the dreaded chirpping
Old Feb 20, 2012 | 05:56 PM
4SFED Z's Avatar
4SFED Z
Default the dreaded chirpping
After 5 min chirpping is gone. Cold start its there. I'm going to mist belt to see if that's the culprit. If its loose. How do you tighten the belt up. I have a and a v2 si kit. Thanks.
Old Feb 21, 2012 | 07:14 AM
4SFED Z's Avatar
4SFED Z
Belt is tight. Sounds like pulley in blower area. Idk....
Old Feb 21, 2012 | 10:03 AM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
That basically means that there is a pulley that is slightly off front to back, but not enough to make it jump. A belt rib is roughly .140, so you may need to shim a pulley .050 for instance and it will go away.
Now figuring out which pulley and which direction is the fun part. Hope that helps.
Old Feb 21, 2012 | 11:48 AM
AVB's Avatar
AVB
Don't over look the AC belt.
Old Feb 21, 2012 | 12:26 PM
Mikvi's Avatar
Mikvi
St. Jude Donor '10
I had same problem. Belt only had a few thousand on it. Changed the belt and re-tightened and problem went away. The stealership put the belt on and it must have been a cheapo. Motor was starting to run rich as the belt was slipping so much. Have a procharger, but basically same setup.
To the dreaded chirpping
