Another F/I Project for me - WTB: Crank Balancer Install Tool
Too much stress on the stock style crank balancers with flip-drive - I replaced the OE stock one a long time back and now this one has decided to take a dump and go cockeyed and chewed the belt!
I am going with the Fluidampr 740121 solid balancer for my set-up -
SO - Before I go and purchase the one I want (HAWK install tool at Colorado Speed) I wanted to see what someone might have that they want to sell
Hit me up with what you may have
Plus I know I can make one but I do not want to make a home made job one for my project!
Thanks,Matt
661-406-7516
Thanks,Matt
661-406-7516
Thanks,Matt
For me it's worth the extra $ for the tool thus saving myself some serious heartache down the road
Thanks,Matt
Thanks,Matt
Hit me up Matt. I have a homemade one someone let me borrow on LS1tech a while ago. I never used it but it was a "pass it on" deal so I just ask that you send it to the next person who needs it.
ISIS SUCKS FAT CHOAD
You can make your own matt. But if you don't want to do that OTC makes a nice crank balancer puller / install tool.
It all came to $405 shipped free. They price matched the Fluidampr off the Internet.
So I will slap it in as soon as it comes in and pun the new one. I already yanked everything off Saturday and cleaned it all up.
Then I'll be back on the road.
Thanks, Matt
I called Summit today and they are going to have theirs in Stock this week and I got the all one piece Fluidampr at thesame time.
Thanks, Matt
Thanks, Matt
If you want pics of swapping out the balancer then I did a write-up a couple of years ago!
If you want pictures of the Balancer and Tool, I don't have those either as of yet - However here they and at this point this is the best I can do:
Balancer:
http://www.summitracing.com/parts/flu-740121
Install Tool: Enlarge the picture and you will see the hex head at the end of the shaft -
http://www.summitracing.com/parts/sum-900135
Thanks,Matt
Balancer:
Thanks,Matt
Received 1,195 Likes
St. Jude Donor '15
They're simple enough to make. Threaded rod + washers + nut, but that install tool looks nice too!
What's the advantage of the balancer you're getting compared to something like the Innovators West one?
But what advantage does the I/W have over the Fluidampr? except if you want a key-way - But I don't have a key-way on my crank snout and I would have to drill and pin the I/W too just like I will for the Fluidampr
One advantage that does appeal to me is that the price is better and I believe that the IW stock size one is $550 plus shipping compared to $360 I got the Fluidampr from Summit for-
Either way price is great on the Fluidampr and is a solid one piece balancer and Fluidampr is a proven part and it will do exactly what I need it to do for my set-up
No more crap stock rubber sealed balancers -
Thanks,Matt
Balancer:
Thanks,Matt
Balancer:
Thanks,Matt
Plus I didn't and don't "feel" like taking any chances with a home made tool - I know I can make one and have seen the specs for it -
But for me one home made mistake can cost me a crank if I do something wrong with washers ans threaded rods and nuts
To me it's worth the couple of extra bucks or at this point since I got the discount price match from Summit I essentially got the tool for free and free shipping!
Thanks,Matt
The OTC kit with the new Matco extension adapter for the LS engines is the best option there is IMO. Also, although I have the 4531 kit, for those that can't justify the expense, check with your local parts stores for what they're renting out. The rental is free and all of the stores in my town are renting that OTC kit.
I'm going to work on getting the part# for the Matco adapter and report back.
Received 1,763 Likes
ttt
Good luck buddy I know it will be good to go after this time.
St. Jude Donor '15
The problem with that method is that I've yet to find any threaded rod strong enough for repeated use. I've broken one off in the crank before and had to go through that wonderful process of extracting it.
