Broken seat?
Old Feb 16, 2005 | 08:35 PM
jmzvet's Avatar
jmzvet
Default Broken seat?
My passenger side seat back feels like it broken on one side. When you lean back, the upper right side leans back further than the left.
Has anyone else had this problem?
Old Feb 16, 2005 | 09:02 PM
gtzy's Avatar
gtzy
Condition
Some customers may comment on the driver's or passenger's seat back twisting.
Cause
This condition may be caused by the seat back recliner cables not releasing together.
See dealer about TSB # 04-08-50-005,,seat back twisting[resynchronize seat back recliner]
Old Feb 16, 2005 | 09:06 PM
cjlaw73's Avatar
cjlaw73
My driver side is a little off and does something similar. If I release it all the way forward and then use my back to recline both sides in sync it resets okay. Stupid little fix that works for mine, but mine may not be as far along as yours.
Old Feb 16, 2005 | 09:09 PM
JeffC5's Avatar
JeffC5
From: Edmond, OK...One of the first rules of online forums: If you don't like what is said but can't refute it, attack the poster.
My passenger side seat did that. I just tilted it all the way forward, then all the way back. Then adjusted it where i wanted it and it has worked fine so far. Only happened once.
jeff
Old Feb 16, 2005 | 11:05 PM
jmzvet's Avatar
jmzvet
Thanks for the info. I'll give it a shot.
Old Feb 16, 2005 | 11:50 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
I went through this when the salesman got in my car and I took him for a ride. He moved it forward and then back and it straightened it right out. Seems to be pretty common.
Old Feb 17, 2005 | 12:22 AM
3RD-INF's Avatar
3RD-INF
Had my drivers side replaced last month under f/w.
Old Feb 17, 2005 | 08:41 AM
TrackAttack!'s Avatar
TrackAttack!
St. Jude Contributor
I had this happen to mine this past summer. A buddy of mine was reaching around for his wallet and we heard a big POP! The outside passenger upper seat frame broke right at the pivot point of the seat. Dealer goodwilled the parts and labor! If the above posts don't fix it, this could be the the reason.
Old Feb 17, 2005 | 09:05 AM
dajael
Guest
Posts: n/a
Had the exact same problem...dealer fixed it under warranty.
To Broken seat?
