Techron additive....
Old Mar 9, 2005 | 06:03 AM
About time for me to run a bottle though mine. Thanks for the reminder.
Old Mar 9, 2005 | 09:16 PM
jsdanehy's Avatar
jsdanehy
Senior Member
Cruise-In V Veteran
Originally Posted by Grumpy
wally world $4.50 or so..
PEP Boys too
Old Mar 9, 2005 | 09:41 PM
joeking's Avatar
joeking
Cruise-In II Veteran
Cruise-In III Veteran
I give it a bottle every 6 months. I have never had a gas guage problem with C-5's.....its the darn oil pressure sensor that can haunt a person.
Old Mar 9, 2005 | 10:28 PM
Half-Life's Avatar
Half-Life
Originally Posted by Zilla
I am not trying to burst your bubble but Techron will not solve all problem with the fuel gauge. The dealer replaced my sending unit etc... and I still have a gas guage that is wonky..
Just thought i would let you know.
Same here. I've been using Techron ever since my gauge went bonkers but no effect. As with Zilla, the dealer changed the sending unit too. I'm in the northeast, I think it has something to do with the winter reformulated gas. Oh well, at least my valves are clean.....
Old Mar 10, 2005 | 04:51 AM
Vette_Fan's Avatar
Vette_Fan
Sounds great...Thanks for sharing. Will try. Has anyone tried the REDLINE fuel additive? Its supposed to clean your entire fuel system, including jets. HOW is this product compared to the Techron? Anyone....?
Old Mar 10, 2005 | 06:46 AM
EHS's Avatar
EHS
Well, sounds like time for the PCM update as well. Solved my problem, finally, after three sending units were replaced.
Old Mar 10, 2005 | 08:18 AM
Steve-H's Avatar
Steve-H
$7 will buy a gallon of lacquer thinner which is what most additives are. petroleum distillates.
Freestyler's Avatar
Freestyler
CHEVron CHEVrolet Corvette
of course they were meant for each other
anyone tried Slick 50 or similar for an OilAdditive? Thots?
FreeStyler
Old Mar 10, 2005 | 08:42 AM
JohnnyB's Avatar
JohnnyB
Originally Posted by USARMYTTT
Thank you sir. My guage is acting up and I will give this a try. I assume you just add it to a full tank and let it do it's work???
I've always added it to an empty tank. Don't forget, we have 2 tanks with contacts in each. I feel that by adding it while empty, it gets mixed up and distributed to both tanks equally.
Old Mar 10, 2005 | 09:06 AM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Thats a good point actually that I hadn't thought of.
Old Mar 10, 2005 | 09:14 AM
NitrousMan's Avatar
NitrousMan
I've had really good luck with Amsoil gas treatment.
Old Mar 10, 2005 | 09:19 AM
sxeC7's Avatar
sxeC7
St. Jude Donor '06-'07-'09-'10
That's cause you Nanook of the North Guys are wonky to start with.
I just use Chevron 93.
Old Mar 10, 2005 | 10:03 AM
  #33
EHS's Avatar
EHS
How many gallons of lacquer thinner per tankful?
Old Mar 10, 2005 | 12:09 PM
  #34
SavPrato's Avatar
SavPrato
Anyone know if "TECHRON" is available in Canada?
Old Mar 10, 2005 | 12:13 PM
  #35
junkmn's Avatar
junkmn
You do know that lacquer thinner is a mix of alcohol, acetone and a few other things. No acetone in my gas tank, thanks!
Old Mar 10, 2005 | 12:18 PM
  #36
EHS's Avatar
EHS
Hey, I didn't bring it up, I just want to know how much I put in, like maybe a full couple of gallons. Won't it not only clean, but also really enhance the performance with the acetone?
Old Mar 10, 2005 | 01:41 PM
  #37
vetdude's Avatar
vetdude
Techron Fuel System Cleaner also available at Costco in a 4-pack - forgot the price though, but less than $20.
To Techron additive....
Old Mar 10, 2005 | 05:14 PM
  #38
jmesox's Avatar
jmesox
If you bought the Pep Boys M.A.D.D calender. Buy one get one free. last time I checked they still had some.
John
Old Mar 10, 2005 | 05:43 PM
  #39
tmcclaff's Avatar
tmcclaff
St. Jude Donor '04 & '05
I wish could get Chevron gasoline here but there aren't any stations. I do put Techtron in all my cars about every 2 months
Old Mar 10, 2005 | 08:42 PM
  #40
WhiteC5Vette's Avatar
WhiteC5Vette
St. Jude Contributor
True, won't fix all the problems with the sender unit. If the coating has been dissolved, and the contacts are destroyed, a replacement is necessary. If the sender contacts are just filmed over, Techron will help, as well as any premium grade fuel with maximum cleaner that is of a good brand (e.g., Shell V-power, BP, etc.).
One thing many forget is that Techron is also an excellent top engine cleaner. GM and Saturn did extensive testing about six years ago on cylinder head/valve deposits, and found Techron to be the best additive made to clean top engine components.
If there is a buildup on a piston, soak it overnight with pure Techron. Just remove the plugs, poor it in and let it sit. Next morning crank the engine WITH THE PLUGS STILL OUT, once all Techron is removed, install plugs and start, and the tailpipes will shoot out blue smoke for about one minute.
It's an amazing chemical, but not a total fix all for all fuel gauge sender problems.
