Window Motor Help!? 1997 Corvette
Old Jan 31, 2005 | 02:35 PM
Sean99SS's Avatar
Sean99SS
Default Window Motor Help!? 1997 Corvette
Ok there has been this awful scrapping noise sometimes when my window goes up and now today the window quit going up. So I am thinking the motor but I don't know for sure because the window will go up about 1/4 the way then just stops abruptly and wont budge anymore even trying to help pull it up. But, the window will go back down just fine. Is there 2 different motors one to go up and one to go down and does this sound like it has gone out on me or maybe something is in the way? Also, is there any tip sites about how to get to the window motors and how to replace them and is there anyway to manually pull the window up?
Old Jan 31, 2005 | 04:27 PM
NoelsTorchredZ's Avatar
NoelsTorchredZ
Not so sure about it being the motor. Sounds like something came loose and is preventing it from going up or down the whole way. When my motor went out it stopped all together, nothing, nada. You may just want to pull off the door panel and take a looksie. Maybe you got lucky and just had a spring or bolt come loose. I'm pretty sure I've heard of others around here with the same problem, just can't remember exactly what was the culprit. Hopefully they will chime in. Good luck!
Old Feb 11, 2005 | 08:52 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Your best be is to pull the door panel off and inspect the regulator assy and the window track/
Bill
To Window Motor Help!? 1997 Corvette
