GHL Question
Old Feb 26, 2005 | 10:42 AM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
Magnum Plus 6" cans..zero resonance!
Old Feb 26, 2005 | 12:18 PM
breezn24's Avatar
breezn24
Originally Posted by MJD
You may also want to consider the magnum plus. From what I've read the also have the 6 inch cans like the bullets but their cost falls in between the bullets and magnums. If I've read correctly the cost difference between magnum plus and bullet series are the tips that are used.
I have the 6-inch magnum-plus, and love 'em! They're a little quieter than the 5-inch magnums, yet still loud enough to annoy the neighbors, and they sound incredible at WOT There's some interior drone at around 1,800, but it's not too bad.
The magnum series is not nearly as expensive as the bullet series. IMO, the only downside to the magnum-plus is the tips--you can't get four tips, only two.
Old Feb 26, 2005 | 03:48 PM
lloaf's Avatar
lloaf
Breezn24--Do you have x-pipe, and if so which one ? thanks.
Old Feb 27, 2005 | 09:03 AM
BudgetPlan1's Avatar
BudgetPlan1
St. Jude Donor '09-'10
Originally Posted by Freestyler
any way to post some wav files of your respective exhausts just to try and compare?
Much appreciated if you can,
Cheers
FreeStyler
Bullets on otherwise stock 2004 A4
GHL Bullets
GHL Bullets on Dyno
Old Feb 27, 2005 | 10:50 AM
35thAnivSS's Avatar
35thAnivSS
Budget:
Did you put an X-pipe on your GHL set-up?
Old Feb 27, 2005 | 11:36 AM
DIP51's Avatar
DIP51
2018 C2 of Year Winner
Budget, what size & style tips are those??
Old Feb 27, 2005 | 12:17 PM
MY1STPEWTER's Avatar
MY1STPEWTER
I have the Ghl bullets with the Ghl x-pipe. There is still some burble on decel but not popping. They sound great and I have not noticed any resonance with mine at any speed, not that I can notice anyway. What really improved the sound more was when I installed the Halltech Stinger. It gave it a more throaty sound. I'd say you couldn't go wrong with any of the Ghl's. My gas mileage has suffered ever since I put them on and I love every second of it.
Old Feb 27, 2005 | 04:47 PM
BudgetPlan1
Originally Posted by 35thAnivSS
Budget:
No x-pipe
Old Feb 27, 2005 | 04:51 PM
35thAnivSS's Avatar
35thAnivSS
Originally Posted by BudgetPlan1
No x-pipe
I am pulled. Originally thought I was gonna put one in - now (after hearing yours and others) not sure. Seems to take some of the 'bite' out of the system.
Old Feb 27, 2005 | 06:48 PM
DIP51's Avatar
DIP51
I kinda like the sound with the H-Pipe better.
Old Feb 27, 2005 | 08:11 PM
2003vert's Avatar
2003vert
Finally, should I go with an X-pipe or leave the stock H-pipe on and who has the best prices around for GHL's??
I have an A4 and did go with the X Pipe You may want to stay with the H Pipe,, if you like it then you are $$ ahead.
