Ysi. Max cubes?
Old Sep 8, 2011 | 03:21 PM
stevieturbo's Avatar
stevieturbo
AFAIK This is still on a YSi
http://www.youtube.com/watch?feature...&v=sDiESieKDlo
Not very many details about it though.
Old Sep 8, 2011 | 03:48 PM
joe11204's Avatar
joe11204
Procharged F1X 7.18 @ 197
St. Jude Donor '09-'10-'11
Originally Posted by 4DRUSH
Should be not problem running mid to low 8's with the proper trans & weight.
If someone would let me borrow one, I'd prove it.
Maybe I can lend you an F3R
Originally Posted by helga203
I guess nobody knows what the max cubes is. My next build I'm going to go with 427 stroked to 434 with ysi or f2 or something like that. I would think as long as it breaths and forged there is no limit.502cu ???????
I wouldn't compare a YSI to an F2 which flows 2700CFM.
VORTECH V-7 YSI-TRIM SUPERCHARGER
Performance Specs
Max Speed: 65000 RPM
Max Boost: 30 PSI
Max Flow: 1600 CFM
Max Power: 1200 HP
Peak Efficiency: 78%
The equivalent in Procharger would be an F1-A or F1-C which requires a base engine hp range of 300-550.
Will it work? Yes, but I wouldn't put a YSI on a 300 cube motor or a 600 cube motor. You need to find the sweet spot for your setup. LS motor 400 - 450 cubes IMHO.
You mentioned 502 cubes. You are out of the LS family at that point that is BBC
Old Sep 8, 2011 | 03:54 PM
stevieturbo
There are quite a few setups in Australia with the YSi making in excess of 1000rwhp on Dyno Dynamics and Mainline dynos. Both of which are a lot more conservative with their numbers than a Mustang dyno
Some are even up around 1200rwhp.
So it depends how solid those stats from Vortech actually are.
They could be comparable to a Bosch 044 pump. Bosch only rate them to about 400bhp, yet certainly in the US, people would rate them at double that in terms of power a unit can support.
I guess the issue is, how fast can a YSi reliably be spun, and how efficient are they at speed ?
I can only comment on mine, and I spin to about 69k max. Even at that, the compressor blade tips at both inducer and exducer have made contact with the cover. I can only assume either heat has caused it, or a combination of heat and the blades flexing at speed
Dont think I'd want to risk spinning much harder.
Old Sep 8, 2011 | 04:11 PM
helga203's Avatar
helga203
Default Torque
From what i've been reading i'm looking for mass low end torque with the big cubes. Which i don't think you could accomblish with smaller cubes???
Old Sep 8, 2011 | 04:12 PM
Arun@CCP's Avatar
0Arun@CCP
Former Vendor
Tobner ran a best of 170mph @ 3300, so just simple racer math says he's making around 1200 hp to get it done-just like the rating Vortech gives it.
Dyno's can read anything they want-tuning tool and before and after is what it does best.
Old Sep 8, 2011 | 04:13 PM
Arun@CCP's Avatar
0Arun@CCP
Former Vendor
Yep-then you want the cubes-but don't let anyone fool you into thinking your going to be faster.
Just get ready to break alot of parts.
Old Sep 8, 2011 | 04:24 PM
stevieturbo
I fully agree. But in shootout mode that should not happen.
Either way, it would seem the YSi can blow above what Vortech claim, even if the blades do have casting flaws and bend lol
But if someone is looking for a torque monster, then a centrifugal is by far the wrong choice.
Old Sep 8, 2011 | 10:10 PM
zssman's Avatar
zssman
Very informative guys, keep it coming. Thanks.
Old Sep 8, 2011 | 10:13 PM
zssman's Avatar
zssman
Thinking 427, 434, ysi, non intercooled, carys ls7 heads an intake, solid roller, glide and 275 drs. Whats do u think? 3400lb 02 SS, 25.5.
Old Sep 8, 2011 | 11:57 PM
jmuck's Avatar
jmuck
I've always heard that the Renegade guys have spun the YSi's well over the recommended ratings?
So 400-450cubes? I know there isn't a magical number, but why between those 2 cubes?
Old Sep 9, 2011 | 07:06 AM
zssman's Avatar
zssman
RHS block. If the blower don,t get it done a piston swap back to the juice.
Old Sep 9, 2011 | 09:06 AM
helga203's Avatar
helga203
Performance Specs
Max Boost: 30 PSI
Max Flow: 1600 CFM
Max Power: 1200 HP
Great info thanks.
Old Sep 9, 2011 | 09:27 AM
  #33
jmuck's Avatar
jmuck
ZSSSMAN, you wouldn't happen to have been or still are a LittleRockRacingscene member are you??
Old Sep 9, 2011 | 09:52 AM
  #34
helga203's Avatar
helga203
Lingenfelter 2005 C6 427 CID Twin Turbo Corvette 1038 RWHP. Check this out on youtube i love this vid. don't know how to down load to forum.
Old Sep 9, 2011 | 10:13 AM
  #35
helga203's Avatar
helga203
http://www.youtube.com/watch?v=n4J3v976_Cc
Old Sep 9, 2011 | 10:20 AM
  #36
stevieturbo
In Oz with the YSi. Mark uses them a lot, and his builds are superb.
http://www.youtube.com/watch?v=4CFcP...eature=related
http://www.youtube.com/watch?v=UvD_Brevbb4
Not sure how fast they are spinning the blower. But the smaller pulley doesnt look an smaller than 28, may even be 30T.
And I know the standard large pulley for the crank that is offered with CAPA's ortech setups is 86T, so more than likely that is what they are using. TBH there wouldnt really be much room for anything larger anyway.
I had mine custom made at 85T for this reason and currently using a
30T blower pulley.
Old Sep 9, 2011 | 04:35 PM
  #37
zssman's Avatar
zssman
Thats me.
To Ysi. Max cubes?
Old Sep 9, 2011 | 05:32 PM
  #38
jmuck's Avatar
jmuck
Originally Posted by zssman
Thats me.
I'm Twotonefreak over there. Haven't trolled around there much since I moved in 07.
Old Sep 9, 2011 | 07:36 PM
  #39
MVP'S ZO6's Avatar
MVP'S ZO6
ISIS SUCKS FAT CHOAD
The truth of this whole matter is build a 402 or 416 stroker. Why because it's the most cost effective 400+ cubic inch stroker you can build because you can use an LQ9 block. Sure you can buy a LS7 block or another factory large diaplacment aluminum block or even an RHS aluminum block or LSx cast iron block and get more then 416 cubic inches but it starts to get real expensive real quick.
Old Sep 9, 2011 | 08:41 PM
  #40
zssman's Avatar
zssman
Already have the rhs block. Taking my time, gathering info on different combos to see whats the best bang for my buck. An try to acomplish my goals. Also finding good deals on the net helps too. Research helps to. THANKS again guys this is helping a lot. Who has the best deals on a ysi for a ls1 (head unit)? PHIL.
