Cartek D1SC
Old Jun 13, 2014 | 08:43 PM
oldC5's Avatar
oldC5
Great numbers Callie.
Old Jun 14, 2014 | 08:06 AM
callie454's Avatar
callie454
Thanks Buddy! Weather looks like it's finally cooperating. Hoping to put some miles on it this weekend.
Old Jun 18, 2014 | 05:55 AM
callie454's Avatar
callie454
Installed a set of Hinson motor mounts- the shorter version. Instantly took care of the hood clearance problem I had been encountering. It's amazing the difference .360" can make.
Old Jun 18, 2014 | 07:34 AM
oldC5's Avatar
oldC5
Old Jun 18, 2014 | 05:08 PM
callie454's Avatar
callie454
Pics of mounts vs stock for those interested.
Old Jun 18, 2014 | 05:18 PM
callie454's Avatar
callie454
Also, finally got around to installing my Halltech front mesh grille. Took only a few minutes to get it done. Looks fantastic!
Old Jun 18, 2014 | 05:44 PM
a/c man's Avatar
a/c man
let us know how the motor mounts help out!
Old Jun 18, 2014 | 06:03 PM
callie454's Avatar
callie454
They made all the difference. At first, the pulley was chewing on the under hood light bezel, and the head unit was rubbing the hood at the support cross member. I removed the hood liner, under hood light, and associated wiring. That solved the pulley grinding...
The mounts were a piece of cake. Loosen the mount hardware, loosen the cradle hardware, jack up the motor, and let the cradle hang in order to remove the OEM mounts.
Hinson specs the mounts to .360 shorter than the OEM. Works out to 23/64". Whatever the math- it did the trick. No more hood-blower contact.
Old Jun 18, 2014 | 10:17 PM
a/c man's Avatar
a/c man
Awesome any vibrations from new mounts or does it feel the same as stock?
Old Jun 19, 2014 | 05:41 AM
callie454's Avatar
callie454
Feels same as stock. I thought i'd notice a difference, but can't say that I do.
