e-BOOST
Old Nov 24, 2004 | 10:43 PM
NICK YOSKIN's Avatar
NICK YOSKIN
St. Jude Donor '08
Default e-BOOST
Anyone here using it?
Nice as it acts as boost controller and gauge plus more...
Old Nov 25, 2004 | 10:49 AM
mdhmi's Avatar
mdhmi
I think the Blitz Controller is much slicker.
Mark
Old Nov 25, 2004 | 01:15 PM
NICK YOSKIN
St. Jude Donor '08
Mark
mark nice no doubt but you cannot stick it in pod plus e-boost will be able to set boost level per gear.
Old Nov 25, 2004 | 11:42 PM
mdhmi's Avatar
mdhmi
Yea - the Blitz is nice as you can tuck it away in your ashtray.
Mark
Old Nov 26, 2004 | 12:00 AM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
The speed controlled boost mode with the Blitz controller sounds intriguing...
Old Nov 26, 2004 | 03:44 AM
MRC5's Avatar
MRC5
is the e-boost works with porcharger ?
Old Nov 26, 2004 | 08:11 AM
gmf's Avatar
gmf
Never heard of it, more info please? Thanks!
Old Nov 26, 2004 | 08:36 AM
BLOWNZO6's Avatar
BLOWNZO6
Premium Supporting Vendor
No, the boost controller on a belt driven FI engine is the pulley.
A boost controller is for a turbocharger setup.
Back to rebuilding your motor!
__________________
EAST COAST SUPERCHARGING SALES AND TECH SUPPORT
WWW.EASTCOASTSUPERCHARGING.COM
Old Nov 26, 2004 | 12:03 PM
NICK YOSKIN
St. Jude Donor '08
http://www.turbosmart.com.au/boost_c...electronic.htm
Old Nov 26, 2004 | 12:27 PM
Z06GMAN's Avatar
Z06GMAN
St. Jude Donor '06
Just in case you didn't notice the size is larger that a normal pod gauge.
Old Nov 26, 2004 | 02:02 PM
Indiana Z06's Avatar
Indiana Z06
We're going to have to put ours in the ashtray area. Looks like a really nice piece.
Old Nov 26, 2004 | 03:56 PM
NICK YOSKIN
St. Jude Donor '08
GARY i noticed, oh well.
Old Nov 26, 2004 | 04:10 PM
Z06GMAN's Avatar
Z06GMAN
St. Jude Donor '06
Just making sure I was look at going the same way myself. So if you are going the ashtray location the Blitz has some really great options.
Old Nov 26, 2004 | 05:31 PM
NICK YOSKIN
St. Jude Donor '08
gary do you have gauge pod and if so 2 or 3 and whats in them?
i know one of tjhe gauges that i need , thats electric fuel not sure which brand though. i'd like to have boost there too, maybe ill get manual boost controller and gauge. EGT???
let me know
thanks
Old Nov 26, 2004 | 06:09 PM
Z06GMAN's Avatar
Z06GMAN
St. Jude Donor '06
I am running a 2 guage pod at this time. fuel pressure and boost both are colbalt, they really look great. But I have a wide band coming so I will have a AF gauge I can use. The great thing about the blitz is that it has the abilty to track a whole bunch of info. The more I think about it 3 gauges on the pillar will start to look busy It's getting to the point I need to get very carefull not to overdo
Old Nov 27, 2004 | 09:11 AM
VETZILLA's Avatar
VETZILLA
Gary
If you are going to get the Blitz controller do not get a separate wideband for the car. Our resident turbo guru Phil has once again been on the cutting edge and engineered a simple a way to run the AEM 5 wire wide band AFR sensor through the Bliz. The nice thing about this setup is with the turn of the dial you can monitor and log AFR's in either a digital readout or graph format, and the information is dead nutz on. It took me all of about an hour to have it all installed and tied into the boost controller. And this is not all it can log, it can be setup to log IAT's, Exhaust Temps, etc.
Also I do belive the Blitz has the ability to control boost via either rpm or mph in the scramble mode. I have not done this yet but will be tinkering with it this spring so I can keep the rears from spinning at 90mph when at the track.
Old Nov 27, 2004 | 09:16 AM
VETZILLA's Avatar
VETZILLA
Tony
I highly recommend this unit, it has alot of features that are very useful and as I said in the response to Gary, Phil has engineered how to monitor and log all of the important info through its aux inputs and the install is easy.
To e-BOOST
Old Nov 27, 2004 | 10:01 AM
NICK YOSKIN
St. Jude Donor '08
gary i agree. it can get a little to pimp dady
Old Nov 27, 2004 | 10:02 AM
Z06GMAN's Avatar
Z06GMAN
St. Jude Donor '06
Originally Posted by VETZILLA
Gary
That sounds really good Mike. Would I still be able to hook it up to the HP tuner software for data???
Old Nov 27, 2004 | 10:13 AM
NICK YOSKIN
St. Jude Donor '08
Gary
NO WAY! thats awesome. IATS and exhuast temps hows it hooked up to Blitz?
