Bap
Old Jul 7, 2013 | 04:55 PM
Dave concrete's Avatar
Dave concrete
Default Bap
Do BAP go bad. Mine always said 60 pounds now it's at 55-56. The fuel pumps are new GM one that were installed under warrenty when crossover was fixed.
Old Jul 7, 2013 | 06:19 PM
Darion's Avatar
Darion
I had one go bad, capacitor blew up inside, so ya it can happen.
PC
Old Jul 8, 2013 | 07:57 PM
PhysicsDude55's Avatar
PhysicsDude55
Measure the voltage at the pump and you'll be able to see....
Old Jul 9, 2013 | 07:39 PM
Dave concrete
I will check voltage. It's working just a 4 to 5 pound difference in pressure.
Old Jul 9, 2013 | 07:41 PM
Dave concrete
What is the fuel pressure without a BAP?
Old Jul 9, 2013 | 09:02 PM
fotoboy's Avatar
fotoboy
Have seen 2 go bad. Build your system right.
Old Jul 16, 2013 | 05:27 PM
Josh@AandASuperchargers's Avatar
Platinum Supporting Vendor
We have sold hundreds of KB BAP's over the years with only 2 failures in all that time. Just not common for a KB BAP to die. Other brands of BAP's I've seen fail more often.
What is way more common is for the Autometer fuel gauge or sending unit to start crapping out and give false readings. Put a mechanical fuel pressure test gauge on the rail to confirm actual pressure.
Stock rail pressure should be 58psi.
Old Jul 16, 2013 | 07:45 PM
Dave concrete
thanks I will check. I noticed it has slowly went from holding at 60 psi to 58 now around 56 57
Old Jul 18, 2013 | 05:13 PM
PEETYZ's Avatar
PEETYZ
You may have a clogged filter? I'm not sure if the 04 Cars have an inline filter like my 2001. Heat also makes a big difference.
Old Jul 18, 2013 | 05:31 PM
optimum01's Avatar
optimum01
Pretty sure when I had mine I also saw the pressure like you said 58 57 or so. Tuner said don't worry about it.
To Bap
