ECS fuel ring install help
Old Mar 15, 2015 | 02:18 PM
nullpointer's Avatar
nullpointer
Default ECS fuel ring install help
So I spent the last few hours trying to get the damn ECS fuel ring bolts in to the tank. Needless to say, it didn't line up. I am able to get 3 bolts in but the others do not line up with the tank (they do insert into the ring).
The kit came with 4 o rings, so I installed them on both sides of the ring. That means on the tank side there is the OEM gasket then orings. Could this be my issue? The directions are not clear that only two should be used.
About ready to pull my hair out...
Old Mar 15, 2015 | 02:52 PM
StealthFRC's Avatar
StealthFRC
pretty sure there are 2 versions of it that have a different bolt pattern.... sounds like you have the wrong one.
Old Mar 15, 2015 | 02:54 PM
4DRUSH's Avatar
4DRUSH
O'rings, gaskets shouldn't effect alignment.
Try without, are the bolts long enough ?
Try rotating the ring
Old Mar 15, 2015 | 02:55 PM
nullpointer
There are two sets of holes in the ring, I am able to line those up with the factory fuel hat so I assumed I had the correct pattern. They are off mating to the tank. I am wondering if the double gasketed side facing the tank (OEM gasket | O-ringed fuel run) could be messing it up.
Then again who the hell knows, out of ideas. I'll be calling ECS tomorrow.
Old Mar 15, 2015 | 02:56 PM
nullpointer
Bolts are long enough as I can get 3 of them in and tightened. Its the rest that just don't line up with the tank holes. IDK what else to try
I tried the ring in a few diff positions and then no bolts line up.
Old Mar 15, 2015 | 02:59 PM
4DRUSH's Avatar
4DRUSH
I assume you're starting/trying all the bolts before tightening
Old Mar 15, 2015 | 03:00 PM
nullpointer
Tightened is a bad word, I should have said I was able to use my hand to screw them in more. I can't line them all up at all, even completely loose. I'll grab a pic so I appear sane.
Old Mar 15, 2015 | 03:17 PM
NITRO UK's Avatar
NITRO UK
Hi , I`m sure you have tried , but could you check the ring is rotated to the correct clocked position , those bolt holes in the tank are a bit odd , and think it will only align in one position , just saying bud .
Old Mar 15, 2015 | 03:24 PM
nullpointer
Here are a few pictures showing the bolts passing through the ring. When I attempt to then line it up with the tank, all the bolts do not line up. It's like I need to twist the ring counter clock wise a little more but I can't. I am able to get three bolts to start but the rest no dice. The pictures have no bolts connected so its not turned as much as if I was attempting to thread the bolts.
Old Mar 15, 2015 | 04:37 PM
Patches's Avatar
Patches
I had a similare issue and I realized that, at different times, I had the OEM gasket improperly oriented or the fuel ring adapter was.
The orientation of the ring should look like this:
Old Mar 15, 2015 | 05:33 PM
nullpointer
Thanks I looked at the OEM gasket before it does seem it can only go on two ways due to the flat part of the gasket. Hoping I just need to rotate it.
Old Mar 15, 2015 | 05:42 PM
nullpointer
No dice, the OEM gasket only lines up one way for me. I was originally sent a C6 kit, are there different rings for each kit? When I use the other set of holes the fuel ring sits flush as I thought it should, the holes just don't line up.
Old Mar 15, 2015 | 05:52 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
C6's don't use that ring.. They have a fuel block kind of like a bulkhead where you have to drill a hole in the tank
Old Mar 15, 2015 | 06:13 PM
nullpointer
I took a short video showing the issue. I am using the only set of holes that line up with the factory fuel hat, the other set doesn't line up properly. I hope I am just doing something stupid...
Based on patches pictures it looks like I need to turn the pump counter clock wise but I cant. It won't move...so do I need to take the pump out and try to re install at a different angle?
Old Mar 15, 2015 | 07:14 PM
4DRUSH's Avatar
4DRUSH
You're getting warm
Old Mar 15, 2015 | 08:01 PM
nullpointer
You're getting warm
I'll pull the pump and give it a shot tomorrow
Old Mar 15, 2015 | 08:47 PM
SilverZ06NC's Avatar
SilverZ06NC
I had a similar issue while doing mine, I ended up finding out the return tube was hitting the inside of the tank not allowing it to be allined right. I just "massaged" the tube to allow the adapter to align correctly. I ended up having to shorten the bolts that came with my kit also, they were bottoming out before the bolts were even close to the fuel hat. I hope this helps you.
Bryan
To ECS fuel ring install help
Old Mar 16, 2015 | 02:14 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Did this get resolved yet?
Old Mar 17, 2015 | 11:51 AM
nullpointer
Not yet, I hope to work on it wednesday night. Going to try pulling the pump out and rotating it a bit. Hope that works
Old Mar 21, 2015 | 10:50 AM
nullpointer
Pulled pump and rotated and re installed, didn't seem to change a thing. Still nothing lines up due to rotation...at my whits end. Might just drill the tank if I can't get this figured out soon.
I shouldn't have to force the pump counter clockwise for things to line up. It's not clear what I am doing wrong.
