help
Old Mar 15, 2005 | 06:44 PM
calvette 11's Avatar
calvette 11
Default help
How much trouble is it to put in a clutch and swap out the rear end.Can this be done with average tools in my garage? I have a 2000.How many hours?
Old Mar 15, 2005 | 07:18 PM
Cajun @ Edgyvette's Avatar
0Cajun @ Edgyvette
Former Vendor
St. Jude Donor '07-'08-'09-'10-'11-'12'-'13-'14-'15
If you have never done it before I would HIGHLY suggest at least having someone that has done it before standing by and helping you. You will need a lift or very high jack and stands. You will also need supporting devices for rear axle and rear diff. At least read up on it and get ALOT of pointers before taking this type of thing on........bottom line, if you dont know what you are doing you may end up with a headache and an unsafe car
Good luck
Cajun
Old Mar 15, 2005 | 07:19 PM
SPD KILZ's Avatar
SPD KILZ
Its trouble. Its probably gonna take two people especially to get that tranny down. As far as the pumpkin its just plug and play, but that’s a lot easier said then done...... Personally I'd let the pro's do it like HPE, MTI, or where you can get that kind of quality of work. Matter of fact my cars getting done right now. The only prob is the change $$$$!
Old Mar 15, 2005 | 08:30 PM
zowhat's Avatar
zowhat
do yourself a favor and pay the pros to handle this one not only do you have to remove the rear subframe you can break the oil pressure switch if you pull the trans out at the wrong angle its no easy mustang clutch the corvette will need a lift and somebody that knows the car to do it good luck
Old Mar 15, 2005 | 08:34 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Hmmm C5 tech would be a better place to ask
To help
