Trunk Emblem
Old Mar 7, 2005 | 07:21 PM
Derek Byrne's Avatar
Derek Byrne
Default Trunk Emblem
Anyone know how to remove the rear emblem ?
Old Mar 7, 2005 | 07:25 PM
ZaydeZ06's Avatar
ZaydeZ06
I've seen this question before. Maybe do a search. I think that I recall you remove it like body side moldings, heat it with a hair dryer and remove using poly fishing line. good luck
Old Mar 7, 2005 | 07:30 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
Hairdryer and, if necessary, a length of fishing line to 'saw' it off - no screws or hidden fasteners, and no alignment pins like the front one.
Old Mar 7, 2005 | 07:32 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
Make sure that you warm the emblem up enough so that the adhesive don't wreck the paint.
Old Mar 7, 2005 | 07:34 PM
Z0SLIK's Avatar
Z0SLIK
Derek Byrne
Thanks guys
Old Mar 7, 2005 | 07:42 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Ohhhh yeaaaaaaaaa!! Here is a link that will get you started!!
Make sure that you get the trunk and emblem nice and warm. With some stout fishing line, seterate the emblem from the adhesive. Do not try to seperate the adhesive from the trunk!! The adhesive has grit, dirt and trash ebbeded in it. If you drag the fishing line against the trunk it might scratch the paint.
Once you get the flags on both sides loose, just slowly peal the rest of the emblem off. I used my fingers to roll most of the excess glue off the trunk. Keep the glue warm!! When you get most of it off you can use Gooe B Gone to help get the adhesive off. I used PB Blaster! The stuff is amazing!! It will NOT harm the paint and made short work of the stickey!
Then polish off the area. Use medium compound to smooth off the area, then clay bar the area, them use wax. It will look very COOL!
Bill C
Old Mar 8, 2005 | 11:16 AM
Yoggi's Avatar
Yoggi
Old Mar 8, 2005 | 01:19 PM
That's the way. Best of luck getting it off.
Old Mar 8, 2005 | 01:21 PM
JACKAL0PE's Avatar
JACKAL0PE
Lepus-temperamentalus
Don't know about that one.
It looks kinda "neckked" to me.
Old Mar 8, 2005 | 01:23 PM
alssiri's Avatar
alssiri
Had mine removed,even without me asking(damn thieves)
To Trunk Emblem
