LED interior colors??
Old Feb 16, 2005 | 02:53 AM
Hirohawa's Avatar
Hirohawa
I live in LA. How much would it cost to do this setup in the ultra white? You can PM me if you don't want to post an answer or email me hirohawa@aol.com.
Steve
Old Feb 16, 2005 | 03:34 AM
SpdKilz's Avatar
SpdKilz
Steve
The LEDs are relatively cheap. Go to www.oznium.com and if you are doing the doorpanels, purchase the white 3mm LEDs vs the 5mm, so you don't have to cut the LED down.
It should cost you around 10-15 dollars.
Carleton
Old Feb 16, 2005 | 05:19 AM
Hirohawa's Avatar
Hirohawa
How difficult is it to install and how many hours approx?
Are the 3mm White LEDs brighter than the stock setup?
Old Feb 16, 2005 | 01:15 PM
SpdKilz's Avatar
SpdKilz
If you just do the door panels, I would say it should take about two hours if you have no experience with this.
It isn't too dificult to install.
Yes, the 3mm White LEDs should be brighter than the stock setup.
Carleton
Old Feb 22, 2005 | 10:39 AM
TorchedTexan's Avatar
TorchedTexan
I just did mine in red. I did them with 5mm LED's because I was afraid they would not be bright enough in red with the 3mm. I am not 100% happy with the ride control, even though the only light I am using is on the left button the right one still looks brighter. I was going to do the same thing as one member and put black on the tip but I tried just taking it out and it looks balanced now. Just not bright enough, I am thinking about putting a non cut head LED in the left side to see if that will do the trick. The center looks good but not as good as the doors.
It took about two hours. I could do it quicker now.
The came out great, I did the doors, ride control and the trunk/fogs. I really want to do the dash but I am going to wait until I buy some aluminum trim rings and do them at the same time because I think you have to pull the whole cluster.
Old Feb 22, 2005 | 12:44 PM
JohnTheStigGalt's Avatar
JohnTheStigGalt
Old Feb 22, 2005 | 01:04 PM
WhiteC5Vette's Avatar
WhiteC5Vette
St. Jude Contributor
I did the door switches on Saturday, and it took just a hair over one hour.
Old Feb 22, 2005 | 01:33 PM
TorchedTexan
Originally Posted by SeaLawyer
Ok ok...
I will drag out my tripod and get some night shots.
Old Feb 22, 2005 | 02:47 PM
wicked 98z's Avatar
wicked 98z
Just let me know when you want to see how fast you can do it. Ill send you mine
Albert
Old Feb 22, 2005 | 03:14 PM
LV_2_XLR8's Avatar
LV_2_XLR8
How red are they? I was afraid they would turn out pink because of the white letters on the switches. Pictures would be helpful, thanks...
Old Feb 22, 2005 | 03:23 PM
illmac77's Avatar
illmac77
CI 7-8 Veteran
CI 8 Car Show Winner
St. Jude Donor '07
im waiting on my blue led and bezels to come in to do up the cluster. im gonna try and change every light i can ill take a bunch of pics when im finished.
Old Feb 22, 2005 | 03:51 PM
TorchedTexan
The door panels look great, a nice red at night, a little pinkish in half light, this would be true of any color though, I am sure the blue is a lighter during the day.
I still need to come up with something for the ride control ones though... I am not really happy with them, one side looks good and the other looks too dim.
Old Feb 22, 2005 | 04:45 PM
  #33
LV_2_XLR8's Avatar
LV_2_XLR8
Thanks, TT. You might want to think about lowering the value of the resistor on the dim side. I know that LEDs can stand a slightly higher voltage without burning out and it just may give you the brightness you need. Good luck and thanks for the speedy response.
Old Feb 22, 2005 | 07:50 PM
  #34
TorchedTexan
I went home and shot this one after work today. I did not get pics of the center console. I may try the higher voltage idea, I am actually thinking about drilling a hole and just adding one.
Anyhow if you are on the fence about doing it in red this should help. They are even a darker red in person.
Old Feb 22, 2005 | 07:58 PM
  #35
illmac77's Avatar
illmac77
CI 7-8 Veteran
St. Jude Donor '07
looks great torch!!!!much better then stock
Old Feb 23, 2005 | 10:19 AM
  #36
LV_2_XLR8's Avatar
LV_2_XLR8
Thanks for the pic, TT. That's just the effect I was looking for. Red like an airplane cockpit. Great job!
Old Feb 23, 2005 | 10:51 AM
  #37
JohnTheStigGalt
Now THAT'S HOT!!!! Planning to do this mod, was undecided on the color... My decision is now made -- red it is!!
To LED interior colors??
Old Feb 24, 2005 | 02:16 AM
  #38
TorchedTexan
That's what I was thinking... I have only seen it in movies, firefox comes to mind; slow movie to start but it gets good in the end. Cough Cough, back on topic, that's why I am looking forward to getting my aluminum gauge rings so I can do controls around the gauges and complete the cockpit look.
Old Feb 28, 2005 | 01:56 AM
  #39
TorchedTexan
I solved the too dim traction control button issue, I added another LED. I used the black on the bulb tip idea for the bulb under the ride control. I think they look relatively balanced amd bright like the doors now. Here is the picture with the extra LED (I know it looks like hell but it works fine). I was going to do the mirror today but I decided to try the HVAC controls instead. I was testing the voltage when I shorted the thing out. The blue smoke means the magic genie of electricity has left the building...
Anyhow that will be about a $100+ mistake. Live and learn and mod.
Old Feb 28, 2005 | 02:08 AM
  #40
RockinC5's Avatar
RockinC5
Here's a great price on a replacement for ya, unless you have the dual zone option.
http://forums.corvetteforum.com/show....php?t=1024350
I had a few close calls when I did my HVAC, but nothing that forced it to give up the ghost
