Boost A Pump
Old Apr 8, 2018 | 02:57 PM
BURL's Avatar
BURL
Default Boost A Pump
Where are most of you FI guys mounting your Boost A Pump. I have a C5 hatchback and would like info on the best location.
Old Apr 8, 2018 | 05:03 PM
chris308's Avatar
chris308
first pic
https://www.corvetteforum.com/forums...-question.html
Old Apr 10, 2018 | 06:37 PM
BURL's Avatar
BURL
Default Boost a pump mounting
Originally Posted by chris308
I appreciate the reply but these pics give me very little frame of reference. Can't tell where the mounting location is.
Old Apr 11, 2018 | 07:19 AM
Turpid porpoise's Avatar
Turpid porpoise
That is on the drivers side frame rail inside the rear wheel well splash guard.
Old Apr 11, 2018 | 12:31 PM
TastyBacon's Avatar
TastyBacon
I've always wondered about this...are there any other good reasons to mount the BAP back there that I'm missing besides "it stays cooler than the engine bay" and "my plug-n-play harness was designed that way"? My knowledge of basic electronics tells me that if you're trying to transmit a large amount of power over a distance, it's more efficient to do it at a higher voltage. It would make more sense to me to mount the BAP up front, and reduce the loss across the long wire to the pump by running it at the BAP voltage (17-21V) instead of the alternator voltage (13-14V). If engine bay heat is a concern, the area behind the driver's side front wheel well splash guard seems like a good option, since hotwire kits run the fuel pump power feed down there anyway. Then again, maybe the difference is really small and I'm just overthinking it. I'm a digital electronics guy, don't do much with power electronics, but I can try to run the numbers and see what I come up with.
Old Apr 11, 2018 | 01:26 PM
oneandgone's Avatar
oneandgone
I'm with you, in fact when I ordered mine from LPE they recommended mounting it by the battery and stock ecu.
Old Apr 11, 2018 | 02:33 PM
Racetronix's Avatar
Racetronix
Supporting Vendor
A great way to melt the electrical center terminals and heat soak the BAP!
Old Apr 11, 2018 | 02:39 PM
Josh@AandASuperchargers's Avatar
Platinum Supporting Vendor
We have found the left rear quarter panel to be the best place to mount the BAPs after trying all the other locations over the years.
Old Apr 11, 2018 | 02:52 PM
Racetronix's Avatar
Racetronix
Supporting Vendor
Along with one of these:
http://racetronix.biz/itemdesc.asp?ic=FPWH-007&eq=&Tp=
Old Apr 12, 2018 | 12:16 AM
oneandgone's Avatar
oneandgone
Can you elaborate please? How so? Why ok for the ECU and not the BAP?
To Boost A Pump
