Run a tank of 93 every 5-6 of E85 is what I been told. My 99 FRC has a P59 PCM swap and is setup for flex fuel.
very interested in your expereinces and tips on the P59 swap. getting all the gauges and wiring worked out and the tune setup
did you have a vendor help out with this mod? thanks for any tips. I remember the thread on this swap a while back and interested in how well it works out and wiring tips.
All I did was drop off my car at a local shop called Legacy Motorsports in Baytown TX along with a P59 pcm. I had already installed the flex fuel sensor inline on the return side. They did the rest. I've read everything from a bunch of o2 wiring has to be changed, to an alternator wire has to be moved around. All I know is the work was so affordable IMO that it wasn't my business to ask them what all they did to make it work. Before dropping it off they told me they had already done the swap before and when I picked up my car everything worked as it should.
Might want to give them a call see if there is some way they can help you out or point you in the right direction.
