10w30 or 5w30?
Old Mar 28, 2005 | 10:24 AM
  #61
bsmithC5/2004's Avatar
bsmithC5/2004
Originally Posted by Gearhead Jim
I'm suspicious of the idavette article- the part number they list for steering fluid is not what's in my owners manual, and they seem to recommend 10W-30 all the time. Here in Chicago, I use 10W-30 in the summer but 5W-30 in the winter. That keeps me within the manual requirements but give the advantage thinner oil for cold weather startups and thicker oil in summer.
During summer, if i use 5W-30 the cars burns a quart about every 3,000 miles. During summer, 10W-30 gives about 4,000 miles per quart.
Why would it matter when car is at operating temp. it is a 30 you don't drive around with a cold engine temp.
Old Mar 28, 2005 | 10:40 AM
  #62
Dave68's Avatar
Dave68
Originally Posted by Richin Chicago
I don't know where you come up with this stuff but it always seems to be second hand heresay.
5w-30 has a pour point of -45deg C
http://www.mobil.com/USA-English/Lub...bil1_5W-30.asp
10w-30 has a pour point of GUESS WHAT? -45 deg C!
http://www.mobil.com/USA-English/Lub...il1_10W-30.asp
It is the same pour point!
According to the Mobil 1 tech rep, that information is wrong. The 5W-30 pour point is actually 5 degrees lower that that of 10W-30. The important thing though, is that 5W-30 is thinner at normal startup temps, reducing wear that inherent to the startup process.
Old Mar 28, 2005 | 10:48 AM
  #63
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
5w-30...just because I change my oil like my undershorts...not because it needs it, but it is a good escape from the wife and kids
plus..it's what the build specs say goes in it...
Peace
Willfulone
Old Mar 28, 2005 | 10:58 AM
  #64
Richin Chicago's Avatar
Richin Chicago
Originally Posted by bsmithC5/2004
5x30 Mobil 1 .thats what GM says .Here is food for thought .I have a Ford F150 and a Ford Focus Ford calls for 5x20 first oil change I put in 10x30 before I realised it said 5x20 on the oil fill cap .I called the dealer they said dump the 10x30 .put in 5x20 .The clearances are so tight in these engines they said it could blow out crank seals and others with to high oil pressure .I guess they could be right so I always use factory specs.Most engines today are this way and use lower viscosity oils.
I'm sorry but somebody at the dealer is being quite dramatic.
Most 5w20 oils have a 100°C, cSt of around 10. 5W20 oils come in around 8.5 if a 1.5 viscosity difference is going to do damage to an engine, it is a very very fragile engine.
Old Mar 28, 2005 | 11:31 AM
  #65
Patman's Avatar
Patman
Pour point doesn't mean much though, the proper number to look at is the cold cranking viscosity of the two oils. And you can see when you look at those specs, that a 5w30 will have much better cold cranking numbers than a 10w30. Pour point is simply 5 degrees higher than the temperature at which the oil turns into a solid. And it's basically a meaningless test.
Old Mar 28, 2005 | 02:22 PM
  #66
Corvette00Car's Avatar
Corvette00Car
I couldn't decide so I use 3 quarts of each to total about 6. I save the 5-30 for precharging the filter. Oh well.
Old Mar 28, 2005 | 03:45 PM
  #67
thug29's Avatar
thug29
Question;
Where can I find the following items please.
1. Baldwin Oil Filter
2. German Castrol Syntec Oil
Thanks guys.
Old Mar 28, 2005 | 03:46 PM
  #68
Lancer033's Avatar
Lancer033
well, it is a Ford engine
Old Mar 29, 2005 | 02:48 PM
  #69
Patman's Avatar
Patman
Originally Posted by thug29
Question;
Thanks guys.
German Castrol Syntec 0w30 is only sold in the US at larger Autozone stores. Nobody else has it. In Canada it can be found at Walmart, Canadian Tire and Partsource.
I have no idea where to get a Baldwin filter from, but I'm sure someone on here must know.
Old Mar 29, 2005 | 03:52 PM
  #70
Dave68's Avatar
Dave68
Since the Baldwin is fairly hard to find and the K&N flows and filters just as well, I'd get the K&N filter instead. I've been using one for the past four months and am very happy with its ability to quiet the inherent valve tappping at startup.
Old Mar 29, 2005 | 04:12 PM
  #71
C66 Racing's Avatar
C66 Racing
As a note for those looking for Baldwin filters, Baldwin is the manufacturer of the AMSOIL SDF Oil Filter which can be bought via the AMSOIL link to the left, the link in my signature, or using this info:
AMSOIL Ordering Information
AMSOIL Preferred Customer Program
As a note, the AMSOIL SDF Filters and the Baldwin filters are not the same. The AMSOIL SDF Filter has a special Cellulose, Synthetic and Glass Blend Media. Part number for the C5/Z06 is SDF32.
All sales via my dealership benefit my race team and this site. Thanks for your support.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Mar 29, 2005 | 05:40 PM
  #72
66427-450's Avatar
66427-450
i think you'll see that the Baldwin B31 has a bit more DP compaired to the K&N HP1007..... i.e., the K&N usually has an oil pressure about 2-4#'s higher at idle (that's according to my notes anyway)....... I use the K&N BTW (from Auto Zone)
Old Mar 29, 2005 | 05:52 PM
  #73
C66 Racing's Avatar
C66 Racing
Not that I know what the "correct" answer is here... and actually there probably isn't one, but to add a little info to the discussion.
0w oil isn't by definition any "thinner" than 5w oil, it just has a lower pour point. You can see from the below tables that AMSOIL Series 2000 0w30 actually has a higher viscosity at both 40C and 100C than does Mobil 1 5w30.
Any 30 weight oil will have a cST viscosity somewhere in the range of 9.30-12.49 at 100C (212F).
Almost every oil manufacturer reports viscosity at 40C (104F) and 100C (212F). I compiled the below info directly off the manufacturer's websites. I can provide links if anyone wants them.
First is listing of highest to lowest Viscosity (cST) at 212F or near normal operating temp. Higher is nearer 40 weight, lower nearer 20 weight, all are within the 30 weight band of 9.3-12.49:
Viscosity 40C (104F) cST/Viscosity 100C (212F) cST
AMSOIL SAE 10w30 66.1 11.8
AMSOIL SAE 5w30 64.3 11.6
AMSOIL Series 2000 0w30 56.9 11.2
Redline 5w30 67 10.9
Redline 10w30 70 10.7
Castrol Syntec 10w30 59.6 10.1
Mobil 1 10w30 62 10.0
Mobil 1 5w30 56 10.0
Castrol Syntec 5w30 58.2 9.7
Second is listing of lowest to highest viscosity (cST) at 104F or nearer startup temp:
I've listed the highest to lowest at 212F as most people seem to want a higher viscosity at normal operating temp, and lowest to highest at 40C as most seem to want a lower viscosity at startup.
P.S. I'm not sure if the Castrol numbers apply to the "German" Castrol. These numbers are pulled off the Castrol North America website for Castrol Syntec sold in North America, which the "German" Castrol is. Best I could do, sorry.
Old Mar 29, 2005 | 10:36 PM
  #74
FLACHUSNRET's Avatar
FLACHUSNRET
St. Jude Donor '11-'12-'13-'14-'15-'16
I located my Baldwin oil filters by clicking on their web site. Just type in Baldwin oil filter on your search. Once you find their web site you should be able to type in your zip code and find the dealers near you. They will most likely be tractor or industrial equipment distributors.
I am definitely changing to 10w30 oil the next time I change the oil as I still have the tap tap in my '02 vert which has only 9000 miles on it even with the Baldwin filter. I live on the Gulf Coast and I never drive my car if the temperature is below 40 degrees. I store my car in my basement garage which never gets colder than 60 degrees even if outside temp gets down in the twenties.
Old Mar 29, 2005 | 11:12 PM
  #75
2pedala's Avatar
2pedala
Default more in driving habit than 5s or 10s
ive been trained by mobil an do preventive ****. for living, in all ive learned. you do more wear in just reving up your car at red lite ,whats called no loading ,than the diff of 5 or 10 will ever make.
Old Mar 30, 2005 | 04:56 PM
  #76
Patman's Avatar
Patman
I had some of my German Castrol analyzed in it's virgin (unused state) and it gave the following viscosity numbers:
67.6 cst at 40c
12.2 cst at 100c
So it is a very thick 30wt, almost a 40wt oil actually. This is one of the reasons why it performs so well in the LS1, because these engines like the slightly thicker oils like this.
Old Mar 30, 2005 | 09:58 PM
  #77
Richin Chicago
67.6 cst at 40c
12.2 cst at 100c
In my opinion any engine will "like" very thin oils with great sheer resistance. It just happens that some thicker oils do that better. But that is changing.
