How do I reduce road noise?
Then...I added B-quiet's Vcomp...and the car is much quieter. Unfortunately, I did the B-quiet install after the winter set in in Ohio, and have not been able to remeasure the DB reduction yet. I will, and I will post the results here.
Here's a link to my B-quiet install photos...
http://forums.corvetteforum.com/showthread.php?t=989605
I've had several Corvettes over the years, beginning with a '58 in 1969 and culminating with the '02 and '99 we have today. It truly amazes me how people buy these later generation cars expecting them to be equivalent to a Lexus or Ford Crown Victoria in ride quality and interior noise level. It's still a sports car and if you know that going in your expectations should not be altered.
I did not want to epoxy or spray any insulation. I am sure there are better noise canceling materials... but they are not as light weight and as inexpensive... My research on the original dynamat , was this it gave off a tar smell when heated... it was too heavy, and too expensive.. so I never tried it because it didn't meet my criteria. the tar smell was just another negative.. I heard the new stuff is better... I did this research while I was still working, four years ago.
You'll notice the folks who achieved the most noise reduction were the ones who did not use metal faced insulation.
Walk into a recording studio and the only metal you'll find will be the instruments. Everything else will be covered in foam.
you need to learn the difference between lowering the resonate frequency of a vibrating panel - and absorbing sound. Two totally different avenues for two different applications of sound reduction.
We're stopping outside noise from being radiated inside ... not absorbing the sound that is already in the cabin.
DB meters can fool you. If you reduce 50% of just a portion of the audible spectrum - you DB meter (that is looking at a much broader range of frequencies) will not indicate a 50% reduction.
If you reduce the most irritable band (range) of audible frequencies (just a segment, and not a reduction of the entire audible range) - that can make the ear happy (where the DB meter says there wasn't much of a change).
For example; lets say you run an accurate recording of interior car noise into an amplifier with top-notch speakers in a recording studio room.
But instead of a single volume control on the amp - there are 4 volume controls.
#1 is for the 20 to 500 hz range
#2 if for the 500 to 2500 range
#3 if for the 2500 to 8000 range
#4 is for the 8000 to 20,000 range
So you turn them all up fully and the sound out of the speakers acurately simulates normal interior car noise.
But in this example the most irritating noises inside this car are from the 100 to 400hz range. I don't necessarily mean the most "loudest" noises.. but the range of car noises that are most irritating to a person.
So you turn down volume control #1 by 50% (this was the volume control for the 20 to 500hz range) and the irritating noises are cut in half. But the overall volume is only cut by 12.5%
Your ears can easily hear the difference. The driver is much less irritated, the passengers are happier, but the DB meter shows a lousy 0.3 db reduction.
Having possession of such an instrument (DB meter) is just one step. Knowing what it does, how it does it, how to interpret the results, and when to know it's being fooled - goes a lot deeper than just having one in your possession.
For most running the factory Bose in your car, you know that there is not much frequency control. I would have liked to have seen a separate "mid" control. If you are like me, I suspect you have your bass boosted and treble cut to close to the halfway point on the Bose.
Although I have been involved with sound for 30 plus years, I will leave the factory radio in the car. My 54 year old ears are not as good as they use to be.
but who has the time and money to fool around with this?
With us Corvette owners - added weight is a serious concern when adding mods. And spending money for a mod that won't increase HP is not popular here. Both ET and I have found alternative light-weight low-cost products that worked well for us, and have countless
We both know there are better products out there and have recommended them to those not concerned about weight or cost.
Yes the FK and Reflectix may not work as well as others... but it's about the best one can do when lining the entire interior for 15 lbs of added weight.
Yes, it's a trade-off (lower weight and less $ for less results - compared to heavier and costlier products). But it is what many Corvette owners are seeking.
If you seek other goals and have different restrictions/concerns - great then. Find the best products to fit your criteria.
No one here is coming down on you for your choices.
Peace
Willfulone
I do not use ignore feature. I have seen plenty of your posts that are worth while and informative. None on sound proofing though.
As for the time and money. Ding ding...I have made the offer many times. To anyone within a reasonable distance that is going to do this mod anyways. I will use my Audio Control RTA to measure the car across various terains if needed at various speeds before and after installation. I would actually do it on my own car if it was not already sound deadened with Stinger Road Kill.
orth it.
