Meth injection for Vortech setup?
Old Feb 11, 2011 | 06:46 PM
TheRadioFlyer's Avatar
TheRadioFlyer
Supporting Vendor
Default Meth injection for Vortech setup?
I'm considering a Meth setup for my Vortech centri setup (pic below for reference)
My questions:
1) where would be the best place for the injector?....Halo setup?
2) What all is involved with a meth setup.
I'd like to use my washer fluid tank to make the installation easy plus I'll have a DIC notification when i get low.
Old Feb 11, 2011 | 07:08 PM
corvette8189's Avatar
corvette8189
ecs/julio alky control kit
Old Feb 11, 2011 | 07:09 PM
Slow Z06's Avatar
Slow Z06
Old Feb 11, 2011 | 10:42 PM
Todd157k's Avatar
Todd157k
Banned Scam/Spammer
Originally Posted by theradioflyer
My questions:
1. In the blue hose piece as far as distance however you need something you can screw into.. so the hose itself isn't good. I have a metal ring inside my hose and the fitting screws into it. It just "looks" like it goes into a hose. You also want a straight shot into the throttle body so don't spray at the bend.
2. Not much but you will want it tuned with the meth up and running.
3. Washer tank is what I used also. Unplug the electrical connector to the pump, but leave the pump in there. It closes off a hole. You can mount the new meth pump in the fenderwell behind the tire (remove the inner fender access panel). I covered the top of my pump with plastic because it is right under the drain utters.
Bret has some pics of his "3 injector" meth setup. You don't need that however it will give you a good idea on location. (basically a few inches in front of the throttle body).
Old Feb 12, 2011 | 01:05 AM
TheRadioFlyer
Supporting Vendor
I don't suppose it's possible to drill/tap directly into the throttle body assuming clearance for the blade.....?
Old Feb 13, 2011 | 04:31 PM
Todd157k's Avatar
Todd157k
Banned Scam/Spammer
It is, and some have done it. Hard to get a good straight shot though. It might also put more in the front cylinders than in the rear.
Old Feb 14, 2011 | 08:11 AM
Julio's Avatar
Julio
My questions:
Nozzle placement doesnt matter as long as it goes pre-tb. You have to understand the way the meth works is if the temperature going over the nozzle is higher than the liquids flash temperature.. the meth will flash into the air and get even cylinder distribution. Well.. as evenly as the air distributes.
Example methanol flashes at 70 degree's. Water is 180. Thats why meth works better on lower boosted applications. Every PSI boost is 11 dgeree's. So 5 PSI=55 plus ambient.
The air velocity going through the pipe at WOT is 150+ MPH. So if the nozzle is 2 inches or 2 feet away.. doesnt matter. This is not nitrous on an NA car.
You can put the nozzle on the pipe in the silicone hose or metal pipe leading to it. I would not touch the TB.
Hope this helps.
Old Feb 14, 2011 | 10:11 AM
TheRadioFlyer
Supporting Vendor
I was told that meth will destroy silicone hoses if the nozzle is installed there.
Old Feb 14, 2011 | 11:24 AM
corvettebob1's Avatar
corvettebob1
Hope this helps.
Listen to this man!
The only thing I want to add is install the nozzle in front of the IAT sensor for maximum benefit.
Old Feb 14, 2011 | 12:02 PM
Julio's Avatar
Julio
Originally Posted by corvettebob1
Listen to this man!
Great point that way tuning can be done to offset timing
I'd rather have a nozzle on the metal pipe but there are other ways it can be done.
Old Feb 14, 2011 | 12:05 PM
Julio's Avatar
Julio
Nope
Meth won't harm silicone. Can't say the installation procedure doesn't though
Old Feb 14, 2011 | 12:36 PM
TheRadioFlyer
Supporting Vendor
Would injecting meth upstream of the blower have as much of an affect as downstream? My IAT sensor is upstream of the blower.
Old Feb 14, 2011 | 12:52 PM
jad568's Avatar
jad568
Twin Turbo Meth Injected!
I have a Twin Turbo setup running 6 PSI of boost and my Meth/H20 injector is just downstream of the MAF. As I understand it you really don't want the MAF sensor to see the affects of the Meth system. I have a custom tank in place of the old washer tank and the pump is inside the passenger fender. See pic below:
Old Feb 14, 2011 | 01:32 PM
Julio's Avatar
Julio
IAT sensor placement is just for tuning strategy. The motor wont care where the nozzle is.
Now.. that being said, the meth is used as an IC. So typically it goes after the heat source not before it. In your case after your IC. You can put a nozzle pre-blower but your gains/benefit vs risk/cost may not warrant it.
Keep it simple. Place nozzle and IAT in metal pipe. If you want to really be slick, ditch the 90 degree silicone hose and replace with an aluminum 90 degree pipe. Mount your IAT into the aluminum pipe.. and the nozzle a little distance back. Dont overcomplicate it
Old Feb 14, 2011 | 01:35 PM
Julio's Avatar
Julio
Neat.. methanol and aluminum are no-no's unless your using washer fluid then its really not meth anymore.
Typically one would use stainless or plastic for a tank. Anodized aluminum fittings also fail in the thread areas.
Old Feb 14, 2011 | 02:33 PM
Chris Stewart's Avatar
Chris Stewart
There's a huge advantage to breakout the IAT, and have the IAT sensor after the meth nozzle. It becomes obvious when you bracket race and the rounds get closer, (hotlap) and your IAT's are going up. The meth keeps things in check, but otherwise your tune sees the IAT going up and pulls timing. Then you slow down, or just can't hold your dial.
To Meth injection for Vortech setup?
