Ysi. Max cubes?
Old Sep 10, 2011 | 03:29 AM
  #41
stevieturbo's Avatar
stevieturbo
I see Summit list the head unit for just under $3k
Old Sep 10, 2011 | 03:10 PM
  #42
MVP'S ZO6's Avatar
MVP'S ZO6
ISIS SUCKS FAT CHOAD
Originally Posted by zssman
Already have the rhs block. Taking my time, gathering info on different combos to see whats the best bang for my buck. An try to acomplish my goals. Also finding good deals on the net helps too. Research helps to. THANKS again guys this is helping a lot. Who has the best deals on a ysi for a ls1 (head unit)? PHIL.
Oh damn you got the RHS block well I see your not that concerned with money. Lol. J/K. That's a fantastic block. Your better off buying a whole kit. I'm about to send you a PM.
Old Sep 11, 2011 | 09:05 AM
  #43
helga203's Avatar
helga203
Default Mind change
After seeing all the responces on this max cube debate I'm having second thoughts. Don't want to start another thread. First ? How many safe cubes could a 6.0L iron ls block attain? Bore,stroke? What needs to be done of corse YSI s/c'ed. Where talking just the block because this could go on forever with heads,cam,you know where i'm getting at. Thanks
Looking for more cubes by the way, but seems 427 or 434 might be to much????
Old Sep 11, 2011 | 11:56 AM
  #44
MVP'S ZO6's Avatar
MVP'S ZO6
416 is as much as you want to go on the LQ9 block. Guys always use a 4.0" stroke crank. Here's the thing though, Let's say you build a 402 with the iron block which is a 4.00" inch stroke with 4.005 inch pistons (if I recall correctly) this is good because your leaving room for an over bore on the cylinders should you have to in th future and most of all in the grand scheme of things your not going to notice a huge difference in power with a YSi on a 402 vs a 416. There will be the potential for a significant power difference once you reach the 427 and larger territory. However, if i recall correctly the LQ9 block won't safely support that type of piston size with a blower.
You can't go over a 4.00" stroke on the LQ9 block and making the cylinders real big on that particular block is asking for trouble on a FI application. Hence the reason FI guys who want more cubes usually end up with a factory large displacement block or an aftermarket race Block.
So to answer your question, if you have the extra money and the desire for more cubes and the potential for more power while stressing the engine less, a 427 and larger is good and feasible just not with the LQ9 Block.
Old Sep 11, 2011 | 04:09 PM
  #45
helga203's Avatar
helga203
That's the answer i was looking for thanks you.Go Chicago Bears.
Old Sep 11, 2011 | 07:21 PM
  #46
MVP'S ZO6's Avatar
MVP'S ZO6
No problem. Good luck with your decision. Da bears. Good luck there too. U guys won pretty decisively today.
I'm a lions fan.
Old Sep 11, 2011 | 07:30 PM
  #47
LB's Avatar
LB
I am trying out the YSi on my new 06Z06 ... 396ci 4.125 bore 3.625 Stroke. See how the ls7 square port head does with good size cam when I spin it 7500+. Backing that up with 8" Balancer and 2.95 Blower Pully, 10 Rib Conversion
I am hoping to put down 1000rwhp.
Old Sep 13, 2011 | 01:47 AM
  #48
zssman's Avatar
zssman
Did u forget? lol.
Old Sep 13, 2011 | 01:49 AM
  #49
MVP'S ZO6's Avatar
MVP'S ZO6
Did u forget? lol.
Yeah sorry sending now.
Old Sep 13, 2011 | 01:51 AM
  #50
zssman's Avatar
zssman
Just got back from LsFest, has a blast. Didn,t see any ysi cars.
  #51
zssman's Avatar
zssman
U a night owl too? LOL.
Old Sep 13, 2011 | 01:55 AM
  #52
MVP'S ZO6's Avatar
MVP'S ZO6
Pm sent. Yeah I work nights.
Old Sep 13, 2011 | 01:56 AM
  #53
MVP'S ZO6's Avatar
MVP'S ZO6
Your a camaro or vette guy?
Old Sep 16, 2011 | 06:14 AM
  #54
zssman's Avatar
zssman
Sorry been busy. Camaro guy. Thats mine in my avatar. 1st Lsx Shootout.
Old Sep 18, 2011 | 02:06 PM
  #55
zssman's Avatar
zssman
Nice, any updates?
Old Oct 9, 2012 | 12:48 AM
  #56
BLWN1's Avatar
BLWN1
Originally Posted by Arun@CCP
Doesnt matter how many cubes you use it'a all about airflow-said that the YSi can only move a certain amount of air-which means even if you have a 311 cube motor or a 440 cube motor it's only going to make 1000rwhp.
Fastest YSi pull to date is 5.10@140 mph-some food for thought. This was accomplished with 377 cubes at a weight of 3330.
If your running a a class and your limited too say a 275 tire-are you going to need all that torque?
5.10 in a stang or actual vette?
Sorry old post....
Old Oct 23, 2012 | 12:26 AM
  #57
BLWN1's Avatar
BLWN1
Just noticed you said Tobener so assuming still a mustang... maybe renegade, from the old days...
To Ysi. Max cubes?
Old Oct 23, 2012 | 01:24 AM
  #58
Arun@CCP's Avatar
0Arun@CCP
Former Vendor
Yep, big bad Bart!
Old Oct 23, 2012 | 09:03 AM
  #59
robert miller's Avatar
robert miller
Default ttt
Seem like no matter what you do the YSI is out of air when the car makes around 1,k rwhp and some like 850 rwtq..Not much more in the unit at all... Robert
Old Oct 23, 2012 | 04:38 PM
  #60
stevieturbo
They need to make a bigger replacement, and make it soon !
