***treadstone intercooler***
Old Aug 19, 2011 | 06:51 PM
princerobert1's Avatar
princerobert1
Default ***treadstone intercooler***
Does anyone have this intercooler on there fi set up. If so did u have to fab mounts for it? How is the quality?
here are the specs on the intercooler:
Core Size, 25" X 6" X 3.5"
1-3" outlet and 1-3" inlets, passenger or driver side
Outlet is angled 15 degrees back towards engine
1453 CFM flow rate
968 HP efficient
1.5psi pressure drop at 1453cfm
http://www.treadstoneperformance.com...e.phtml?pk=798
http://www.treadstoneperformance.com...2C+GM%2C+Viper...
Old Aug 19, 2011 | 09:55 PM
bullitt4110's Avatar
bullitt4110
I am going to be purchasing one in the near future so I'd be curious as well.
FixedRoof's Avatar
FixedRoof
Cruise-In VI Veteran
My buddy runs one. It's a pretty nice piece for the price. Had to make brackets for it that attach to the tabs, but no big deal
Old Aug 19, 2011 | 10:26 PM
princerobert1
is your buddy happy with it does it get the job done
Old Aug 19, 2011 | 11:22 PM
FixedRoof's Avatar
FixedRoof
Made right at 600rwhp on a stock bottom end ls1 and p1sc. kept the intake air temps low. He is pretty happy. I would run one if I needed one.
Old Aug 19, 2011 | 11:45 PM
princerobert1
sweet thanks for the feed back
Old Aug 20, 2011 | 12:57 AM
2slicks1vette's Avatar
2slicks1vette
What did he do for piping?
Old Aug 20, 2011 | 01:00 AM
princerobert1
piping should be pretty easy you can buy kits off of ebay i think treadstone sells piping kit too
Old Aug 20, 2011 | 05:13 PM
2slicks1vette
So if the blower sits on the passenger side, is it best to get the intercooler inlet on the driver side or passenger side?
Old Aug 20, 2011 | 05:17 PM
princerobert1
i think its personal preference but i would say passenger side i think the routing would be more direct
Old Aug 20, 2011 | 05:24 PM
YeloFevr's Avatar
YeloFevr
It's an excellent FMIC — don't hesitate in purchasing one. As far as piping, just route it the same way as you would with an A&A kit. No need to make it more complicated than it needs to be by running it out the drivers side and back across to the blower.
Old Aug 20, 2011 | 05:27 PM
princerobert1
with the routing
so i asume you have used this intercooler cuz im thinkin about using it on my turbo set up to save a little money i mean $400 bucks you cant beat that it looks like its decent i guess ill just have to man up and try it
Old Aug 20, 2011 | 07:49 PM
2slicks1vette
Oh ok, for some reason I was under the impression that A&A routes the piping all the way over to the driver's side. I figured their might have been something in the way, preventing them from going directly from the blower to the passenger side.
Old Aug 21, 2011 | 08:42 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
www.siliconeintakes.com
Thanks,Matt
Old Aug 21, 2011 | 09:10 AM
helga203's Avatar
helga203
Default Better?????
What will this intercooler do diff then a A&A intercooler (older one 2003). Will there be better performance more boost?????????:con fused2:
Old Aug 21, 2011 | 09:51 AM
2slicks1vette
It looks like my procharger has the outlet facing towards the center of the car. It appears that I would need to have the outlet facing towards the ground to be able to run the pipe straight down from the procharger into the passenger side of the intercooler.
Can I just loosen up the 7 allen bolts and rotate the outlet towards the ground?
Old Aug 21, 2011 | 11:14 AM
madmatt9471
Yes! You do that and rotate the Volute to turn it - be aware that you will relocate the screws as you rotate it!
Thanks,Matt
To ***treadstone intercooler***
Old Aug 21, 2011 | 12:09 PM
2slicks1vette
Originally Posted by madmatt9471
This seems interesting. I wish somebody had a DIY so that I knew exactly what I need to order all in one shot.
Old Aug 21, 2011 | 12:58 PM
YeloFevr's Avatar
YeloFevr
http://www.aacorvette.com/pdf/aa_pc_clocking.pdf
Make sure your oil slinger is in the proper position, as well.
Old Aug 21, 2011 | 03:57 PM
2slicks1vette
Thanks,Matt
Thanks for the help.
Do you know if the volute can be rotated with the blower and bracket still secured to the car?
If not, is there a write-up anywhere on how to remove the blower. It's a gen 1 ATI P1SC with their gen 1 bracket.
