The e85 thread
Old Nov 20, 2011 | 08:59 AM
Warp Factor's Avatar
Warp Factor
Originally Posted by Z06supercharged
Straight from pump 91 at 14 timing to E85 with 19 timing netted 46 rwhp more I think it was (I dont have my exact info here with me).
E85 allowed more timing, but how much more power do you think could be had by increasing boost, because the E85 has a higher detonation threshold? I'd think that's where the largest advantage would be.
A friend of mine is running about 25 pounds boost with E-85 on his Big Block, without an intercooler.
Also, how much of a safe boost increase might E-85 allow on a stock shortblock? With lower combustion temperatures and greater resistance to detonation, I'd think the stock pistons would be less stressed, and there would be less chance of butting the ring end gap. I'd be darned surprised if it wasn't good for another 150 hp. Anyone try to explore the limits with this?
Old Nov 20, 2011 | 02:44 PM
stainless40cal's Avatar
stainless40cal
I haven't seen anyone. But I Gurantee you a stock shortblock record could easily be broken with e85. I would bet money with upgraded rod bolts you could have it hold over 1000rwhp for a while. One of the magazine companies just did this with a 5.3 stock short and some eBay twins and made 1200hp. I don't believe it was on e85 though.
Old Nov 20, 2011 | 04:37 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Originally Posted by MVP'S ZO6
I'm about to pick up some of the ID1000's. Would like to find the best price I can on them though.
call me on those. I got you covered!
Old Nov 20, 2011 | 05:16 PM
bullitt4110's Avatar
bullitt4110
At the shop I work at (again subaru's) my boss gets on average about 60-70awhp going from CA 91 to E85, and more the bigger the turbo.
Old Nov 20, 2011 | 06:00 PM
Warp Factor
As I recall, they increased the ring end gap, used race gas, and got the numbers.
Old Nov 21, 2011 | 06:58 PM
stainless40cal
Yep I think you hit the nail on the head. My car is 99% complete. Basically ready to fire and break in. Hoping to see what e85 can do for my top mount going into the new year.
Oh and warp my car looks a lot like your avatar. Except in black and no carbs on top
Old Nov 21, 2011 | 08:48 PM
mdaniel's Avatar
mdaniel
Banned Scam/Spammer
You can keep your pro stock fuel system. I'll add a can of Torco for $10 and call it a day.
Old Nov 21, 2011 | 09:08 PM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
Changing plugs all the time, exhaust tips turning burnt orange, AND it doesn't have near the "pros" as E85.
Old Nov 21, 2011 | 09:16 PM
dascorcha21's Avatar
dascorcha21
informative post!
your missing the whole point of it. along with the benefits you wont receive from using e85...
Old Nov 21, 2011 | 10:59 PM
MJD's Avatar
MJD
You'll like it a lot. I run a non I/C maggie with e85 and haven't really seen the heat soak issues that many complain about with these blowers. On the dyno with no cool down period my numbers varied very little. In fact I put the numbers in my sig down on the 4th pull.
Old Nov 21, 2011 | 11:37 PM
stainless40cal
Nice
I figure since with the 3.6 liquid cooled KB blower, the e85, and the cooling affects/cold air of the blower sticking up through the hood, if I have any heat issues at all I will just take a sledge hammer to it anyway
Old Nov 22, 2011 | 09:53 AM
mdaniel's Avatar
mdaniel
Banned Scam/Spammer
I've changed my plugs once in the last five years. 9 second turbo car. FWIW
Old Nov 22, 2011 | 10:59 AM
  #33
Z06supercharged's Avatar
Z06supercharged
Torco worked for me for a year until I wised up and went E85. There isnt even a comparison between the two. If boosted its a no brainer. If you have E85 available and a fuel system to support it then continuing to use Torco or any other octane booster is just.....goober
Old Nov 22, 2011 | 12:08 PM
  #34
CancerJCC's Avatar
CancerJCC
Thought I'd re-look into E85 after seeing this thread. No go for me though since E85 is only 2 cents cheaper than 93! This is on Ft. Benning, GA BTW and is the only spot around to fill up. Maybe in time though. (Oh I DD my V so mileage is a small concern).
Old Nov 22, 2011 | 12:31 PM
  #35
user_name's Avatar
user_name
Major downsides are the cost of the fuel system, limited availability, and the need to check on/tweak the tune so often due to the different blends. For me I think it outweighs the pros. I'll do 93+meth most of the time. C16 when I want to crank it up.
Old Nov 22, 2011 | 01:21 PM
  #36
dsmlights's Avatar
dsmlights
right now I been running e85 for almost a year and it is great. No downside other than filling up more frequent. I just ordered the ID2000. Once I install will see what more I make. I was limited to the injector size before I made 650@12-13 psi I am going to try and make 14-15 psi and see if I make it to the 700 club
Old Nov 22, 2011 | 03:00 PM
  #37
stainless40cal
The only real downside I see there is the availability for some people. Luckily we have 5-6 stations in our town. Fuel system cost isn't much more if any extra than what you have to spend on a meth system for 93 octane. I have a friend who runs the same tune all year with all three level of blends and never touches the tune. Sure it runs a little rich in dead winter, but still much safer of a fuel compared to 93 and meth in my opinion.
To The e85 thread
Old Nov 24, 2011 | 06:38 PM
  #38
SueTaing's Avatar
SueTaing
I'll be switching to full e85 in about 1-2 months I will post some info. I will be using the stock fuel system minus what comes in the A&A Kit. Just a fun test to see what I can do on eth for the cost of an hour tune. I will likely be maxing my injectors but I dont drive my car much so not too worried about that for now.
Old Nov 24, 2011 | 08:51 PM
  #39
Z06supercharged
Thats ridiculous a station is only that much difference. The Chevron station here E85 (its not Chevron fuel btw) is $3.59 and pump 91 is $3.93.
Old Nov 24, 2011 | 09:45 PM
  #40
CancerJCC's Avatar
CancerJCC
I agree! Although its a federal installation that requires our flex fuel vehicles to use E85. Probably drives up the price from AAFES because they know we HAVE to use it in our government vehicles.
