Methonal color
Old Jul 25, 2010 | 06:07 PM
Ronnie_W's Avatar
Ronnie_W
Default Methonal color
I just bought a five gallon can of methonal. It is 99.9% methonal and is clear in color. The last methonal i used, I got from a friend that was already mixed 50/50 and had a greenish color. What should the color be?
Old Jul 25, 2010 | 06:25 PM
HotRod68Camaro's Avatar
HotRod68Camaro
It should be clear
Old Jul 25, 2010 | 06:49 PM
corvette8189's Avatar
corvette8189
it will be clear, 50/50 was probally winshield washer fluid which comes in green and blue color
Old Jul 25, 2010 | 07:06 PM
black98c5's Avatar
black98c5
Mine is clear (M1).
Old Jul 25, 2010 | 07:20 PM
rclinton's Avatar
rclinton
Veteran: Marine Corps
I would like to add a Meth kit to my V-2 kit for safety reasons only(cooler IAT). My tuner recommended windshield washer fluid. Is this an acceptable fluid and any specific brand names to use?
Old Jul 25, 2010 | 07:25 PM
tail_lights's Avatar
tail_lights
Old Jul 25, 2010 | 07:51 PM
Ronnie_W's Avatar
Ronnie_W
Thanks guys!
Old Jul 25, 2010 | 07:54 PM
user_name's Avatar
user_name
The green stuff was prob boost juice.
Old Jul 25, 2010 | 11:11 PM
cobill1972's Avatar
cobill1972
The Snow "boost juice" that I have is sort of a redish color.
Old Jul 25, 2010 | 11:16 PM
a/c man's Avatar
a/c man
if you run out of meth and you run 100% would it be safe to run washer fluid if you cant get it till monday
Old Jul 26, 2010 | 12:58 AM
felo357's Avatar
felo357
Clear 100% M1 thats the way to go forget the 50/50 mix go all the way 100%
Old Jul 26, 2010 | 12:59 AM
felo357's Avatar
felo357
is safer to stay out the boost
Old Jul 26, 2010 | 03:06 AM
HotRod68Camaro
Old Jul 26, 2010 | 07:42 AM
Its Bruce's Avatar
Its Bruce
It looks like water but tastes different...
Old Jul 26, 2010 | 08:07 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
that's what she said?
jk jk
Old Jul 26, 2010 | 10:16 AM
user_name's Avatar
user_name
Not even a little...
Old Jul 26, 2010 | 10:29 AM
Blow Torch's Avatar
Blow Torch
Cool
Just swapped out my old injection system for a Alkycontrol kit to run 100% meth. My "source" stood me up Friday so I have none until next weekend Just stayed out of boost Sunday
You wouldn't BELIEVE all the guys that tell me I'm going to "burn up" my car when the stuff leaks and catches on fire and and the flame is INVISABLE
To Methonal color
Old Jul 26, 2010 | 10:30 AM
cobill1972's Avatar
cobill1972
I have heard one bottle of carquest washerfluid and adding two small bottles of heat product will give you the right formula. However I'm not a chemist and just play it safe and buy the "boost juice". I'm not sure if I would run straight meth. I have heard the 49/51 mix uses the meth for the octane and the water for the cooling properties.
Bill
Old Jul 26, 2010 | 11:42 AM
thekid96's Avatar
thekid96
Ya, it happens...if you are using the ww tank make sure you take measures to seal the cap. They will leak in the rear under hard acceleration/launch and you can guess what happens next.
Originally Posted by Blow Torch
Cool
Old Jul 26, 2010 | 12:43 PM
Blow Torch's Avatar
Blow Torch
NOW I feel better....
