Meth question
Old Feb 1, 2012 | 10:43 PM
Robert 2000's Avatar
Robert 2000
Originally Posted by DOUG @ ECS
You leaving a fair amount of power on the table by using boost juice over pure meth. (just an FYI)
I am in no means against pure meth. It is really a matter of long road trips and I didn't know how it would be to travel with pure meth in any location other than my WW tank. I also have the snow kit which I think is fine with pure meth but I am not certain. Does pure meth allow more timing? Where is the power boost coming from?
Old Feb 9, 2012 | 12:15 AM
BLACK-10's Avatar
BLACK-10
I believe the stock washer tank is 1.6 gal.
i say that because when its full it fills up a wash bucket like this. seems like a lot especially when your trying to take it off the car and its full
Old Feb 9, 2012 | 01:03 PM
tlove32's Avatar
tlove32
Originally Posted by Todd157k
go to any wallymart / target and get a couple bottles of HEET. It's Methanol, and it's $1.99 per bottle. The rest is pretty simple.
I also keep a couple bottles in our other cars in the winter. A shot of HEET in the washer fluid keeps it from freezing.
I've been on longs trips, and never needed to refill the meth tank. However, if I needed to I'd get a bunch of bottles of HEET (yellow bottle).
Old Feb 9, 2012 | 01:49 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Originally Posted by SinisterC6
6000 miles in 7 months, 10 gallons meth, lots of won races
Priceless..
Old Feb 9, 2012 | 03:45 PM
SinisterC6's Avatar
SinisterC6
Speedy
2024 C8 of the Year Finalist - Modified
Its coming from cooler IATs which means you can put more timing and or boost before knock is seen. Since knock is just a premature combustion due to high cylinder temps anything you do do to decrease cylinder temps; meth, race gas will help.
Typically when you increase boost while using meth you are "meth dependent" because you really can change boost on the fly.
When you tune a car to have more timing while on meth you are "meth independent" because the computer pulls just enough timing to prevent knock while your off meth.
On a road trip I took I brought a 5 gallon drum secured in the trunk via bungee chords
Old Feb 9, 2012 | 03:46 PM
SinisterC6's Avatar
SinisterC6
Speedy
Priceless..
What can I say, ECStacy and Meth are a brutal combo.
Old Feb 9, 2012 | 04:10 PM
schnellTTZ06's Avatar
schnellTTZ06
Water Injection is most efficient with a 50/50 water alcohol (or methanol) mixture.
Denatured (ethanol) alcohol, typically 95% pure, is available in paint, hardware, and Home Depot type stores in gallon containers.
Denatured alcohol also has a higher octane rating 129 vs 123 respectively.
Old Feb 9, 2012 | 05:17 PM
SinisterC6's Avatar
SinisterC6
Speedy
There is something in the VP M1 meth like a lubcricant that is recomended for our pumps. I have yet to find any ethanol at a hardware store, I tried everyone in chicago. But everything you say is true
On a side note, though denatured alcohol could act as a cheap version of ever clear the manufacturers realized this and added methanol (which if ingested is a neuro toxin and causes blindness - so no home made home depot moon shine
Old Feb 9, 2012 | 07:20 PM
Robert 2000
I am already meth dependent
Just running boost juice and was wondering if pure meth allows more timing or how it makes more power over 50/50 mix
Old Feb 9, 2012 | 07:48 PM
SinisterC6's Avatar
SinisterC6
Speedy
oh yea, I think doug said he can make 50 extra ponies due to more timing
Old Feb 9, 2012 | 08:18 PM
liveaboard74's Avatar
liveaboard74
ECS. How much more timing using pure meth can you add on a adv. motor if you had the same motor without meth? Both boosted/same psi!!
Just a ball park figure will do.
Old Feb 9, 2012 | 09:11 PM
_zebra's Avatar
_zebra
this is why you tune without meth & just spray for safety
but that ain't as fun!
Old Feb 9, 2012 | 09:23 PM
  #33
Robert 2000
Hmmmm maybe I will make the jump then to pure meth in the future
Old Feb 10, 2012 | 08:45 AM
  #34
StatmanRN's Avatar
StatmanRN
I've found you can usually find all the meth you want in the nearest trailer park.
Old Feb 12, 2012 | 06:47 PM
  #35
helga203's Avatar
helga203
Old Feb 12, 2012 | 10:39 PM
  #36
C5sleeper's Avatar
C5sleeper
Go to a chemical supply company I paid $170 for 55 gallons.. just make sure cap is on tight
Old Feb 12, 2012 | 10:55 PM
  #37
liveaboard74
Smartest answer I've heard yet.
