LED interior colors??
Old Mar 1, 2005 | 09:30 PM
  #61
WhiteC5Vette's Avatar
WhiteC5Vette
St. Jude Contributor
Originally Posted by RockinC5
the existing bulbs before putting in the new LED's. It also takes some creativity and patience to determine which is the pos and neg lead on the circuit board. If someone could track down schematics on the board that would be very helpful but I had no luck, even tried a couple local dealers... but found nada.
Dealer would not have the schematic, since the unit is not actually repairable by the dealer. Need to get a copy of the engineering drawing from the engineers who designed the unit.
Connecting a 12 volt source (or even a 9-volt source) to the unit while it was out and then using a volt meter might help in determine which trace on the circuit board is positive, which is negative.
Old Mar 2, 2005 | 03:12 AM
  #62
SpdKilz's Avatar
SpdKilz
That's what I did!
