hi, just a quick question concerning the use of the sequencer mod..has anybody tried using the sequential unit with Euro's...does it work???
please reply. i tried putting this question in the tech and general sections but recieved no response.... thanks, dan
Reason: goofed the lingo..
Put my tail light sequencers in - took about 20 minutes. Look great.
Have not put the high mount brake light pulser in. For those that have done it, is the C5 a one wire or 2 wire set up? I'm nervous about making the "first cut" (its the deepest or so they say).
The pulser has one 3m connector, (for ground), and cut the other wire then use wire nuts.
Very easy, no big deal. If you wanted to get fancy, I suppose you could use some butt connectors for a more secure connection.
If you want to take it out (like to sell the car or just take it out), no big deal. Just remove module and put the orginal one wire you cut back together w/ wire nut or butt connetor.
Wouldn't a crapload of electrical tape wrapping be sufficient to keep any moisture out of the connectors?
Good idea, but it won't stick because of the dialectric grease. Borrow an idea from the antenna industry and wrap the connections with Coax Seal. You can then wrap it with electrical tape for further protection if you want.
