Overheating
Old Sep 21, 2014 | 01:07 PM
  #101
danieloneil01's Avatar
danieloneil01
Separating the two looks annoying and I may just buy a new one.
Dam these things are spensive. EEK!!!!!!!!!!!!
Old Sep 21, 2014 | 01:10 PM
  #102
BLOWNBLUEZ06@RKT Performance's Avatar
Supporting Vendor
Originally Posted by danieloneil01
I checked the high speed fan (dark blue wire with high speed enabled) at the PCM and was getting 1.5v. I tried grounding the right fans ground to a good ground source (battery) and still clicked. So now I'm off to checking all connections (relays and fans) with the voltmeter for high speed operation.
I have a service manual that has the wiring schematic.
Also, the post above yours was with the relay off for each test. This time it will be with them connected using a thin wire so the relay can be in place during test.
If I can't find the problem I'll just have it when the low speed turns on it's actually the high speed and just set the high speed temp operation to 284*. And how do you pull enough slack out of the fuse block to check the connections? I can get maybe 2" off the block and that's it.
The PCM throws a ground, not a hot.
Use You don't even have to cut the control wires. You're going through a lot more trouble than you need to solve this problem. You can skin back the two relay control wires and run them to pin 85 on a good, Bosch, Potter Brumfield, Tyco or other non-Chinese, high current relay and run 12v to pin 86. Run 12v to 87 and your load (fans) to pin 30. Done. You'll still have 2 stages of fan control from your PCM.
Old Sep 21, 2014 | 01:43 PM
  #103
danieloneil01
You say to skin back the wires and I'll have 2 stages but won't the high speed relays keep clicking if I do this?
I'll try that once I eliminate my current issue. Do you know how to separate this?
Old Sep 21, 2014 | 02:44 PM
  #104
Supporting Vendor
I'm not convinced the relays have sufficient contact. If you you extend those contacts coming out of the box, you can grab a good 12v signal, and use the supply out of the PCM to supply the ground and verify the relays remain engaged. Then replace the relays with external ones after verifying that signal is stable.
As for the block, it's held together by the 3 large metal pins, the ones that the top cover screws into. To get it apart, I heat up the pins with a micro torch, place the block face down on the vise with the jaws opened about 1.5" apart. Heat it up and use about 1 1/4" punch knock the pins out. To hold it back together, you can make a plate and run a screw through it into the pins to hold it together afterwards.
I'll upload pictures in a bit.
Old Sep 21, 2014 | 02:55 PM
  #105
Supporting Vendor
Old Sep 21, 2014 | 03:03 PM
  #106
danieloneil01
Before I separate the block to determine if that's the issue I'm going to solder wires to all 3 relays then set the spliced ends into the distribution block to see if the high speed fans come on. If not then I know the fuse block isn't my issue. Yes it seems like a lot of work but I got a low IQ count.
Is there no wires connecting some of the relays together?
Old Sep 21, 2014 | 03:18 PM
  #107
Supporting Vendor
I don't recommend soldering leads to relays, but if one insists on doing so, that they be careful and quick about it because it's possible to negatively affect the factory soldering work at the other end of the leads. if you do decide to disassemble the block, you can slide off the loose terminals and flip them over and then solder that end to the block (again carefully and quickly with a nice, high powered iron). That will possibly provide you with an end with more tension. You can also increase tension on the leads by adding a dab of solder to the legs to bulk them up and then sand/grind them down to the desired thickness.
I also recommend using separate relays to ensure they're not the problem.
Old Sep 21, 2014 | 03:50 PM
  #108
danieloneil01
I bought 2 new relays for 43 and 44. I abandoned the solder idea.
Sending you a PM.
Old Sep 21, 2014 | 05:29 PM
  #109
danieloneil01
Thank you BB. Hopefully this will be fixed tomorrow.
Old Sep 22, 2014 | 08:34 AM
  #110
Supporting Vendor
Sent you a PM about your final drawing, do us a favor and isolate the two fans and then post up the fix, would ya? I'm sure this'll eventually come up again.
Old Sep 22, 2014 | 06:53 PM
  #111
danieloneil01
Well I hooked it all up using two HD relays for low and high even though the fans would run in high speed no matter what. I really didn't feel like getting the high speed wire from the pcm at the pcm so I got it from under the fuse block. When I went to enable high speed the relay clicked over and over not allowing the fans to run. I'm to the point of just not caring enough in the Houston heat in a garage to go further and try it off the PCM. From making 2 runs to the auto parts store I've been in the heat for 5hrs. I work on it more than I actually drive it and that has to end. Tomorrow I might get my condenser in and hopefully have AC soon, just in time for winter, lol.
So I programmed hptuners to nuke the high speed altogether.
I took it for a spin without the top cover and when the fans are on the temp stays at 187-190 with a 187 tstat. Outside temp is low 90s.
If you don't mind I can post the diagram I made and I'll include the PCM wire locations for the low and high speed under the fuse block if one is so inclined to go that far.
Old Sep 23, 2014 | 07:04 AM
  #112
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Yes please post your diagram - I think my buddy has the same issue!
Thanks,Matt
Old Sep 23, 2014 | 09:14 AM
  #113
PEETYZ's Avatar
PEETYZ
Glad you got it under control man. What a headache.
Old Sep 24, 2014 | 02:44 PM
  #114
danieloneil01
I went full retard and dumped my two 30 amp relays and got two 75 amp relays (Oreillys, 50 each) and separated each fan to run off each relay. I'll get a diagram up soon but it's only for low speed off the PCM but my fans will run in high speed no matter what, with or without the ac on. I have hptuners so I turned off all stage 2 runs.
Old Sep 27, 2014 | 04:19 PM
  #115
danieloneil01
Old Sep 27, 2014 | 04:20 PM
  #116
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
So all is well now?
Old Sep 27, 2014 | 05:41 PM
  #117
danieloneil01
No, fans must stay on for probably 90% of the time. I have them come on at 205 and off at 190. Car runs between 190-207 cruising on the highway. This is without a top cover though. I tried leaving the fans off on the highway early in the morning when it was 72* and the temp climbed to 230 before I let the car turn the fans on through hptuners. Hoping it is strictly because of the top cover missing.
When I get time after my move I'll see if I can find a big enough flat piece of aluminum and try to make a top cover with little gaps. I think it would help also to put some pieces on the sides of the radiator too.
