Overheating
Old Sep 9, 2014 | 07:55 PM
  #61
danieloneil01's Avatar
danieloneil01
No I wasnt there and my fuel system can't handle it without the restrictor plate in. I'm going to the track next week if they're open and log it to see.
My last dyno tune with the manual didn't make more power after 5k rpm if at all.
Old Sep 9, 2014 | 09:47 PM
  #62
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Originally Posted by ajrothm
The drag strip will tell you what you need to know.. That car will run 9.80s as it sits.
For reference, Alberts C5Z auto only dynoed 637hp, yet it ran 9.30s..
Yeah, but the fuel and tune were changed once we got to the track.
Old Sep 9, 2014 | 10:42 PM
  #63
danieloneil01
I'll be happy with 10s and a drivable car.
Old Sep 9, 2014 | 11:01 PM
  #64
a/c man's Avatar
a/c man
with my old set up close to this 10 psi one not alberts thats a beast!! my car was running 10:30s 600rwhp.
Old Sep 9, 2014 | 11:08 PM
  #65
danieloneil01
Auto or manual?
Old Sep 10, 2014 | 02:35 AM
  #66
a/c man's Avatar
a/c man
Originally Posted by danieloneil01
Auto or manual?
auto 2800 stall 342s
Old Sep 10, 2014 | 08:24 AM
  #67
Pekka_Perkeles's Avatar
Pekka_Perkeles
On the way home I stayed around 225* at anything above 65mph and in traffic it stayed around 212. Wished I knew if my fans were spinning as fast as they should. They told me I should look into SPAL fans.
I doubt fans will help you at 65 mph.
Again, increase the airflow through you radiators.
The easiest way to do it is to have vacuum behind the radiator.
Old Sep 10, 2014 | 10:53 AM
  #68
ajrothm's Avatar
ajrothm
That car is gonna run hard in good air.. I bet it goes 10.50s first trip.. Drag pack, velocity stack and track tuning, 9.80s in good air..
You're gonna have to do something different with the IC/radiator relationship.. There is no way that thing is going to cool down with the IC directly in front/on top of the condenser.
The reason it heats up at highway speeds is the engine is creating more heat from higher load, and your air flow is not increasing thru the radiator as it should to pull the heat out...
You're gonna have to mod the cradle to create a gap. Even then the air flow still sucks... But you can get it a little better I think....
Old Sep 10, 2014 | 11:46 AM
  #69
danieloneil01
Anyone have a picture of their air dam whether it be stock or aftermarket.
Old Sep 10, 2014 | 05:18 PM
  #70
Cutlassmaster's Avatar
Cutlassmaster
Search center air dam in this section. I posted 2 pics of mine. Thread was last updated on 8/27.
Chris
Old Sep 10, 2014 | 08:13 PM
  #71
danieloneil01
I'm going to be racing my brother in his tank, '10 GT500. He claims he's making the same rwhp as me. He knows he'll lose since he's a manual and is hoping for 12s, LOL!!!!!!!!!!!!!!! He said he's getting a bigger blower soon and will own me. All I need is a ECS fuel system and I can remove the restrictor plate and go full 100% meth and smack that ***. Thinking if I fix my cooling issues then I may just spend the 1k and get the ECS fuel system.
I would like to thank this forum for helping me with my issue. I'm no expert and just enjoy working on my own car which I know would be impossible for guys like me without the internet and the simplicity of the LSx engine. Thank you and GM for the simplistic engine that is the golden standard for idiots like me.
Next week it's showing low 80s high 70s at race time. Either way I'll be getting video of me raping a Mustang, lol.
Old Sep 10, 2014 | 09:56 PM
  #72
ajrothm's Avatar
ajrothm
I assume you already have some good drag tires to run on?
If not, I have some 26x11.5x16 ET Street bias ply tires with about 30 passes on them if you want them.. Find some firebird or Camaro 16x8s and throw em on.. I'll make you a crack head deal on them...
Otherwise, get some good ET street drag radials before you hit the track.
Old Sep 10, 2014 | 10:38 PM
  #73
danieloneil01
I have some hoosiers on 17s. Not a lot of sidewall but enough to whip up on a GT500. I'll probably do 1.8 sixties which is good enough. Later I'd like some 16s or 17s that have sidewalls.
Old Sep 11, 2014 | 12:47 PM
  #74
ajrothm's Avatar
ajrothm
If the Hoosiers are the 275/40/17 drag radials, those hook great, especially on a sticky track. The 1" shorter diameter will help your gear ratio and tighten the converter some. Those should work well for you if they are fresh..
That car will go low 1.50 to high 1.40 60's easy! You are gonna be surprised how quick it runs. The problem is the heat/humidity and DA.. You'll have hell keeping the coolant temps down.. Better hit the radiator with the water hose after a pass to cool it back down to the 160s...
Keep it as cool as you can, I'd probably put a couple gals of race fuel in it for safety as well...
Old Sep 11, 2014 | 12:58 PM
  #75
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
open the front up....to get some air flow....I had to do this with mine...difference is night and day...
https://www.corvetteforum.com/forums...t-updated.html
Old Sep 11, 2014 | 01:03 PM
  #76
danieloneil01
Okay, I'm starting to tear it down up front and want some opinions. I'm thinking of cutting off the radiator/IC support in the middle (in between the radiator support mounts) and bolt in a piece of straight aluminum to just see if it works. If it does, I'll back it up with a flat piece of steel.
I'll mount the IC up against the front of the frame and use a angled piece of aluminum which will hardly see any weight since it's mostly held up by the charge pipe to the TB. I'm wanting to close off the sides of the radiator which shouldn't be hard but time consuming.
Old Sep 11, 2014 | 01:11 PM
  #77
danieloneil01
I have the screen front plate which hasn't helped. But I noticed your top cover is basically on the condenser. I wonder if that works better than the top cover you get with ECS or AA kits.
To Overheating
Old Sep 12, 2014 | 06:25 PM
  #78
pewter99's Avatar
pewter99
yeah I am not familiar with the ECS part...but this is the only thing that has worked for me...I wish you well I know how frustrating it is
Old Sep 12, 2014 | 07:51 PM
  #79
danieloneil01
I'm going to try and move it as far forward as it can go in hopes I can get more airflow into the radiator. To do this I ordered a 12" hose to extend it so I can move the IC a few more inches forward. I've already got my flat aluminum bar in place but I'm not sure how well it'll work but I'm hoping it will. I'm also going back to a 160* tstat.
I'm thinking if I can completely box in the top with a top cover and the sides somewhat then that should help feed the airflow through the radiator but I don't have anything other than a grinder to make cuts. And cutting circles for the tubing should be interesting. Wonder if a dremel has an attachment that can can thin metal?
Old Sep 12, 2014 | 08:37 PM
  #80
pewter99's Avatar
pewter99
never know till you try....good luck
