D1?Any input is appreciated.
Old Apr 15, 2009 | 05:55 PM
chriswtx's Avatar
chriswtx
Old Apr 15, 2009 | 07:41 PM
95vettski's Avatar
95vettski
Dayco or Goodyear
I'm using this one http://www.daycoproducts.com/DaycoWe...y_Cog!OpenForm
Old Apr 15, 2009 | 08:27 PM
tail_lights's Avatar
tail_lights
Old Apr 15, 2009 | 09:09 PM
MotleyDrew's Avatar
MotleyDrew
I am a big fan of the Goodyear belts. They have a little more give to them which I like and are quiet !!!!
Old Apr 15, 2009 | 09:14 PM
Arun@ChampionMotors's Avatar
0Arun@ChampionMotors
Former Vendor
Originally Posted by 95vettski
Dayco or Goodyear
16 psi at 6000 grand with no signs of giving up!
Old Apr 15, 2009 | 10:03 PM
TRIZ's Avatar
TRIZ
Dayco or Goodyear
For an FI application the poly cog is not the best choice.
This is just my opinion only.
Here's my reasoning:
The gaps between the cogs will increase slip (belt rib material is deleted).
In an FI application you want all the ribs in the belt to engage into the pulleys.
Max engagement or contact between the belt and pulley is the objective, right?
Poly Cog is intentionally designed with part of the ribs in the belt missing.
Old Apr 15, 2009 | 11:49 PM
Double G's Avatar
Double G
Default Another 2 cents.
I think the idea with a cog belt is it wraps around a mid/small pully without compressing the ID of the belt thus giving it a softer better bite than the compressed hard surface of the non cog belt that has a tendency to slip, glaze, and squeal. Cog belts also run cooler. Older piston ac compressors created a lot of load on the "double belt" systems. The cog belt always fixted the problem. Remember that as the cog belt wraps around a pully the less the cog gap becomes. Just another way of looking at it.
Old Apr 15, 2009 | 11:56 PM
nmp27's Avatar
nmp27
gates heavy duty green belt here, been working like a charm for a long time
Old Apr 16, 2009 | 12:32 AM
bullitt4110's Avatar
bullitt4110
Im running the goodyear gatorback, dont have much time on it so cant tell you how good they are yet.
Old Apr 16, 2009 | 11:42 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
They only make a small number of HD belts. I'm using the 8-rib 903. Working great so far. Holding 18psi with no belt slip.
Old Apr 16, 2009 | 12:07 PM
excessive81's Avatar
excessive81
i like the gator back. been using for 3 years. but looking to get a green just for comparison sake
Old Apr 16, 2009 | 12:09 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Don't have a D1 but it's been either Dayco or gates for me with no probs
Thanks,Matt
Old Apr 16, 2009 | 12:44 PM
Former Vendor
That's what conventional wisdom would say-but how can you argue with the Renegade Mustang class where racers make 30+ psi of boost and run low 8's over 160 mph with a curb weight of 3500lbs and cubes as small as 302's.
EVERY racer in that class is limited to a 8 rib belt and they ALL run the Dayco Polycog belt.
Now from my own testing-whenever a Gates belt has slipped, a switch over to a Dayco or Goodyear fixed that-right away.
Old Apr 16, 2009 | 01:20 PM
BLOWNBLUEZ06
The way I understand it, the poly cog prevents air from being trapped between the belt and pulley, kinda like the Reichart pulleys, but from the belt perspective.
Old Apr 16, 2009 | 01:27 PM
95vettski's Avatar
95vettski
Exactly!
Old Apr 16, 2009 | 03:01 PM
chriswtx's Avatar
chriswtx
Where do you buy the Dayco Polycog belts from?
To Belt preference
Old Apr 16, 2009 | 03:30 PM
optimum01's Avatar
optimum01
Looks like the polycogs have it won.
Old Apr 16, 2009 | 04:53 PM
tail_lights
Old Apr 16, 2009 | 05:01 PM
felo357's Avatar
felo357
How often shoul i change my belt? I have SC600 from ECS @ 9psi.
Do u guys change them yearly?
Do I need the aligment tool too to change the belt.
