ATI Overheating Problem SOLVED
Old Apr 7, 2003 | 06:01 PM
  #61
Am I Badd's Avatar
Am I Badd
Default Re: ATI Overheating Problem SOLVED (ganson)
The system you have will come close to being able to use some type of induction hood that flow outside air directly into the filter like the T/A hoods do. But this would take some further modifing to your unit and I don`t think you would want to get into doing something like that. Well at this point all I can say is drive it , enyoy it, and take care. See ya...
Old Apr 7, 2003 | 08:33 PM
  #62
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Default Re: ATI Overheating Problem SOLVED (Am I Badd)
:iagree:
vetterdstr :cheers:
Old Apr 8, 2003 | 12:30 PM
  #63
ganson's Avatar
ganson
Default Re: ATI Overheating Problem SOLVED (vetterdstr)
vetterdstr: Regarding the other problem (air temp behind the rad), do you know whether or how well the lowered rad & air bridge/filter address this? Is the air cooler just in front of the plastic rad shroud where the filter sits?
Old Apr 8, 2003 | 12:35 PM
  #64
ken-rx's Avatar
ken-rx
i've been working on a similar mod based on your pics. How does the air box stay on the SC? There's not much space there.
Old Apr 8, 2003 | 12:48 PM
  #65
ganson's Avatar
ganson
Default Re: ATI Overheating Problem SOLVED (ken-rx)
Hi Ken,
The airbox is mounted to the fan shroud, so it all slides in as one piece. It connects to the s/c via a short length of hose. It is pretty tight there, but I got lucky and it fit perfectly on the first try.
How is yours progressing?
Old Apr 8, 2003 | 01:40 PM
  #66
vetterdstr's Avatar
vetterdstr
The temps are reduced by taking in cool air as opposed to behind the shroud. The Single intercooler is in front of the AC condenser and the shroud is removed. IN a few weeks I will post Info from traces regarding IAT numbers. :)
vetterdstr :cheers:
